Philips Semiconductors
Product specification
P-channel enhancement mode
MOS transistor
FEATURES
BSH207
SYMBOL
• Very low threshold voltage
• Fast switching
• Logic level compatible
• Subminiature surface mount
package
QUICK REFERENCE DATA
VDS = -12 V
s
ID = -1.52 A
g
RDS(ON) ≤ 0.15 Ω (VGS = -2.5 V)
VGS(TO) ≥ 0.4 V
d
GENERAL DESCRIPTION
P-channel, enhancement mode,
logic level, field-effect power
transistor. This device has low
threshold voltage and extremely
fast switching making it ideal for
battery powered applications and
high speed digital interfacing.
PINNING
SOT457
PIN
DESCRIPTION
6
1,2,5,6 drain
3
gate
4
source
5
4
Top view
1
The BSH207 is supplied in the
SOT457 subminiature surface
mounting package.
2
3
LIMITING VALUES
Limiting values in accordance with the Absolute Maximum System (IEC 134)
SYMBOL
PARAMETER
CONDITIONS
VDS
VDGR
VGS
ID
Drain-source voltage
Drain-gate voltage
Gate-source voltage
Drain current (DC)
RGS = 20 kΩ
IDM
Ptot
Drain current (pulse peak value)
Total power dissipation
Tstg, Tj
Storage & operating temperature
Ta = 25 ˚C
Ta = 100 ˚C
Ta = 25 ˚C
Ta = 25 ˚C
Ta = 100 ˚C
MIN.
MAX.
UNIT
- 55
-12
-12
±8
-1.52
-0.96
-6.09
0.417
0.17
150
V
V
V
A
A
A
W
W
˚C
THERMAL RESISTANCES
SYMBOL
PARAMETER
CONDITIONS
TYP.
MAX.
UNIT
Rth j-a
Thermal resistance junction to
ambient
FR4 board, minimum
footprint
300
K/W
August 1998
1
Rev 1.000
MOS transistor
BSH207
ELECTRICAL CHARACTERISTICS
Tj= 25˚C unless otherwise specified
SYMBOL PARAMETER
V(BR)DSS
VGS(TO)
Drain-source breakdown
voltage
Gate threshold voltage
CONDITIONS
MIN.
VGS = 0 V; ID = -10 µA
VDS = VGS; ID = -1 mA
Tj = 150˚C
RDS(ON)
gfs
IGSS
IDSS
Drain-source on-state
resistance
VGS = -4.5 V; ID = -1 A
VGS = -2.5 V; ID = -1 A
VGS = -1.8 V; ID = -0.5 A
VGS = -2.5 V; ID = -1 A; Tj = 150˚C
Forward transconductance
VDS = -9.6 V; ID = -1 A
Gate source leakage current VGS = ±8 V; VDS = 0 V
Zero gate voltage drain
VDS = -9.6 V; VGS = 0 V;
current
Tj = 150˚C
TYP. MAX. UNIT
-12
V
-0.4
-0.1
1.5
-0.6
80
117
140
175
4.5
±10
-50
-13
120
150
180
230
±100
-100
-100
V
V
mΩ
mΩ
mΩ
mΩ
S
nA
nA
µA
Qg(tot)
Qgs
Qgd
Total gate charge
Gate-source charge
Gate-drain (Miller) charge
ID = -1 A; VDD = -10 V; VGS = -4.5 V
8.8
0.7
2.0
nC
nC
nC
td on
tr
td off
tf
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
VDD = -10 V; ID = -1 A;
VGS = -8 V; RG = 6 Ω
Resistive load
2
4.5
45
ns
ns
ns
ns
Ciss
Coss
Crss
Input capacitance
Output capacitance
Feedback capacitance
VGS = 0 V; VDS = -9.6 V; f = 1 MHz
500
210
62
pF
pF
pF
REVERSE DIODE LIMITING VALUES AND CHARACTERISTICS
Tj = 25˚C unless otherwise specified
SYMBOL
PARAMETER
CONDITIONS
IDR
IDRM
VSD
Continuous reverse drain
current
Pulsed reverse drain current
Diode forward voltage
trr
Qrr
Reverse recovery time
Reverse recovery charge
August 1998
MIN.
