74HCT670D,652
74HCT670D,652
    NEXPERIA(安世)
    n/a
74HCT670D,652 数据手册
INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT670 4 x 4 register file; 3-state Product specification File under Integrated Circuits, IC06 December 1990 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 the location of the stored word. When the WE input is LOW, the data is entered into the addressed location. The addressed location remains transparent to the data while the WE input is LOW. Data supplied at the inputs will be read out in true (non-inverting) form from the 3-state outputs (Q0 to Q3). Dn and Wn inputs are inhibited when WE is HIGH. FEATURES • Simultaneous and independent read and write operations • Expandable to almost any word size and bit length • Output capability: bus driver • ICC category: MSI Direct acquisition of data stored in any of the four registers is made possible by individual read address inputs (RA and RB). The addressed word appears at the four outputs when the RE is LOW. Data outputs are in the high impedance OFF-state when RE is HIGH. This permits outputs to be tied together to increase the word capacity to very large numbers. GENERAL DESCRIPTION The 74HC/HCT670 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC/HCT670 are 16-bit 3-state register files organized as 4 words of 4 bits each. Separated read and write address inputs (RA, RB and WA, WB) and enable inputs (RE and WE) are available, permitting simultaneous writing into one word location and reading from another location. The 4-bit word to be stored is presented to four data inputs (D0 to D3). The WA and WB inputs determine Design of the read enable signals for the stacked devices must ensure that there is no overlap in the LOW levels which would cause more than one output to be active at the same time. Parallel expansion to generate n-bit words is accomplished by driving the enable and address inputs of each device in parallel. QUICK REFERENCE DATA GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns TYPICAL SYMBOL PARAMETER CONDITIONS UNIT HC tPHL/ tPLH propagation delay Dn to Qn CL = 15 pF; VCC = 5 V CI input capacitance CPD power dissipation capacitance per package notes 1 and 2 Notes 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz fo = output frequency in MHz ∑ (CL × VCC2 × fo) = sum of outputs CL = output load capacitance in pF VCC = supply voltage in V 2. For HC the condition is VI = GND to VCC; for HCT the condition is VI = GND to VCC −1.5 V ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. December 1990 2 HCT 23 23 ns 3.5 3.5 pF 122 124 pF Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 5, 4 RA, RB read address inputs 8 GND ground (0 V) 10, 9, 7, 6 Q0 to Q3 data outputs 11 RE 3-state output read enable input (active LOW) 12 WE write enable input (active LOW) 14, 13 WA, WB write address inputs 15, 1, 2, 3 D0 to D3 data inputs 16 VCC positive supply voltage Fig.1 Pin configuration. Fig.2 Logic symbol. Fig.3 IEC logic symbol. WRITE MODE SELECT TABLE OPERATING MODE INPUTS WE Dn Fig.4 Functional diagram. READ MODE SELECT TABLE INTERNAL LATCHES(1) OPERATING MODE INPUTS OUTPUT RE INTERNAL LATCHES(1) Qn write data L L L H L H read L L L H L H data latched H X no change disabled H X Z Note Notes 1. The write address (WA and WB) to the “internal latches” must be stable while WE is LOW for conventional operation. 1. The selection of the “internal latches” by read address (RA and RB) are not constrained by WE or RE operation. H = HIGH voltage level L = LOW voltage level X = don’t care Z = high impedance OFF-state December 1990 3 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 Fig.5 Logic diagram. December 1990 4 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 DC CHARACTERISTICS FOR 74HC For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: bus driver ICC category: MSI AC CHARACTERISTICS FOR 74HC GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 −40 to +85 −40 to+125 min. typ. max. min. max. min. UNIT V CC WAVEFORMS (V) max. tPHL/ tPLH propagation delay RA, RB to Qn 58 21 17 195 39 33 245 49 42 295 59 50 ns 2.0 4.5 6.0 Fig.6 tPHL/ tPLH propagation delay WE to Qn 77 28 22 250 50 43 315 63 54 375 75 64 ns 2.0 4.5 6.0 Fig.7 tPHL/ tPLH propagation delay Dn to