BZX884S-B6V8YL
BZX884S-B6V8YL
    NEXPERIA(安世)
    Zener Diode Single 6.8V 2% 15Ohm 365mW Automotive 2-Pin DFN-BD T/R
BZX884S-B6V8YL 数据手册
BZX884S series Voltage regulator diodes Rev. 1 — 13 July 2020 Product data sheet 1. General description General-purpose Zener diodes in an ultra small SOD882BD (DFN1006BD-2) leadless SurfaceMounted Device (SMD) plastic package with side-wettable flanks. 2. Features and benefits • • • • Leadless ultra small plastic package with side-wettable flanks suitable for surfacemounteddesign Two tolerance series: ± 2 % and approximately ± 5 % Wide working voltage range: nominal 2.4 V to 6V8 (E24 range) AEC-Q101 qualified 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA Ptot total power dissipation [1] [2] Min Typ Max Unit [1] - - 0.9 V [2] - - 365 mW Pulse test: tp ≤ 100 μs; δ ≤ 0.02 Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 2 Graphic symbol 1 2 006aaa152 Transparent top view [1] The marking bar indicates the cathode. BZX884S series Nexperia Voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number Package BZX884S series [1] [1] Name Description Version DFN1006BD-2 Leadless ultra small plastic package with sidewettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD The series includes 12 breakdown voltages with nominal working voltages from 2.4 V to 6V8 and ±2 % and approximately ±5% tolerances. 7. Marking Table 4. Marking Codes Type number Mark. Code Type number Mark. Code BZX884S-B2V4 2A BZX884S-C2V4 4K BZX884S-B2V7 2B BZX884S-C2V7 4L BZX884S-B3V0 2C BZX884S-C3V0 4R BZX884S-B3V3 2D BZX884S-C3V3 4S BZX884S-B3V6 2E BZX884S-C3V6 4T BZX884S-B3V9 2F BZX884S-C3V9 4U BZX884S-B4V3 2G BZX884S-C4V3 4U BZX884S-B4V7 2H BZX884S-C4V7 4Y BZX884S-B5V1 2J BZX884S-C5V1 5B BZX884S-B5V6 2K BZX884S-C5V6 5C BZX884S-B6V2 2L BZX884S-C6V2 5F BZX884S-B6V8 N3 BZX884S-C6V8 5G BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 2 / 11 BZX884S series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current Ptot total power dissipation Tj Tamb Tstg [1] Conditions Min Max Unit - 200 mA - 365 mW junction temperature - 150 °C ambient temperature −55 +150 °C storage temperature −65 +150 °C Min Typ Max Unit - - 340 K/W Tamb = 25 °C [1] Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air [1] thermal resistance from junction to ambient [1] Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 10. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA [1] Min [1] - Typ Max Unit - 0.9 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02. BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 3 / 11 BZX884S series Nexperia Voltage regulator diodes Table 8. Characteristics per type; BZX884S-B2V4 to BZX884S-C6V8 Tj = 25 °C unless otherwise specified. BZX884S 2V4 2V7 3V0 3V3 3V6 3V9 4V3 4V7 5V1 5V6 6V2 6V8 [1] Sel Working voltage VZ (V) Differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K) Diode capacitance Cd (pF) [1] IZ = 5 mA IZ = 1 mA IZ = 5 mA Min Max Typ Max Typ Max Max VR (V) Min Max Max B 2.35 2.45 275 600 70 100 50 1.0 -3.5 0.0 450 C 2.20 2.60 B 2.65 2.75 300 600 75 100 20 1.0 -3.5 0.0 450 C 2.50 2.90 B 2.94 3.06 325 600 80 95 10 1.0 -3.5 0.0 450 C 2.80 3.20 B 3.23 3.37 350 600 85 95 5 1.0 -3.5 0.0 450 C 3.10 3.50 B 3.53 3.67 375 600 85 90 5 1.0 -3.5 0.0 450 C 3.40 3.80 B 3.82 3.98 400 600 85 90 3 1.0 -3.5 0.0 450 C 3.70 4.10 B 4.21 4.39 410 600 80 90 3 1.0 -3.5 0.0 450 C 4.00 4.60 B 4.61 4.79 425 500 50 80 3 2.0 -3.5 0.2 300 C 4.40 5.00 B 5.00 5.20 400 480 40 60 2 2.0 -2.7 1.2 300 C 4.80 5.40 B 5.49 5.71 80 400 15 40 1 2.0 -2.0 2.5 300 C 5.20 6.00 B 6.08 6.32 40 150 6 10 3 4.0 0.4 