BAS70LSYL
BAS70LSYL
    NEXPERIA(安世)
    SOD-882
    BAS70LSYL
BAS70LSYL 数据手册
BAS70LS General-purpose Schottky diode 25 January 2021 Product data sheet 1. General description General-purpose Schottky diode in a leadless ultra small DFN1006BD-2 (SOD882BD) SurfaceMounted Device (SMD) plastic package with side-wettable flanks. 2. Features and benefits • • • • • High switching speed High breakdown voltage Low leakage current Low capacitance Suitable for Automatic Optical Inspection (AOI) of solder joint 3. Applications • • Ultra high-speed switching Voltage clamping 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tamb = 25 °C - - 70 mA VR reverse voltage - - 70 V VF forward voltage - - 410 mV IF = 1 mA; tp ≤ 300 µs; δ ≤ 0.02; pulsed; Tamb = 25 °C 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode 2 A anode Simplified outline Graphic symbol K 1 2 Transparent top view DFN1006BD-2 (SOD882BD) sym001 A BAS70LS Nexperia General-purpose Schottky diode 6. Ordering information Table 3. Ordering information Type number Package Name BAS70LS Description Version DFN1006BD-2 Leadless ultra small plastic package with side-wettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD 7. Marking Table 4. Marking codes Type number Marking code BAS70LS 8K 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage IF forward current Tamb = 25 °C - 70 V - 70 mA IFRM repetitive peak forward current tp ≤ 1 s; δ ≤ 0.5; Tamb = 25 °C - 70 mA IFSM non-repetitive peak forward current square-wave pulse; tp ≤ 10 ms; Tj(init) = 25 °C - 100 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 345 mW [2] - 640 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided 70 μm copper, tin-plated and standard footprint. 2 Device mounted on an FR4 Printed-Circuit Board (PCB), 70 μm single-sided copper, tin-plated; mounting pad for collector 1cm . BAS70LS Product data sheet All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 2 / 10 BAS70LS Nexperia General-purpose Schottky diode 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) [1] [2] [3] Conditions thermal resistance from in free air junction to ambient Min Typ Max Unit [1] [2] - - 360 K/W [3] - - 195 K/W Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided 70 μm copper, tin-plated and standard footprint. For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. 2 Device mounted on an FR4 Printed-Circuit Board (PCB), 70 μm single-sided copper, tin-plated; mounting pad for collector 1cm . aaa-031867 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.50 0.33 102 0.25 0.20 0.10 10 1 0.05 0.02 0.01 0 10-1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, 70 μm single sided copper standard footprint Fig. 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-031868 103 Zth(j-a) (K/W) 102 10 duty cycle = 1 0.75 0.50 0.33 0.25 0.20 0.10 0.02 1 0.05 0.01 0 10-1 10-5 10-4 10-3 10-2 10-1 1 FR4 PCB, 70 μm single sided copper, mounting pad for cathode 1 cm Fig. 2. 10 102 2 tp (s) 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BAS70LS Product data sheet All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 3 / 10 BAS70LS Nexperia General-purpose Schottky diode 10. Characteristics Table 7. Characteristics Symbol Parameter VF forward voltage IR reverse current Cd diode capacitance Conditions Min Typ Max Unit IF = 1 mA; tp ≤ 300 µs; δ ≤ 0.02; pulsed; Tamb = 25 °C - - 410 mV IF = 10 mA; tp ≤ 300 µs; δ ≤ 0.02; pulsed; Tamb = 25 °C - - 750 mV IF = 15 mA; tp ≤ 300 µs; δ ≤ 0.02; pulsed; Tamb = 25 °C - - 1 V VR = 50 V; Tj = 25 °C - - 100 nA VR = 70 V; Tj = 25 °C - - 10 µA VR = 0 V; f = 1 MHz; Tamb = 25 °C - - 2 pF mra803 102 mra805 102 IR (µA) IF (mA) (1) 10 10 (2) 1 1 10- 1 10- 1 10- 2 (1) 10- 2 0 (2) 0.2 (3) (4) 0.4 0.6 0.8 VF (V) 1 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = −40 °C Fig. 3. Product data sheet 10- 3 0 20 40 60 VR (V) 80 (1) Tj = 125 °C (2) Tj = 85 °C (3) Tj = 25 °C Forward current as a function of forward voltage; typical values BAS70LS (3) Fig. 4. Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 4 / 10 BAS70LS Nexperia General-purpose Schottky diode mra802 103 mra804 2 Cd (pF) rdif (Ω) 1.5 102 1 10 0.5 1 10- 1 1 10 IF (mA) 0 102 Differential forward resistance as a function of forward current; typical values BAS70LS Product data sheet 20 40 60 VR (V) 80 Tamb = 25 °C; f = 1 MHz f = 10 kHz Fig. 5. 0 Fig. 6. Diode capacitance as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 5 / 10 BAS70LS Nexperia General-purpose Schottky diode 11. Package outline DFN1006BD-2 Leadless ultra small plastic package with side-wettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD L (2x) T 1 2 b (2x) bf (2x) v w e C A B C y1 C A A1 C SEATING PLANE y C E A u C D (3) (3) (2) u C B 0 0.5 Dimensions A(1) A1 0.50 0.47 0.44 0.04 Unit mm max nom min 1 mm scale bf(1) b D E e L T(1) 0.55 0.30 0.22 0.50 0.60 1.00 0.65 0.25 0.16 0.20 0.45 0.22 0.10 u v 0.05 0.10 w y y1 0.05 0.05 0.05 Note 1. Dimension including plating thickness. 2. The marking bar indicates the cathode. 3. Solderable lead end, protrusion max. 0.02 mm. Outline version SOD882BD Fig. 7. sod882bd_po References IEC JEDEC JEITA European projection Issue date 20-06-22 20-06-23 MO-343AA Package outline DFN1006BD-2 (SOD882BD) BAS70LS Product data sheet All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 6 / 10 BAS70LS Nexperia General-purpose Schottky diode 12. Soldering Footprint information for reflow soldering of DFN1006BD-2 package SOD882BD 1.4 0.2 0.8 (2×) 0.6 (2×) 0.7 (2×) 0.3 0.4 1.0 1.3 solder resist solder paste solder lands Dimensions in mm Issue date Fig. 8. 20-05-01 20-12-15 sod882bd_fr Reflow soldering footprint for DFN1006BD-2 (SOD882BD) BAS70LS Product data sheet All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 7 / 10 BAS70LS Nexperia General-purpose Schottky diode 13. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BAS70LS v.1 Product data sheet - - BAS70LS Product data sheet 20210125 All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 8 / 10 BAS70LS Nexperia General-purpose Schottky diode 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BAS70LS Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 9 / 10 BAS70LS Nexperia General-purpose Schottky diode Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Package outline.......................................................... 6 12. Soldering..................................................................... 7 13. Revision history..........................................................8 14. Legal information........................................................9 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 January 2021 BAS70LS Product data sheet All information provided in this document is subject to legal disclaimers. 25 January 2021 © Nexperia B.V. 2021. All rights reserved 10 / 10
BAS70LSYL 价格&库存
很抱歉,暂时无法提供与“BAS70LSYL”相匹配的价格&库存,您可以联系我们找货
BAS70LSYL
    • 1000+0.48046
    • 10000+0.40038
    • 100000+0.32031
    库存:78250
