BZX384-A7V5X
BZX384-A7V5X
    NEXPERIA(安世)
    NEXPERIA - BZX384-A7V5X - Zener Single Diode, 7.5 V, 300 mW, SC-76, 2 Pins, 150 °C, Surface Mount
BZX384-A7V5X 数据手册
BZX384-A series Voltage regulator diodes Rev. 1 — 3 February 2022 Product data sheet 1. General description Low-power voltage regulator diodes in a small SOD323 (SC-76) Surface-Mounted Device (SMD) plastic package. The diodes are available in the normalized E24 ±1 % (BZX384-A) tolerance range. The series includes 37 breakdown voltages with nominal working voltages from 2.4 V to 75 V. 2. Features and benefits • • • • Total power dissipation: ≤300 mW Very tight tolerance series: ±1 % Working voltage range: nominal 2.4 V to 75 V (E24 range) Non-repetitive peak reverse power dissipation: ≤ 40 W 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Typ Max Unit VF forward voltage IF = 10 mA [1] - - 0.9 V Ptot total power dissipation Tamb ≤ 25 °C [2] - - 300 mW [1] [2] Min Pulse test: tp ≤ 100 μs; δ ≤ 0.02. Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. BZX384-A series Nexperia Voltage regulator diodes 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline [1] 1 Graphic symbol 2 A K 006aaa152 [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number BZX384-A series Package Name Description Version SC-76 plastic surface-mounted package; 2 leads SOD323 7. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code BZX384-A2V4 2B BZX384-A8V2 28 BZX384-A30 5F BZX384-A2V7 2U BZX384-A9V1 29 BZX384-A33 4R BZX384-A3V0 2V BZX384-A10 3X BZX384-A36 4S BZX384-A3V3 2W BZX384-A11 32 BZX384-A39 4T BZX384-A3V6 2X BZX384-A12 33 BZX384-A43 4U BZX384-A3V9 2Y BZX384-A13 34 BZX384-A47 4V BZX384-A4V3 2Z BZX384-A15 35 BZX384-A51 4W BZX384-A4V7 22 BZX384-A16 36 BZX384-A56 4X BZX384-A5V1 23 BZX384-A18 37 BZX384-A62 4Y BZX384-A5V6 24 BZX384-A20 38 BZX384-A68 4Z BZX384-A6V2 25 BZX384-A22 39 BZX384-A75 42 BZX384-A6V8 26 BZX384-A24 4N - - BZX384-A7V5 27 BZX384-A27 4P - - BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 2 / 12 BZX384-A series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current IZSM non-repetitive peak reverse current [1] - see Tables 8 and 9 PZSM non-repetitive peak reverse power dissipation [1] - 40 W Ptot total power dissipation [2] - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature -65 +150 °C Tstg storage temperature -65 +150 °C [1] [2] Conditions Tamb ≤ 25 °C Min Max Unit - 250 mA tp = 100 μs; square wave; Tj = 25 °C prior to surge. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] [2] Min Typ Max Unit [1] - - 415 K/W [2] - - 110 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Soldering point of cathode tab. BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 BZX384-A series Nexperia Voltage regulator diodes 10. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA IF = 100 mA [1] Min Typ Max Unit [1] - - 0.9 V [1] - - 1.1 V Pulse test: tp ≤ 100 μs; δ ≤ 0.02. Table 8. Characteristics per type; BZX384-A2V4 to BZX384-A24 Tj = 25 °C unless otherwise specified. BZX384 Sel -xxx Working voltage VZ (V) IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K) IZ = 5 mA Diode Non-repetitive capacitance peak reverse Cd (pF) [1] current IZSM (A) [2] Min Max IZ = 1 mA IZ = 5 mA Max VR (V) Min Max Max Max 2V4 A 2.37 2.43 600 100 50 1 -3.5 0.0 450 6 2V7 A 2.67 2.73 600 100 20 1 -3.5 0.0 450 6 3V0 A 2.97 3.03 600 95 10 1 -3.5 0.0 450 6 3V3 A 3.26 3.34 600 95 5 1 -3.5 0.0 450 6 3V6 A 3.56 3.64 600 90 5 1 -3.5 0.0 450 6 3V9 A 3.86 3.94 600 90 3 1 -3.5 0.0 450 6 4V3 A 4.25 4.35 600 90 3 1 -3.5 0.0 450 6 4V7 A 4.65 4.75 500 80 3 2 -3.5 0.2 300 6 5V1 A 5.04 5.16 480 60 2 2 -2.7 1.2 300 6 5V6 A 5.54 5.66 400 40 1 2 -2.0 2.5 300 6 6V2 A 6.13 6.27 150 10 3 4 0.4 3.7 200 6 6V8 A 6.73 6.87 80 15 2 4 1.2 4.5 200 6 7V5 A 7.42 7.58 80 15 1 5 2.5 5.3 150 4 8V2 A 8.11 8.29 80 15 0.7 5 3.2 6.2 150 4 9V1 A 9.00 9.20 100 15 0.5 6 3.8 7.0 150 3 10 A 9.90 10.10 150 20 0.2 7 4.5 8.0 90 3 11 A 10.89 11.11 150 20 0.1 8 5.4 9.0 85 2.5 12 A 11.88 12.12 150 25 0.1 8 6.0 10.0 85 2.5 13 A 12.87 13.13 170 30 0.1 8 7.0 11.0 80 2.5 15 A 14.85 15.15 200 30 0.05 10.5 9.2 13.0 75 2.0 16 A 15.84 16.16 200 40 0.05 11.2 10.4 14.0 75 1.5 18 A 17.82 18.18 225 45 0.05 12.6 12.4 16.0 70 1.5 20 A 19.80 20.20 225 55 0.05 14.0 14.4 18.0 60 1.5 22 A 21.78 22.22 250 55 0.05 15.4 16.4 20.0 60 1.25 24 A 23.76 24.24 250 70 0.05 16.8 18.4 22.0 55 1.25 [1] [2] f = 1 MHz; VR = 0 V tp = 100 μs; square wave; Tj = 25 °C BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 4 / 12 BZX384-A series Nexperia Voltage regulator diodes Table 9. Characteristics per type; BZX384-A27 to BZX384-A75 Tj = 25 °C unless otherwise specified. BZX384 Sel -xxx Working voltage VZ (V) IZ = 2 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K) IZ = 2 mA Diode Non-repetitive capacitance peak reverse Cd (pF) [1] current IZSM (A) [2] Min IZ = 0.5 mA IZ = 2 mA Max VR (V) Min Max Max Max Max 27 A 26.73 27.27 300 80 0.05 18.9 21.4 25.3 50 1 30 A 29.70 30.30 300 80 0.05 21.0 24.4 29.4 50 1 33 A 32.67 33.33 325 80 0.05 23.1 27.4 33.4 45 0.9 36 A 35.64 36.36 350 90 0.05 25.2 30.4 37.4 45 0.8 39 A 38.61 39.39 350 130 0.05 27.3 33.4 41.2 45 0.7 43 A 42.57 43.43 375 150 0.05 30.1 37.6 46.6 40 0.6 47 A 46.53 47.47 375 170 0.05 32.9 42.0 51.8 40 0.5 51 A 50.49 51.51 400 180 0.05 35.7 46.6 57.2 40 0.4 56 A 55.44 56.56 425 200 0.05 39.2 52.2 63.8 40 0.3 62 A 61.38 62.62 450 215 0.05 43.4 58.8 71.6 35 0.3 68 A 67.32 68.68 475 240 0.05 47.6 65.6 79.8 35 0.25 75 A 74.25 75.75 500 255 0.05 52.5 73.4 88.6 35 0.20 [1] [2] f = 1 MHz; VR = 0 V tp = 100 μs; square wave; Tj = 25 °C mbg801 103 PZSM (W) aaa-028550 103 IF (mA) 102 102 10 1 (1) 10-1 10 (2) 10-2 1 10- 1 1 tp (ms) 10 (1) Tj = 25 °C (before surge) (2) Tj = 150 °C (before surge) Fig. 1. Product data sheet 0.6 0.8 VF (V) 1.0 Tj = 25 °C Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values BZX384-A_SER 10-3 0.4 Fig. 2. Forward current as a function of forward voltage; typical values (BZX384-A2V4) All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 BZX384-A series Nexperia Voltage regulator diodes aaa-028551 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 °C Fig. 3. aaa-028552 103 IF (mA) 102 0.6 0.8 1.0 VF (V) Tj = 25 °C Forward current as a function of forward voltage; typical values (BZX384-A6V8) Fig. 4. aaa-028553 103 IF (mA) 102 Forward current as a function of forward voltage; typical values (BZX384-A7V5) mld444 0.5 SZ (mV/K) 4V7 0 4V3 10 - 0.5 2V4 1 2V7 3V9 -1 10-1 10-3 0.4 0.6 0.8 VF (V) -2 10- 1 1.0 Tj = 25 °C Fig. 5. Product data sheet 3V3 3V0 1 10 IZ (mA) 102 Tj = 25 °C to 150 °C Forward current as a function of forward voltage; typical values (BZX384-A75) BZX384-A_SER 3V6 - 1.5 10-2 Fig. 6. Temperature coefficient as a function of working current; typical values (BZX384-A2V4 to BZX384-A4V7) All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 BZX384-A series Nexperia Voltage regulator diodes mld445 12 IR (A) 15 SZ (mV/K) 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 8 4 0 aaa-006665 10-1 2V4 10-2 2V7 10-3 3V0 3V3 3V6 3V9 4V3 4V7 5V1 10-4 10-5 5V6 10-6 6V2 6V8 10-7 10-8 -4 10- 1 1 10 IZ (mA) 10-9 102 Tj = 25 °C to 150 °C Fig. 7. IR (A) Fig. 8. aaa-006666 10-1 IR (A) 7V5 10 12 15 18 22 8V2 10-3 2 4 6 VR (V) 8 Tj = 25 °C Temperature coefficient as a function of working current; typical values (BZX384-A5V1 to BZX384-A15) 10-2 0 Reverse current as a function of reverse voltage; typical values (BZX384-A2V4 to BZX384-A6V8) aaa-006667 10-1 30 36 10-2 27 33 43 39 51 47 62 56 75 68 10-3 9V1 11 13 16 20 24 10-4 10-4 10-5 10-5 10-6 10-6 10-7 10-7 10-8 10-8 0 5 10 15 20 VR (V) Tj = 25 °C Fig. 9. Product data sheet 10-9 20 40 60 VR (V) 80 Tj = 25 °C Reverse current as a function of reverse voltage; typical values (BZX384-A7V5 to BZX384-A24) BZX384-A_SER 25 Fig. 10. Reverse current as a function of reverse voltage; typical values (BZX384-A27 to BZX384-A75) All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 BZX384-A series Nexperia Voltage regulator diodes 11. Package outline 1.35 1.15 1.1 0.8 0.45 0.15 1 2.7 2.3 1.8 1.6 2 0.40 0.25 0.25 0.10 Dimensions in mm 03-12-17 Fig. 11. Package outline SOD323 12. Soldering 3.05 2.1 solder lands solder resist 1.65 0.95 0.5 (2×) 0.6 (2×) solder paste occupied area 2.2 0.5 (2×) 0.6 (2×) Dimensions in mm sod323_fr Fig. 12. Reflow soldering footprint for SOD323 (SC-76) BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 BZX384-A series Nexperia Voltage regulator diodes 5 2.9 1.5 (2×) solder lands solder resist occupied area 2.75 1.2 (2×) Dimensions in mm preferred transport direction during soldering sod323_fw Fig. 13. Wave soldering footprint for SOD323 (SC-76) BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 BZX384-A series Nexperia Voltage regulator diodes 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX384-A_SER v.1 Product data sheet - - BZX384-A_SER Product data sheet 20220203 All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 BZX384-A series Nexperia Voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BZX384-A_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 BZX384-A series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Package outline.......................................................... 8 12. Soldering..................................................................... 8 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 February 2022 BZX384-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 3 February 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
BZX384-A7V5X 价格&库存
很抱歉,暂时无法提供与“BZX384-A7V5X”相匹配的价格&库存,您可以联系我们找货
