BZX58550-Q series
Low-current voltage regulator diodes
Rev. 1 — 24 August 2021
Product data sheet
1. General description
Low-current voltage regulator diodes in an SOD523 (SC-79) ultra small and flat lead SurfaceMounted Device (SMD) plastic package.
2. Features and benefits
Total power dissipation: ≤ 300 mW
Tolerance series: approximately ± 5 %
Working voltage range: nominal 1.8 V to 75 V
Specified at a low test current (50 μA), ideal for low bias and portable battery-powered
applications
Qualified according to AEC-Q101 and recommended for use in automotive applications
3. Applications
Low-current general regulation functions
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Typ
Max
Unit
VF
forward voltage
IF = 10 mA
[1] -
0.9
V
Ptot
total power dissipation
Tamb ≤ 25 °C
[2] -
300
mW
[1]
[2]
Min
Pulse test: tp ≤ 300 μs; δ ≤ 0.02
2
Device mounted on an FR4 Printed-Circuit Board (PCB), with approximately 35 mm Cu area at cathode tab.
5. Pinning information
Table 2. Pinning
Pin
Symbol
1
2
[1]
K
A
Description
cathode
[1]
anode
The marking bar indicates the cathode.
Simplified outline
1
Graphic symbol
2
K
A
006aaa152
BZX58550-Q series
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
BZX58550-Q series
Name
Description
Version
SC-79
plastic surface-mounted package; 2 leads
SOD523
7. Marking
Table 4. Marking Codes
Type number
Marking Type number
Code
BZX58550-C1V8-Q 1C
BZX58550-C2V0-Q 1E
BZX58550-C2V2-Q 1F
BZX58550-C2V4-Q 1H
BZX58550-C2V7-Q 1K
BZX58550-C3V0-Q 1L
BZX58550-C3V3-Q 1N
BZX58550-C3V6-Q 1S
BZX58550-C3V9-Q 1T
BZX58550-C4V3-Q 1U
BZX58550-Q_SER
Product data sheet
Marking Type number
Code
BZX58550-C4V7-Q 1X
BZX58550-C5V1-Q 1Y
BZX58550-C5V6-Q 1Z
BZX58550-C6V2-Q 2C
BZX58550-C6V8-Q 2E
BZX58550-C7V5-Q 2F
BZX58550-C8V2-Q 2H
BZX58550-C12-Q
BZX58550-C13-Q
BZX58550-C15-Q
BZX58550-C16-Q
BZX58550-C18-Q
BZX58550-C20-Q
BZX58550-C22-Q
BZX58550-C9V1-Q 2K
BZX58550-C24-Q
BZX58550-C10-Q
BZX58550-C27-Q
BZX58550-C11-Q
2L
2N
BZX58550-C30-Q
All information provided in this document is subject to legal disclaimers.
Marking Type number
Code
Marking
Code
2S
3L
2T
2U
2X
2Y
3C
3E
3F
3H
3K
BZX58550-C33-Q
BZX58550-C36-Q
BZX58550-C39-Q
BZX58550-C43-Q
BZX58550-C47-Q
BZX58550-C51-Q
BZX58550-C56-Q
BZX58550-C62-Q
BZX58550-C68-Q
BZX58550-C75-Q
3N
3S
3T
3U
3X
3Y
3Z
4C
4E
Nexperia B.V. 2021. All rights reserved
2 / 11
BZX58550-Q series
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
IF
forward current
200
mA
PZSM
non-repetitive peak reverse power
dissipation
tp = 100 µs; square wave;
Tj = 25 °C; prior to surge
40
W
Ptot
Tamb ≤ 25 °C
300
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Conditions
[1]
2
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from junction
to ambient
in free air
Rth(j-sp)
to solder point
[1]
[2]
Min
Typ
Max
Unit
[1]
350
K/W
[2]
65
K/W
2
Soldering point of cathode tab
BZX58550-Q_SER
Product data sheet
3 / 11
BZX58550-Q series
Nexperia
10. Characteristics
Table 7. Electrical characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
VF
forward voltage
IF = 10 mA
[1]
[1]
Max
Unit
0.9
V
Table 8. Electrical characteristics per type: BZX58550-C1V8-Q to BZX58550-C24-Q
BZX58550-C
Working voltage
VZ (V)
IZ = 50 µA
Min
Max
1V8-Q
1.71
2V0-Q
2V2-Q
Differential
resistance
rdiff (Ω)
IZ = 1 mA IZ = 5 mA
Reverse current
IR (µA)
Max
Max
Max
Min
7.5
VR (V)
1.0
1.89
600
100
1.88
2.12
600
2.09
2.31
600
100
7
100
4
2V4-Q
2.28
2.52
600
100
2V7-Q
2.565
2.835
600
3V0-Q
2.85
3.15
3V3-Q
3.13
3V6-Q
3.42
3V9-Q
Temperature
coefficient
SZ (mV/K)
IZ = 5 mA
Diode capacit.