TYP.
MAX.
UNIT
Ta = 25 ˚C
-1.52
A
IF = -0.62 A; VGS = 0 V
-0.62
-6.09
-1.3
A
V
IF = -0.5 A; -dIF/dt = 100 A/µs;
VGS = 0 V; VR = -9.6 V
75
69
ns
nC
2
Rev 1.000
MOS transistor
BSH207
Normalised Power Dissipation, PD (%)
BSH207
Peak Pulsed Drain Current, IDM (A)
120
1000
100
D = 0.5
0.2
100
0.1
80
0.05
10
0.02
60
1
40
P
D
0.1
50
75
100
125
T
0.01
1E-06
150
D = tp/T
tp
single pulse
1E-05
1E-04
Ambient Temperature, Ta (C)
1E-03
1E-02
1E-01
1E+00 1E+01
Pulse width, tp (s)
Fig.1. Normalised power dissipation.
PD% = 100⋅PD/PD 25 ˚C = f(Ta)
Fig.4. Transient thermal impedance.
Zth j-a = f(t); parameter D = tp/T
Normalised Drain Current, ID (%)
Drain current, ID (A)
-5
120
-4.5 V
-4.5
100
-4
80
-3.5
BSH207
Tj = 25 C
-1.8 V
-2.5 V
-1.3 V
-3
60
-1.2 V
-2.5
-1.1 V
-2
40
-1.5
-1 V
-0.9 V
VGS = -0.8 V
-1
-0.5
50
75
100
125
Fig.2. Normalised continuous drain current.
ID% = 100⋅ID/ID 25 ˚C = f(Ta); conditions: VGS ≤ -10 V
-0.5
-1
-1.5
Drain-Source Voltage, VDS (V)
-2
Fig.5. Typical output characteristics, Tj = 25 ˚C.
ID = f(VDS); parameter VGS
BSH207
Drain-Source On Resistance, RDS(on) (Ohms)
100
0.7
BSH207
0.6
RDS(on) = VDS/ ID
10
-1V
-0.8 V
-1.1 V -1.2 V
-1.3 V
Tj = 25 C
-0.9 V
0.5
tp = 1ms
0.4
10 ms
1
0.3
100 ms
0.1
-2.5 V
0.2
d.c.
-1.8 V
0.1
VGS = -4.5V
0.01
1
10
100
Fig.3. Safe operating area. Ta = 25 ˚C
ID & IDM = f(VDS); IDM single pulse; parameter tp
August 1998
-0.5
-1
-1.5 -2 -2.5 -3
Drain Current, ID (A)
-3.5
-4
-4.5
-5
Fig.6. Typical on-state resistance, Tj = 25 ˚C.
RDS(ON) = f(ID); parameter VGS
3
Rev 1.000
MOS transistor
BSH207
BSH207
Threshold Voltage, VGS(to), (V)
-5
-4.5
0.7
VDS > ID X RDS(on)
-4
Tj = 25 C
-3.5
0.6
150 C
typical
0.5
-3
0.4
-2.5
minimum
0.3
-2
-1.5
0.2
-1
0.1
-0.5
-1
-1.5
Gate-Source Voltage, VGS (V)
25
-2
Fig.7. Typical transfer characteristics.
ID = f(VGS)
Transconductance, gfs (S)
50
75
100
125
150
Junction Temperature, Tj (C)
Fig.10. Gate threshold voltage.