3.7 200 C 5.80 6.60 B 6.66 6.94 30 80 6 15 2 4.0 1.2 4.5 200 C 6.40 7.20 IZ = 5 mA f = 1 MHz; VR = 0 V BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 4 / 11 BZX884S series Nexperia Voltage regulator diodes aaa-028550 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 1.0 VF (V) 10-3 0.4 Tj = 25 °C Fig. 1. aaa-028551 103 IF (mA) 102 0.6 0.8 Tj = 25 °C Forward current as a function of forward voltage; typical values (BZX884S-B/C2V4) Fig. 2. mld444 0.5 SZ (mV/K) Forward current as a function of forward voltage; typical values (BZX884S-B/C6V8) aaa-031972 4 SZ (mV/K) 4V7 0 6V8 6V2 2 5V6 4V3 5V1 - 0.5 2V4 0 2V7 3V9 -1 3V6 - 1.5 -2 10- 1 -2 3V3 3V0 1 10 IZ (mA) -4 10-1 102 Tj = 25 °C to 150 °C Fig. 3. Product data sheet 1 10 IZ (mA) 102 Tj = 25 °C to 150 °C Temperature coefficient as a function of working current; typical values (BZX884S-B/C2V4 to B/C4V7) BZX884S_SER 1.0 VF (V) Fig. 4. Temperature coefficient as a function of working current; typical values (BZX884S-B/C5V1 to B/C6V8) All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 5 / 11 BZX884S series Nexperia Voltage regulator diodes IR (A) aaa-006665 10-1 2V4 10-2 2V7 10-3 3V0 3V3 3V6 3V9 4V3 4V7 5V1 10-4 10-5 5V6 10-6 6V2 6V8 10-7 10-8 10-9 0 2 4 6 VR (V) 8 Tj = 25 °C Fig. 5. Reverse current as a function of reverse voltage; typical values (BZX884S-B/C2V4 to BZX884S-B/C6V8) BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 6 / 11 BZX884S series Nexperia Voltage regulator diodes 11. Package outline DFN1006BD-2 Leadless ultra small plastic package with side-wettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD L (2x) T 1 2 b (2x) bf (2x) v w e C A B C y1 C A A1 C SEATING PLANE y C E A u C D (3) (3) (2) u C B 0 0.5 Dimensions A(1) A1 0.50 0.47 0.44 0.04 Unit max nom min mm 1 mm scale bf(1) b D E e L T(1) 0.55 0.30 0.22 0.50 0.60 1.00 0.65 0.25 0.16 0.20 0.45 0.22 0.10 u v 0.05 0.10 w y y1 0.05 0.05 0.05 Note 1. Dimension including plating thickness. 2. The marking bar indicates the cathode. 3. Solderable lead end, protrusion max. 0.02 mm. Outline version IEC SOD882BD Fig. 6. sod882bd_po References JEDEC JEITA European projection Issue date 20-06-22 20-06-23 MO-343AA Package outline SOD882BD BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 7 / 11 BZX884S series Nexperia Voltage regulator diodes 12. Soldering Footprint information for reflow soldering of DFN1006BD-2 package SOT882BD 1.4 0.2 0.8 (2×) 0.6 (2×) 0.7 (2×) 0.3 0.4 1.0 1.3 solder resist solder paste solder lands Dimensions in mm Issue date 20-05-01 sod882bd_fr Reflow soldering is the only recommended soldering method. Dimensions in mm. Fig. 7. Reflow soldering footprint SOD882BD BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 8 / 11 BZX884S series Nexperia Voltage regulator diodes 13. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX884S_SER v.1 20200713 Product data sheet - BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 - © Nexperia B.V. 2020. All rights reserved 9 / 11 BZX884S series Nexperia Voltage regulator diodes equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 10 / 11 BZX884S series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 3 11. Package outline.......................................................... 7 12. Soldering..................................................................... 8 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 July 2020 BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 13 July 2020 © Nexperia B.V. 2020. All rights reserved 11 / 11
BZX884S-B6V8YL 价格&库存
很抱歉,暂时无法提供与“BZX884S-B6V8YL”相匹配的价格&库存,您可以联系我们找货
