INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT640
Octal bus transceiver; 3-state;
inverting
Product specification
File under Integrated Circuits, IC06
March 1988
Philips Semiconductors
Octal bus transceiver; 3-state; inverting
74HC/HCT640
FEATURES
GENERAL DESCRIPTION
• Octal bidirectional bus interface
The 74HC/HCT640 are high-speed Si-gate CMOS devices
and are pin compatible with low power Schottky TTL
(LSTTL). They are specified in compliance with JEDEC
standard no. 7A.
• Inverting 3-state outputs
• Output capability: bus driver
• ICC category: MSI
The 74HC/HCT640 are octal transceivers featuring
inverting 3-state bus compatible outputs in both send and
receive directions.
The “640” features an output enable (OE) input for easy
cascading and a send/receive (DIR) for direction control.
OE controls the outputs so that the buses are effectively
isolated. The “640” is similar to the “245” but has inverting
outputs.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
UNIT
HC
tPHL/ tPLH
propagation delay
An to Bn;
Bn to An
CI
CI/O
CPD
power dissipation capacitance
per transceiver
CL = 15 pF; VCC = 5 V
9
9
ns
input capacitance
3.5
3.5
pF
input/output capacitance
10
10
pF
35
35
pF
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
March 1988
HCT
2
74HC/HCT640
PIN DESCRIPTION
PIN NO.
SYMBOL NAME AND FUNCTION
1
DIR
direction control
2, 3, 4, 5, 6, 7, 8, 9
A0 to A7
data inputs/outputs
10
GND
ground (0 V)
18, 17, 16, 15, 14, 13, 12, 11 B0 to B7
data inputs/outputs
19
OE
output enable input (active LOW)
VCC
positive supply voltage
Fig.1 Pin configuration.
Fig.2 Logic symbol.
FUNCTION TABLE
inputs
OE
DIR
L
L
H
L
H
X
inputs/outputs
An
Bn
A=B
inputs
Z
inputs
B=A
Z
Note
1. H
L
X
Z
= HIGH voltage level
= LOW voltage level
= don’t care
= high impedance OFF-state
Fig.3 IEC logic symbol.
March 1988
Fig.4 Functional diagram.
3
74HC/HCT640
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL
PARAMETER
−40 to +85
+25
−40 to +125
min. typ. max. min. max. min.
UNIT V
CC
WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
An to Bn;
Bn to An
30
11
9
90
18
15
115
23
27
23
ns
2.0
4.5
6.0
Fig.5
tPZH/ tPZL
3-state output enable time
OE, DIR to An;
OE, DIR to Bn
44
16
13
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig.6
tPHZ/ tPLZ
3-state output disable time
OE, DIR to An;
OE, DIR to Bn
50
18
14
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig.6
tTHL/ tTLH
output transition time
14
5
4
60
12
10
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.5
March 1988
4
74HC/HCT640
DC CHARACTERISTICS FOR 74HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
An
Bn
OE
DIR
1.50
1.50
1.50
0.90
AC CHARACTERISTICS FOR 74HCT
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL
PARAMETER
−40 to +85
+25
−40 to +125
UNIT V
CC
WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
An to Bn;
Bn to An
11
22
28
33
ns
4.5
Fig.5
tPZH/ tPZL
OE, DIR to An;
OE, DIR to Bn
18
30
38
45
ns
4.5
Fig.6
tPHZ/ tPLZ
OE, DIR to An;
OE, DIR to Bn
19
30
38
45
ns
4.5
Fig.6
tTHL/ tTLH
5
12
15
18
ns
4.5
Fig.5
March 1988
5
74HC/HCT640
AC WAVEFORMS
(1)
(1)
HC : VM = 50%; VI = GND to VCC.
HCT: VM = 1.3 V; VI = GND to 3 V.
Fig.5
Fig.6
Waveforms showing the input (An, Bn) to
output (Bn, An) propagation delays and the
output transition times.
Waveforms showing the 3-state enable and
disable times.
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
March 1988
6
74HC/HCT640 Packaging Information
Type Number
74HC640N
74HC640D
74HC640DB
74HCT640N
74HCT640D
74HCT640D
74HCT640DB
74HCT640DB
Orderable Part Number
74HC640N
74HC640D,652
74HC640DB
74HCT640N,652
74HCT640D,653
74HCT640D,652
74HCT640DB,118
74HCT640DB,112
Package Name
DIP20
SO20
SSOP20
DIP20
SO20
SO20
SSOP20
SSOP20
很抱歉,暂时无法提供与“74HC640D,652”相匹配的价格&库存,您可以联系我们找货