Cd (pF)[1]
Max
Max
-3.5
1.0
-3.5
1.0
-3.5
2
1.0
-3.5
100
1
1.0
-3.5
600
100
0.8
1.0
-3.5
0.2
170
3.47
600
100
7.5
1.5
-3.5
1.2
160
3.78
600
95
7.5
2.0
-3.5
1.2
160
3.70
4.10
600
95
5.0
2.0
-2.7
2.5
150
4V3-Q
4.09
4.52
600
95
4.0
2.0
-2.7
2.5
150
4V7-Q
4.47
4.94
600
80
5.0
3.0
-2.7
2.5
140
5V1-Q
4.85
5.36
500
60
5.0
3.0
-2.0
3.7
130
5V6-Q
5.32
5.88
400
40
2.0
4.0
-2.0
3.7
120
6V2-Q
5.89
6.51
160
10
1.0
5.0
0.4
4.5
110
6V8-Q
6.46
7.14
80
15
0.1
5.1
1.2
4.5
100
7V5-Q
7.13
7.88
80
15
0.1
5.7
2.5
5.3
150
8V2-Q
7.79
8.61
80
15
0.1
6.2
3.2
6.2
150
9V1-Q
8.65
9.56
100
15
0.1
6.9
3.8
7.0
150
10-Q
9.50
10.50
150
7.6
4.5
8.0
90
11-Q
10.45
11.55
150
8.4
5.4
9.0
85
12-Q
11.40
12.60
150
25
0.05
9.1
6.0
10.0
85
13-Q
12.35
13.65
170
30
0.05
9.8
7.0
11.0
80
15-Q
14.25
15.75
200
30
0.05
11.4
9.2
13.0
75
16-Q
15.20
16.80
200
40
0.05
12.1
10.4
14.0
75
18-Q
17.10
18.90
225
45
0.05
13.6
12.4
16.0
70
20-Q
19.00
21.00
225
55
0.05
15.2
14.4
18.0
60
22-Q
20.90
23.10
250
55
0.05
16.7
16.4
20.0
60
24-Q
22.80
25.20
250
70
0.05
18.2
18.4
22.0
55
[1]
f = 1 MHz; VR = 0 V
BZX58550-Q_SER
Product data sheet
4 / 11
BZX58550-Q series
Nexperia
Table 9. Electrical characteristics per type: BZX58550-C27-Q to BZX58550-C75-Q
BZX58550-C
Working voltage
Differential
Reverse current Temperature
VZ (V)
resistance
IR (µA)
coefficient
rdiff (Ω)
SZ (mV/K)
IZ =
IZ = 2 mA
IZ = 50 µA
IZ = 2 mA
0.5 mA
Diode capacit.
Cd (pF)[1]
Min
Max
Max
Max
Max
Max
Max
25.65
28.35
300
80
0.05
VR (V)
20.4
Min
27-Q
21.4
25.3
50
30-Q
28.50
31.50
300
80
0.05
22.8
24.4
29.4
50
33-Q
31.35
34.65
325
80
0.05
25.0
27.4
33.4
45
36-Q
34.20
37.80
350
90
0.05
27.3
30.4
37.4
45
39-Q
37.05
40.95
350
130
0.05
29.6
33.4
41.2
45
43-Q
40.85
45.15
375
150
0.05
32.6
37.6
46.6
40
47-Q
44.00
50.00
375
170
0.05
32.9
42.0
51.8
40
51-Q
48.00
54.00
400
180
0.05
35.7
46.6
57.2
40
56-Q
52.00
60.00
425
200
0.05
39.2
52.2
63.8
40
62-Q
58.00
66.00
450
215
0.05
43.4
58.8
71.6
35
68-Q
64.00
72.00
475
240
0.05
47.6
65.6
79.8
35
75-Q
70.00
79.00
500
255
0.05
52.5
73.4
88.6
35
[1]
f = 1 MHz; VR = 0 V
aaa-028521
103
PZSM
(W)
aaa-033420
103
IF
(mA)
102
102
10
1
10-1
10
10-2
1
10-1
1
tp (ms)
10
10-3
0.4
Non-repetitive peak reverse power dissipation
as a function of pulse duration; maximum
values
BZX58550-Q_SER
Product data sheet
0.8
VF (V)
1.0
Tj = 25 °C
(1) Tj = 25 °C (before surge)
Fig. 1.