Qn 74 27 22 250 50 43 315 63 54 375 75 64 ns 2.0 4.5 6.0 Fig.7 tPZH/ tPZL 3-state output enable time RE to Qn 39 14 11 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.9 tPHZ/ tPLZ 3-state output disable time RE to Qn 47 17 14 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.9 tTHL/ tTLH output transition time 14 5 4 60 12 10 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.6 tW write enable pulse width LOW 80 16 14 14 5 4 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.8 tsu set-up time Dn to WE 60 12 10 3 1 1 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.8 tsu set-up time WA, WB to WE 60 12 10 6 2 2 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.8 th hold time Dn to WE 5 5 5 0 0 0 5 5 5 5 5 5 ns 2.0 4.5 6.0 Fig.8 th hold time WA, WB to WE 5 5 5 0 0 0 5 5 5 5 5 5 ns 2.0 4.5 6.0 Fig.8 tlatch latch time WE to RA, RB 100 20 17 28 10 8 125 25 21 150 30 26 ns 2.0 4.5 6.0 Fig.8 December 1990 5 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 DC CHARACTERISTICS FOR 74HCT For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: bus driver ICC category: MSI Note to HCT types The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT Dn WE, WA WB 0.25 0.40 0.60 RA RB RE 0.70 1.10 1.35 December 1990 6 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 AC CHARACTERISTICS FOR 74HCT GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 −40 to +85 −40 to +125 min. typ. max. min. max. min. UNIT V CC WAVEFORMS (V) max. tPHL/ tPLH propagation delay RA, RB to Qn 21 40 50 60 ns 4.5 Fig.6 tPHL/ tPLH propagation delay WE to Qn 28 50 63 75 ns 4.5 Fig.7 tPHL/ tPLH propagation delay Dn to Qn 27 50 63 75 ns 4.5 Fig.7 tPZH/ tPZL 3-state output enable time RE to Qn 18 35 44 53 ns 4.5 Fig.9 tPHZ/ tPLZ 3-state output disable time RE to Qn 19 35 44 53 ns 4.5 Fig.9 tTHL/ tTLH output transition time 5 12 15 18 ns 4.5 Fig.6 tW write enable pulse width LOW 18 9 23 27 ns 4.5 Fig.8 tsu set-up time Dn to WE 12 4 15 18 ns 4.5 Fig.8 tsu set-up time WA, WB to WE 12 −2 15 18 ns 4.5 Fig.8 th hold time Dn to WE 5 −1 5 5 ns 4.5 Fig.8 th hold time WA, WB to WE 5 0 5 5 ns 4.5 Fig.8 tlatch latch time WE to RA, RB 25 11 31 38 ns 4.5 Fig.8 December 1990 7 Philips Semiconductors Product specification 4 x 4 register file; 3-state 74HC/HCT670 AC WAVEFORMS (1) HC : VM = 50%; VI = GND to VCC. HCT : VM = 1.3 V; VI = GND to 3 V. (1) HC : VM = 50%; VI = GND to VCC. HCT : VM = 1.3 V; VI = GND to 3 V. Fig.6 Fig.7 Waveforms showing the read address input (RA, RB) to output (Qn) propagation delays and output transition times. Waveforms showing the write enable input (WE) and data input (Dn) to output (Qn) propagation delays, and the write enable pulse width. (1) HC : VM = 50%; VI = GND to VCC. HCT : VM = 1.3 V; VI = GND to 3 V. The shaded areas indicate when the input is permitted to change for predictable output performance. The time allowed for the internal output of the latch to assume the state of the new data (tlatch) is important only when attempting to read from a location immediately after that location has received new data. This parameter is measured from the falling edge of WE to the rising edge of RA or RB, RE must be LOW. Fig.8 Waveforms showing the write address input (WA, WB) and data input (Dn) to write enable (WE) set-up, hold and latch times. December 1990 8 Philips Semiconductors Product specification 4 x 4 register file; 3-state (1) 74HC/HCT670 HC : VM = 50%; VI = GND to VCC. HCT : VM = 1.3 V; VI = GND to 3 V. Fig.9 Waveforms showing the read enable (RE) to output (Qn) enable and disable times, and the read enable pulse width. PACKAGE OUTLINES See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. December 1990 9
74HCT670D,652
物料型号:74HC/HCT670
器件简介:74HC/HCT670是一款高速硅门CMOS设备,与低功耗肖特基TTL (LSTTL) 引脚兼容。符合JEDEC标准7A的规范。
引脚分配: - RA, RB:读地址输入 - D0到D3:数据输入 - WA, WB:写地址输入 - RE:3态输出读使能输入(低电平有效) - WE:写使能输入(低电平有效) - Q0到Q3:数据输出 - Vcc:正电源电压 - GND:地(0V)
参数特性: - 传播延迟:HC型为23ns,HCT型为23ns - 输入电容:3.5pF - 每个封装的功耗电容:HC型为122pF,HCT型为124pF
功能详解: - 可同时进行独立的读写操作 - 可扩展到几乎所有的字长和位长 - 输出能力:总线驱动器 - ICC类别:MSI
应用信息:74HC/HCT670适用于需要高速数据存储和读取的应用,例如在数字系统中作为寄存器文件使用。
封装信息:文档末尾提供了封装轮廓的参考信息,具体详情需查阅“74HC/HCT/HCU/HCMOS Logic Package Outlines”。
74HCT670D,652 价格&库存
很抱歉,暂时无法提供与“74HCT670D,652”相匹配的价格&库存,您可以联系我们找货
