HEF4017BP
HEF4017BP
    NEXPERIA(安世)
    IC, 4000 LOCMOS LOGIC
HEF4017BP 数据手册
HEF4017B 5-stage Johnson decade counter Rev. 8 — 18 November 2011 Product data sheet 1. General description The HEF4017B is a 5-stage Johnson decade counter with ten spike-free decoded active HIGH outputs (Q0 to Q9), an active LOW carry output from the most significant flip-flop (Q5-9), active HIGH and active LOW clock inputs (CP0, CP1) and an overriding asynchronous master reset input (MR). The counter is advanced by either a LOW-to-HIGH transition at CP0 while CP1 is LOW or a HIGH-to-LOW transition at CP1 while CP0 is HIGH (see Table 3). When cascading counters, the Q5-9 output, which is LOW while the counter is in states 5, 6, 7, 8, and 9, can be used to drive the CP0 input of the next counter. A HIGH on MR resets the counter to zero (Q0 = Q5-9 = HIGH; Q1 to Q9 = LOW) independent of the clock inputs (CP0, CP1). Automatic counter code correction is provided by an internal circuit: following any illegal code the counter returns to a proper counting mode within 11 clock pulses. Schmitt trigger action makes the clock inputs highly tolerant of slower rise and fall times. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits        Automatic counter correction Tolerant of slow clock rise and fall times Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C Type number Package Name Description Version HEF4017BP DIP16 plastic dual in-line package; 16 leads (300 mil) SOT38-4 HEF4017BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 4. Functional diagram 13 14 15 CP1 CP0 5-STAGE JOHNSON COUNTER MR Q5-9 DECODING AND OUTPUT CIRCUITRY 12 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9 3 Fig 1. 2 4 7 10 1 5 6 9 11 001aah242 Q FF 4 CP Q RD D Functional diagram Q FF 1 CP Q RD Q FF 2 CP Q RD D CP1 CP0 Q FF 3 CP Q RD D D Q FF 5 CP Q RD D MR Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q5-9 001aah243 Fig 2. Logic diagram HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 2 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter CTRDIV10/DEC 14 13 14 CP1 CP0 15 MR 3 Q1 2 Q2 4 Q3 7 3 Q4 10 4 Q5 1 5 Q6 5 6 Q7 6 7 Q8 9 8 Q9 11 9 Q5-9 12 CT≥5 13 15 & 1 CT = 0 2 3 2 4 7 10 1 5 6 9 11 12 001aah240 001aah239 Fig 3. 0 Q0 Logic symbol Fig 4. IEE logic symbol 5. Pinning information 5.1 Pinning HEF4017B Q5 1 16 VDD Q1 2 15 MR Q0 3 14 CP0 Q2 4 13 CP1 Q6 5 12 Q5-9 Q7 6 11 Q9 Q3 7 10 Q4 VSS 8 9 Q8 001aae574 Fig 5. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description Q0 to Q9 3, 2, 4, 7, 10, 1, 5, 6, 9, 11 decoded output VSS 8 ground supply voltage Q5-9 12 carry output (active LOW) CP1 13 clock input (HIGH-to-LOW edge-triggered) HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 3 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Table 2. Pin description …continued Symbol Pin Description CP0 14 clock input (LOW-to-HIGH edge-triggered) MR 15 master reset input VDD 16 supply voltage 6. Functional description Table 3. Function table [1] MR CP0 CP1 Operation H X X Q0 = Q5-9 = H; Q1 to Q9 = L L H  counter advances L  L counter advances L L X no change L X H no change L H  no change L  L no change [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = positive-going transition;  = negative-going transition. HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 4 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter CP0 INPUT CP1 INPUT MR INPUT Q0 OUTPUT Q1 OUTPUT Q2 OUTPUT Q3 OUTPUT Q4 OUTPUT Q5 OUTPUT Q6 OUTPUT Q7 OUTPUT Q8 OUTPUT Q9 OUTPUT Q5-9 OUTPUT Fig 6. 001aah244 Timing diagram 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current HEF4017B Product data sheet Conditions VI < 0.5 V or VI > VDD + 0.5 V VO < 0.5 V or VO > VDD + 0.5 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 Min Max Unit 0.5 +18 V - 10 mA 0.5 VDD + 0.5 V - 10 mA - 10 mA © NXP B.V. 2011. All rights reserved. 5 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IDD Min Max Unit supply current - 50 mA Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C Ptot total power dissipation P Conditions Tamb = 40 C to +125 C power dissipation DIP16 package [1] - 750 mW SO16 package [2] - 500 mW - 100 mW per output [1] For DIP16 package: Ptot derates linearly with 12 mW/K above 70 C. [2] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VDD supply voltage Min Typ Max Unit 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VDD = 5 V - - 3.75 s/V VDD = 10 V - - 0.5 s/V VDD = 15 V - - 0.08 s/V 9. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage Conditions IO < 1 A IO < 1 A HIGH-level IO < 1 A; output voltage VI = VSS or VDD LOW-level IO < 1 A; output voltage VI = VSS or VDD HEF4017B Product data sheet Tamb = 40 C VDD 5V Tamb = 25 C Tamb = 85 C Tamb = 125 C Unit Min Max Min Max Min Max Min Max 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 6 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Table 6. Static characteristics …continued VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter IOH IOL Conditions Tamb = 25 C Tamb = 85 C Tamb = 125 C Unit Min Max Min Max Min Max Min Max HIGH-level VO = 2.5 V output current V = 4.6 V O 5V - 1.7 - 1.4 - 1.1 - 1.1 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA mA LOW-level VO = 0.4 V output current V = 0.5 V O 5V 0.64 - 0.5 - 0.36 - 0.36 - mA 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA 15 V - 0.1 - 0.1 - 1.0 - 1.0 A II input leakage current IDD supply current IO = 0 A; VI = VSS or VDD CI Tamb = 40 C VDD input capacitance 5V - 5 - 5 - 150 - 150 A 10 V - 10 - 10 - 300 - 300 A 15 V - 20 - 20 - 600 - 600 A - - - - 7.5 - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 C; VSS = 0 V; for test circuit see Figure 10 Symbol Parameter tPHL HIGH to LOW propagation delay Conditions MR  Q1 to Q9; see Figure 8 Product data sheet Min Typ Max Unit 113 ns + (0.55 ns/pF)CL - 140 280 ns 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 118 ns + (0.55 ns/pF)CL - 145 290 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns CP0, CP1  Q0 to Q9; 5 V see Figure 7 10 V CP0, CP1  Q5-9; see Figure 7 HEF4017B Extrapolation formula[1] VDD 5V 88 ns + (0.55 ns/pF)CL - 115 230 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 27 ns + (0.16 ns/pF)CL - 35 70 ns All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 7 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Table 7. Dynamic characteristics …continued Tamb = 25 C; VSS = 0 V; for test circuit see Figure 10 Symbol Parameter Conditions tPLH CP0, CP1  Q0 to Q9; 5 V see Figure 7 10 V LOW to HIGH propagation delay CP0, CP1  Q5-9; see Figure 7 MR  Q5-9; see Figure 8 MR  Q0; see Figure 8 transition time tt hold time th see Figure 7 CP0  CP1; see Figure 9 CP1  CP0; see Figure 9 pulse width tW CP0 input LOW; minimum width; see Figure 8 CP1 input HIGH; minimum width; see Figure 8 MR input HIGH; minimum width; see Figure 8 recovery time trec maximum frequency fmax MR input; see Figure 8 see Figure 8 Extrapolation formula[1] VDD Min Typ Max Unit 98 ns + (0.55 ns/pF)CL - 125 250 ns 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 98 ns + (0.55 ns/pF)CL - 125 250 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 83 ns + (0.55 ns/pF)CL - 110 220 ns 10 V 34 ns + (0.23 ns/pF)CL - 45 90 ns 15 V 27 ns + (0.16 ns/pF)CL - 35 70 ns 5V 103 ns + (0.55 ns/pF)CL - 130 260 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 105 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 75 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL 5V [2] - 20 40 ns 5V 90 45 - ns 10 V 40 20 - ns 15 V 20 10 - ns 5V 80 40 - ns 10 V 40 20 - ns 15 V 30 10 - ns 5V 80 40 - ns 10 V 40 20 - ns 15 V 30 15 - ns 5V 80 40 - ns 10 V 40 20 - ns 15 V 30 15 - ns 5V 50 25 - ns 10 V 30 15 - ns 15 V 20 10 - ns 5V 60 30 - ns 10 V 30 15 - ns 15 V 20 10 - ns 5V 6 12 - MHz 10 V 12 30 - MHz 15 V 15 30 - MHz [1] The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). [2] tt is the same as tTHL and tTLH. HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 8 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (W) PD = 500  fi + (fo  CL)  VDD 5V where: 2 fi = input frequency in MHz; 10 V PD = 2200  fi + (fo  CL)  VDD2 fo = output frequency in MHz; 15 V PD = 6000  fi + (fo  CL)  VDD CL = output load capacitance in pF; 2 VDD = supply voltage in V; (CL  fo) = sum of the outputs. 11. Waveforms VI CP0 input VM VSS VI CP1 input VM VSS tPHL tPLH VOH Q1 - Q9 output VM VOL tPLH tPHL VOH Q0, Q5 - Q9 output VOL VM tTLH tTHL 001aaj305 Conditions: CP1 = LOW, while CP0 triggers on a LOW-to-HIGH transition. CP1 triggers on a HIGH-to-LOW transition; The shaded areas indicate where the output state is set by the input count. Measurement points given in Table 9. Fig 7. Waveforms showing the propagation delays for CP0, CP1 to Qn, Q5-9 outputs and the output transition times HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 9 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 1/f max tW VI CP0 input VM VSS 1/f max VI CP1 input VM VSS tW trec VI MR input VM VSS tW VOH Q1 - Q9 output VM VOL tPHL VOH Q0, Q5 - Q9 