0.6
Fig. 2.
Forward current as a function of forward
voltage; typical values (BZX58550-C1V8-Q)
5 / 11
BZX58550-Q series
Nexperia
aaa-028551
103
IF
(mA)
102
10
10
1
1
10-1
10-1
10-2
10-2
10-3
0.4
0.6
0.8
VF (V)
1.0
10-3
0.4
Tj = 25 °C
Fig. 3.
aaa-028553
103
IF
(mA)
102
Fig. 4.
voltage; typical values (BZX58550-C7V5-Q)
aaa-033421
10-1
3V9
4V3
4V7
5V1
5V6
6V2
6V8
10-4
10-1
10-5
10-2
0.6
0.8
VF (V)
1.0
10-6
Tj = 25 °C
4
6
VR (V)
8
Tamb = 25 °C
voltage; typical values (BZX58550-C75-Q)
Product data sheet
1.0
VF (V)
BZX58550-C1V8
2V0
10-2
2V2
2V4
2V7
3V0
10-3
3V3
3V6
1
BZX58550-Q_SER
0.8
IR
(A)
10
Fig. 5.
0.6
Tj = 25 °C
voltage; typical values (BZX58550-C6V8-Q)
10-3
0.4
aaa-028552
103
IF
(mA)
102
Fig. 6.
Reverse current as a function of reverse
voltage; typical values (BZX58550-C1V8-Q to
BZX58550-C6V8-Q)
6 / 11
BZX58550-Q series
Nexperia
IR
(A)
aaa-006666
10-1
IR
(A)
7V5
10-2
10 12
15
18
22
8V2
10-3
aaa-006667
10-1
30 36
10-2
27
33
43
39
51
47
62
56
75
68
10-3
9V1
11 13
16
10-4
10-4
10-5
10-5
10-6
10-6
10-7
10-7
10-8
10-8
10
15
VR (V)
10-9
25
Tamb = 25 °C
Fig. 7.
60
VR (V)
80
Tamb = 25 °C
voltage; typical values (BZX58550-C7V5-Q to
BZX58550-C24-Q)
Fig. 8.
voltage; typical values (BZX58550-C27-Q to
BZX58550-C75-Q)
11. Test information
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
12. Package outline
0.85
0.75
0.65
0.58
1
1.65 1.25
1.55 1.15
2
0.34
0.26
0.17
0.11
Dimensions in mm
Fig. 9.
02-12-13
Package outline SOD523 (SC-79)
BZX58550-Q_SER
Product data sheet
7 / 11
BZX58550-Q series
Nexperia
13. Soldering
2.15
1.4
solder lands
solder resist
0.5 0.6
(2×) (2×)
1.2
solder paste
occupied area
Dimensions in mm
0.4
(2×)
0.5
(2×)
sod523_fr
Fig. 10. Reflow soldering footprint SOD523 (SC-79)
BZX58550-Q_SER
Product data sheet
8 / 11
BZX58550-Q series
Nexperia
14. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
BZX58550-Q_SER v.1
20210824
Product data sheet
BZX58550-Q_SER
Product data sheet
9 / 11
BZX58550-Q series
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
BZX58550-Q_SER
Product data sheet
10 / 11
BZX58550-Q series
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 4
11. Test information.......................................................... 7
12. Package outline.......................................................... 7
13. Soldering..................................................................... 8
14. Revision history..........................................................9
15. Legal information......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 August 2021
BZX58550-Q_SER
Product data sheet
11 / 11
很抱歉,暂时无法提供与“BZX58550-C16-QX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30208
- 100+0.24020
- 300+0.20920
- 3000+0.18598
- 国内价格 香港价格
- 3000+0.519043000+0.06706
- 6000+0.466476000+0.06027
- 9000+0.439679000+0.05681
- 15000+0.4095115000+0.05291
- 21000+0.3916521000+0.05060
- 30000+0.3742830000+0.04836
