74LV139D,112
74LV139D,112
    NEXPERIA(安世)
    n/a
74LV139D,112 数据手册
74LV139 Dual 2-to-4 line decoder/demultiplexer Rev. 04 — 13 December 2007 Product data sheet 1. General description The 74LV139 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC139 and 74HCT139. The 74LV139 is a dual 2-to-4 line decoder/demultiplexer. It has two independent decoders, each accepting two binary weighted inputs (nA0 and nA1) and providing four mutually exclusive outputs (nY0 to nY3) that are LOW when selected. Each decoder has an active LOW input (nE). When nE is HIGH, every output is forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. 2. Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 °C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 °C Demultiplexing capability Two independent 2-to-4 line decoders Multifunction capability Active LOW mutually exclusive outputs ESD protection: ◆ HBM JESD22-A114E exceeds 2000 V ◆ MM JESD22-A115-A exceeds 200 V Multiple package options Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV139N −40 °C to +125 °C DIP16 plastic dual in-line package; 16 leads (300 mil) SOT38-4 74LV139D −40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer Table 1. Ordering information …continued Type number Package Temperature range Name Description Version 74LV139DB −40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LV139PW −40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LV139BQ −40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm SOT763-1 4. Functional diagram 1 1E 1Y0 2 3 1A0 1Y1 1A1 1Y2 1Y3 2Y0 14 13 2A0 2Y1 2A1 2Y2 2Y3 4 DX 0 0 1 G 3 1 2 2 5 0 3 6 1 3 7 5 6 7 2 3 1 X/Y 0 1 1 2 2 EN 3 4 5 6 7 12 11 DX 0 0 1 G 3 1 2 14 10 0 13 9 15 2E 15 4 3 12 11 10 9 (a) mna779 14 13 15 X/Y 0 1 1 2 2 EN 3 (b) 12 11 10 9 mna781 a) demultiplexer b) decoder Fig 1. Logic symbol Fig 2. IEC logic symbol 2 1A0 3 1A1 1 1E 14 2A0 13 2A1 DECODER 1Y0 4 1Y1 5 1Y2 6 1Y3 7 2Y0 12 2Y1 11 DECODER 2Y2 10 2Y3 15 9 2E mna780 Fig 3. Functional diagram 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 2 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 5. Pinning information 5.1 Pinning 1E terminal 1 index area 16 VCC 74LV139 1 16 VCC 1A0 2 15 2E 1A0 2 15 2E 1A1 3 14 2A0 1A1 3 14 2A0 1Y0 4 13 2A1 1Y0 4 13 2A1 1Y1 5 12 2Y0 1Y2 6 1Y3 7 1 1E 1Y2 6 11 2Y1 1Y3 7 10 2Y2 GND 8 9 2Y3 VCC(1) 11 2Y1 10 2Y2 9 12 2Y0 2Y3 5 8 1Y1 GND 139 001aah107 Transparent top view 001aad029 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration DIP16, SO16 and (T)SSOP16 Fig 5. Pin configuration DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1E 1 enable input (active LOW) 1A0 2 address input 1A1 3 address input 1Y0 4 output 1Y1 5 output 1Y2 6 output 1Y3 7 output GND 8 ground (0 V) 2Y3 9 output 2Y2 10 output 2Y1 11 output 2Y0 12 output 2A0 14 address input 2A1 13 address input 2E 15 enable input (active LOW) VCC 16 supply voltage 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 3 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care Input Output nE nA0 nA1 H X X L L L L H L L L L H nY0 nY1 nY2 nY3 H H H H L H H H H L H H H H H L H H H H H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +7.0 V - ±20 mA - ±50 mA - ±25 mA input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current VO = −0.5 V to (VCC + 0.5 V) ICC supply current - 50 mA IGND ground current −50 - mA Tstg storage temperature −65 +150 °C Ptot total power dissipation IIK [1] Tamb = −40 °C to +125 °C DIP16 package [2] - 750 mW SO16 package [3] - 500 mW (T)SSOP16 package [4] - 500 mW DHVQFN16 package [5] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 12 mW/K above 70 °C. [3] Ptot derates linearly with 8 mW/K above 70 °C. [4] Ptot derates linearly with 5.5 mW/K above 60 °C. [5] Ptot derates linearly with 4.5 mW/K above 60 °C. 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 4 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions [1] Min Typ Max Unit 1.0 3.3 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage Conditions −40 °C to +85 °C Min Max Min Max VCC = 1.2 V 0.9 - - 0.9 - V VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VI = VIH or VIL IO = −100 µA; VCC = 1.2 V - 1.2 - - - V IO = −100 µA; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = −100 µA; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = −100 µA; VCC = 3.0 V 2.8 3.0 - 2.8 - V IO = −100 µA; VCC = 4.5 V 4.3 4.5 - 4.3 - V IO = −6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V IO = −12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V 74LV139_4 Product data sheet −40 °C to +125 °C Unit Typ[1] © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 5 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL −40 °C to +85 °C Conditions LOW-level output voltage Min Typ[1] −40 °C to +125 °C Unit Max Min Max VI = VIH or VIL IO = 100 µA; VCC = 1.2 V - 0 - - - V IO = 100 µA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 160 µA ∆ICC additional supply current per input; VI = VCC − 0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 µA CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 °C. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 8. Symbol Parameter tpd propagation delay −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.2 V - 70 - - - ns VCC = 2.0 V - 24 31 - 39 ns VCC = 2.7 V - 18 23 - 29 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 11 - - - ns VCC = 3.0 V to 3.6 V [3] - 13 18 - 23 ns - - 15 - 19 ns VCC = 1.2 V - 60 - - - ns VCC = 2.0 V - 20 27 - 34 ns nAn to nYn; see Figure 6 [2] VCC = 4.5 V to 5.5 V nEn to Yn; see Figure 7 VCC = 2.7 V - 15 20 - 25 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 10 - - - ns VCC = 3.0 V to 3.6 V [3] - 11 16 - 20 ns - - 13 - 16 ns VCC = 4.5 V to 5.5 V 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 6 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 8. Symbol Parameter CPD −40 °C to +85 °C Conditions power dissipation capacitance [4] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at Tamb = 25 °C. [2] tpd is the same as tPLH and tPHL. [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V). [4] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching Σ(CL × VCC2 × fo) = sum of the outputs. −40 °C to +125 °C Min Typ[1] Max Min Max - 42 - - - Unit pF 11. Waveforms VI VI VM nAn input GND GND t PHL t PLH tPLH tPHL VOH VOH VM nYn output VM nE input VM nYn output VOL VOL mna782 Measurement points are given in Table 8. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Input (nAn) to output (nYn) propagation delays Table 8. mna783 Fig 7. Enable input (nE) to output (nYn) propagation delays Measurement points Supply voltage Input Output VCC VM VM < 2.7 V 0.5VCC 0.5VCC 2.7 V to 3.6 V 1.5 V 1.5 V ≥ 4.5 V 0.5VCC 0.5VCC 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 7 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer VCC PULSE GENERATOR VI VO D.U.T. RT CL 50 pF RL 1 kΩ 001aaa663 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. Fig 8. Load circuit for switching times Table 9. Test data Supply voltage Input VCC VI tr, tf < 2.7 V VCC ≤ 2.5 ns 2.7 V to 3.6 V 2.7 V ≤ 2.5 ns ≥ 4.5 V VCC ≤ 2.5 ns 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 8 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 12. Package outline DIP16: plastic dual in-line package; 16 leads (300 mil) SOT38-4 ME seating plane D A2 A A1 L c e Z w M b1 (e 1) b b2 MH 9 16 pin 1 index E 1 8 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 b2 c D (1) E (1) e e1 L ME MH w Z (1) max. mm 4.2 0.51 3.2 1.73 1.30 0.53 0.38 1.25 0.85 0.36 0.23 19.50 18.55 6.48 6.20 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 0.76 inches 0.17 0.02 0.13 0.068 0.051 0.021 0.015 0.049 0.033 0.014 0.009 0.77 0.73 0.26 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.03 Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 95-01-14 03-02-13 SOT38-4 Fig 9. Package outline SOT38-4 (DIP16) 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 9 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 10. Package outline SOT109-1 (SO16) 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 10 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8 o 0 o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA MO-150 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 11. Package outline SOT338-1 (SSOP16) 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 11 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA MO-153 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Fig 12. Package outline SOT403-1 (TSSOP16) 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 12 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 13. Package outline SOT763-1 (DHVQFN16) 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 13 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV139_4 20071213 Product data sheet - 74LV139_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Section 3: DHVQFN16 package added. Section 7: derating values added for DHVQFN16 package. Section 12: outline drawing added for DHVQFN16 package. 74LV139_3 20030313 Product specification - 74LV139_2 74LV139_2 19980428 Product specification - 74LV139_1 74LV139_1 19970212 Product specification - - 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 14 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For additional information, please visit: http://www.nxp.com For sales office addresses, send an email to: salesaddresses@nxp.com 74LV139_4 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 04 — 13 December 2007 15 of 16 74LV139 NXP Semiconductors Dual 2-to-4 line decoder/demultiplexer 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2007. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 13 December 2007 Document identifier: 74LV139_4
74LV139D,112 价格&库存
很抱歉,暂时无法提供与“74LV139D,112”相匹配的价格&库存,您可以联系我们找货