output VOL VM 001aaj306 tPLH Conditions: CP1 = LOW, while CP0 triggers on a LOW-to-HIGH transition, tW and trec are measured when CP0 = HIGH and CP1 triggers on a HIGH-to-LOW transition. The shaded areas indicate where the output state is set by the input count. Measurement points given in Table 9. Fig 8. Waveforms showing the minimum pulse width for CP0, CP1 and MR input; the maximum frequency for CP0 and CP1 input; the recovery time for MR and the MR input to Qn and Q5-9 output propagation delays VI CP0 input VM VSS VM th th VI CP1 input VM VM VSS 001aae578 Hold times are shown as positive values, but may be specified as negative values; Measurement points given in Table 9. Fig 9. Waveforms showing hold times for CP0 to CP1 and CP1 to CP0 Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 10 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter tW VI 90 % 90 % negative pulse VM VM 10 % 0V 10 % tf tr tr tf VI 90 % positive pulse 90 % VM VM 10 % 0V 10 % tW 001aaj781 a. Input waveforms VDD VI VO G DUT CL RT 001aag182 b. Test circuit Test data is given in Table 10. Definitions for test circuit: DUT = Device Under Test; CL = load capacitance including jig and probe capacitance; RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 10. Test circuit for measuring switching times Table 10. Test data Supply voltage Input Load VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF 12. Application information Some examples of applications for the HEF4017B are: • • • • Decade counter with decimal decoding 1 out of n decoding counter (when cascaded) Sequential controller Timer Figure 11 shows a technique for extending the number of decoded output states for the HEF4017B. Decoded outputs are sequential within each stage and from stage to stage, with no dead time (except propagation delay). HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 11 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter CP0 MR CP0 HEF4017B CP1 Q0 Q1- - - - Q8 Q9 clock MR HEF4017B CP1 Q0 Q1- - - - Q8 Q9 CP0 MR HEF4017B CP1 Q1 - - - - - - Q8 Q9 9 decoded outputs 8 decoded outputs 8 decoded outputs first stage intermediate stages last stage 001aae577 Enabling the counter on CP1 when CP0 is HIGH, or on CP0 when CP1 is LOW, causes an extra count. Fig 11. Counter expansion HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 12 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 13. Package outline DIP16: plastic dual in-line package; 16 leads (300 mil) SOT38-4 ME seating plane D A2 A A1 L c e Z w M b1 (e 1) b b2 MH 9 16 pin 1 index E 1 8 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 b2 c D (1) E (1) e e1 L ME MH w Z (1) max. mm 4.2 0.51 3.2 1.73 1.30 0.53 0.38 1.25 0.85 0.36 0.23 19.50 18.55 6.48 6.20 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 0.76 inches 0.17 0.02 0.13 0.068 0.051 0.021 0.015 0.049 0.033 0.014 0.009 0.77 0.73 0.26 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.03 Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 95-01-14 03-02-13 SOT38-4 Fig 12. Package outline SOT38-4 (DIP16) HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 13 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 13. Package outline SOT109-1 (SO16) HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 14 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4017B v.8 20111118 Product data sheet - HEF4017B v.7 Modifications: • • • Legal pages updated. Changes in “General description” and “Features and benefits”. Section “Applications” removed. HEF4017B v.7 20110914 Product data sheet - HEF4017B v.6 HEF4017B v.6 20091105 Product data sheet - HEF4017B v.5 HEF4017B v.5 20090709 Product data sheet - HEF4017B v.4 HEF4017B v.4 20081209 Product data sheet - HEF4017B_CNV v.3 HEF4017B_CNV v.3 19950101 Product specification - HEF4017B_CNV v.2 HEF4017B_CNV v.2 19950101 Product specification - - HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 15 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 16 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com HEF4017B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 November 2011 © NXP B.V. 2011. All rights reserved. 17 of 18 HEF4017B NXP Semiconductors 5-stage Johnson decade counter 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Application information. . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2011. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 18 November 2011 Document identifier: HEF4017B
HEF4017BP 价格&库存
很抱歉,暂时无法提供与“HEF4017BP”相匹配的价格&库存,您可以联系我们找货