VGS(TO) = f(Tj); conditions: ID = 1 mA; VDS = VGS
BSH207
BSH207
1E-01
8
VDS > ID X RDS(on)
7
6
VDS = -5 V
Tj = 25 C
1E-02
Tj = 25 C
150 C
1E-03
5
4
1E-04
3
2
1E-05
1
1E-06
1E-07
-0.2 -0.4 -0.6 -0.8 -1 -1.2 -1.4 -1.6 -1.8 -2 -2.2 -2.4 -2.6
-1
Fig.8. Typical transconductance, Tj = 25 ˚C.
gfs = f(ID)
RDS(ON) @ Tj
RDS(ON) @ 25C
Fig.11. Sub-threshold drain current.
ID = f(VGS); conditions: Tj = 25 ˚C
BSH207
Capacitances, Ciss, Coss, Crss (pF)
Normalised Drain-Source On Resistance
1.5
1.4
1.3
1.2
1.1
1
0.9
0.8
0.7
0.6
0.5
-0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1
1000
Ciss
-2.5 V
VGS = -4.5 V
Coss
-1.8 V
100
Crss
50
75
100
125
10
-0.1
150
Fig.9. Normalised drain-source on-state resistance.
RDS(ON)/RDS(ON)25 ˚C = f(Tj)
August 1998
-1.0
-10.0
-100.0
Fig.12. Typical capacitances, Ciss, Coss, Crss.
C = f(VDS); conditions: VGS = 0 V; f = 1 MHz
4
Rev 1.000
MOS transistor
Gate-source voltage, VGS (V)
BSH207
BSH207
-5
-4
-3
-2
-1
150 C
Tj = 25 C
2
3
4
5
6
Gate charge, (nC)
7
8
9
0.2
0.4
0.6
0.8
1
1.2
1.4
Drain-Source Voltage, VSDS (V)
Fig.14. Typical reverse diode current.
IF = f(VSDS); conditions: VGS = 0 V; parameter Tj
Fig.13. Typical turn-on gate-charge characteristics.
VGS = f(QG)
August 1998
BSH207
Source-Drain Diode Current, IF (A)
5
4.5
4
3.5
3
2.5
2
1.5
1
0.5
VDD = 10 V
RD = 10 Ohms
Tj = 25 C
5
Rev 1.000
MOS transistor
BSH207
MECHANICAL DATA
Plastic surface mounted package; 6 leads
SOT457
D
E
B
y
A
HE
6
X
v M A
4
5
Q
pin 1
index
A
A1
1
2
bp
e
c
3
Lp
w M B
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
c
D
E
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
OUTLINE
VERSION
SOT457
e
HE
Lp
Q
v
w
y
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
REFERENCES
IEC
JEDEC
EIAJ
EUROPEAN
PROJECTION
SC-74
ISSUE DATE
97-02-28
Fig.15. SOT457 surface mounting package.
Notes
1. This product is supplied in anti-static packaging. The gate-source input must be protected against static
discharge during transport or handling.
2. Refer to SMD Footprint Design and Soldering Guidelines, Data Handbook SC18.
3. Epoxy meets UL94 V0 at 1/8".
August 1998
6
Rev 1.000
MOS transistor
BSH207
DEFINITIONS
Data sheet status
Objective specification
This data sheet contains target or goal specifications for product development.
Preliminary specification This data sheet contains preliminary data; supplementary data may be published later.
This data sheet contains final product specifications.
Limiting values
Limiting values are given in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one
or more of the limiting values may cause permanent damage to the device. These are stress ratings only and
operation of the device at these or at any other conditions above those given in the Characteristics sections of
this specification is not implied. Exposure to limiting values for extended periods may affect device reliability.
Application information
Where application information is given, it is advisory and does not form part of the specification.
Philips Electronics N.V. 1998
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the
copyright owner.
The information presented in this document does not form part of any quotation or contract, it is believed to be
accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any
consequence of its use. Publication thereof does not convey nor imply any license under patent or other
industrial or intellectual property rights.
LIFE SUPPORT APPLICATIONS
These products are not designed for use in life support appliances, devices or systems where malfunction of these
products can be reasonably expected to result in personal injury. Philips customers using or selling these products
for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting
from such improper use or sale.
August 1998
7
Rev 1.000
