BZX58550-C51X
BZX58550-C51X
    NEXPERIA(安世)
    NEXPERIA - BZX58550-C51X - Zener Single Diode, 51 V, 300 mW, SC-79, 2 Pins, 150 °C
BZX58550-C51X 数据手册
BZX58550 series Low-current voltage regulator diodes Rev. 1 — 24 August 2021 Product data sheet 1. General description Low-current voltage regulator diodes in an SOD523 (SC-79) ultra small and flat lead SurfaceMounted Device (SMD) plastic package. 2. Features and benefits • • • • Total power dissipation: ≤ 300 mW Tolerance series: approximately ± 5 % Working voltage range: nominal 1.8 V to 75 V Specified at a low test current (50 μA), ideal for low bias and portable battery-powered applications 3. Applications • Low-current general regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Typ Max Unit VF forward voltage IF = 10 mA [1] - - 0.9 V Ptot total power dissipation Tamb ≤ 25 °C [2] - - 300 mW [1] [2] Min Pulse test: tp ≤ 300 μs; δ ≤ 0.02 2 Device mounted on an FR4 Printed-Circuit Board (PCB), with approximately 35 mm Cu area at cathode tab. 5. Pinning information Table 2. Pinning Pin Symbol 1 2 [1] K A Description cathode [1] anode The marking bar indicates the cathode. Simplified outline 1 Graphic symbol 2 K A 006aaa152 BZX58550 series Nexperia Low-current voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number Package BZX58550 series Name Description Version SC-79 plastic surface-mounted package; 2 leads SOD523 7. Marking Table 4. Marking Codes Type number Marking Type number Code BZX58550-C1V8 BZX58550-C2V0 BZX58550-C2V2 BZX58550-C2V4 BZX58550-C2V7 BZX58550-C3V0 BZX58550-C3V3 BZX58550-C3V6 BZX58550-C3V9 BZX58550-C4V3 BZX58550_SER Product data sheet 1C 1E 1F 1H 1K 1L 1N 1S 1T 1U BZX58550-C4V7 BZX58550-C5V1 BZX58550-C5V6 BZX58550-C6V2 BZX58550-C6V8 BZX58550-C7V5 BZX58550-C8V2 BZX58550-C9V1 BZX58550-C10 BZX58550-C11 Marking Type number Code Marking Type number Code Marking Code 1X 2S 3L 1Y 1Z 2C 2E 2F 2H 2K 2L 2N BZX58550-C12 BZX58550-C13 BZX58550-C15 BZX58550-C16 BZX58550-C18 BZX58550-C20 BZX58550-C22 BZX58550-C24 BZX58550-C27 BZX58550-C30 All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 2T 2U 2X 2Y 3C 3E 3F 3H 3K BZX58550-C33 BZX58550-C36 BZX58550-C39 BZX58550-C43 BZX58550-C47 BZX58550-C51 BZX58550-C56 BZX58550-C62 BZX58550-C68 BZX58550-C75 © 3N 3S 3T 3U 3X 3Y 3Z 4C 4E Nexperia B.V. 2021. All rights reserved 2 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit IF forward current - 200 mA PZSM non-repetitive peak reverse power dissipation tp = 100 µs; square wave; Tj = 25 °C; prior to surge - 40 W Ptot total power dissipation Tamb ≤ 25 °C - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Conditions [1] 2 Device mounted on an FR4 Printed-Circuit Board (PCB), with approximately 35 mm Cu area at cathode tab. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] [2] Min Typ Max Unit [1] - - 350 K/W [2] - - 65 K/W 2 Device mounted on an FR4 Printed-Circuit Board (PCB), with approximately 35 mm Cu area at cathode tab. Soldering point of cathode tab BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 3 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes 10. Characteristics Table 7. Electrical characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA [1] [1] Max Unit 0.9 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Table 8. Electrical characteristics per type: BZX58550-C1V8 to BZX58550-C24 Tj = 25 °C unless otherwise specified. BZX58550-C Working voltage VZ (V) IZ = 50 µA Min Max 1V8 1.71 2V0 2V2 Differential resistance rdiff (Ω) IZ = 1 mA IZ = 5 mA Reverse current IR (µA) Max Max Max Min 7.5 VR (V) 1.0 1.89 600 100 1.88 2.12 600 2.09 2.31 600 100 7 100 4 2V4 2.28 2.52 600 100 2V7 2.565 2.835 600 3V0 2.85 3.15 3V3 3.13 3V6 3.42 3V9 Temperature coefficient SZ (mV/K) IZ = 5 mA Diode capacit. Cd (pF)[1] Max Max -3.5 0 220 1.0 -3.5 0 220 1.0 -3.5 0 210 2 1.0 -3.5 0 200 100 1 1.0 -3.5 0 190 600 100 0.8 1.0 -3.5 0.2 170 3.47 600 100 7.5 1.5 -3.5 1.2 160 3.78 600 95 7.5 2.0 -3.5 1.2 160 3.70 4.10 600 95 5.0 2.0 -2.7 2.5 150 4V3 4.09 4.52 600 95 4.0 2.0 -2.7 2.5 150 4V7 4.47 4.94 600 80 5.0 3.0 -2.7 2.5 140 5V1 4.85 5.36 500 60 5.0 3.0 -2.0 3.7 130 5V6 5.32 5.88 400 40 2.0 4.0 -2.0 3.7 120 6V2 5.89 6.51 160 10 1.0 5.0 0.4 4.5 110 6V8 6.46 7.14 80 15 0.1 5.1 1.2 4.5 100 7V5 7.13 7.88 80 15 0.1 5.7 2.5 5.3 150 8V2 7.79 8.61 80 15 0.1 6.2 3.2 6.2 150 9V1 8.65 9.56 100 15 0.1 6.9 3.8 7.0 150 10 9.50 10.50 150 20 0.1 7.6 4.5 8.0 90 11 10.45 11.55 150 20 0.05 8.4 5.4 9.0 85 12 11.40 12.60 150 25 0.05 9.1 6.0 10.0 85 13 12.35 13.65 170 30 0.05 9.8 7.0 11.0 80 15 14.25 15.75 200 30 0.05 11.4 9.2 13.0 75 16 15.20 16.80 200 40 0.05 12.1 10.4 14.0 75 18 17.10 18.90 225 45 0.05 13.6 12.4 16.0 70 20 19.00 21.00 225 55 0.05 15.2 14.4 18.0 60 22 20.90 23.10 250 55 0.05 16.7 16.4 20.0 60 24 22.80 25.20 250 70 0.05 18.2 18.4 22.0 55 [1] f = 1 MHz; VR = 0 V BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 4 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes Table 9. Electrical characteristics per type: BZX58550-C27 to BZX58550-C75 BZX58550-C Working voltage Differential Reverse current VZ (V) resistance IR (µA) rdiff (Ω) IZ = IZ = 2 mA IZ = 50 µA 0.5 mA Temperature coefficient SZ (mV/K) IZ = 2 mA Diode capacit. Cd (pF)[1] Min Max Max Max Max Max Max 25.65 28.35 300 80 0.05 VR (V) 20.4 Min 27 21.4 25.3 50 30 28.50 31.50 300 80 0.05 22.8 24.4 29.4 50 33 31.35 34.65 325 80 0.05 25.0 27.4 33.4 45 36 34.20 37.80 350 90 0.05 27.3 30.4 37.4 45 39 37.05 40.95 350 130 0.05 29.6 33.4 41.2 45 43 40.85 45.15 375 150 0.05 32.6 37.6 46.6 40 47 44.00 50.00 375 170 0.05 32.9 42.0 51.8 40 51 48.00 54.00 400 180 0.05 35.7 46.6 57.2 40 56 52.00 60.00 425 200 0.05 39.2 52.2 63.8 40 62 58.00 66.00 450 215 0.05 43.4 58.8 71.6 35 68 64.00 72.00 475 240 0.05 47.6 65.6 79.8 35 75 70.00 79.00 500 255 0.05 52.5 73.4 88.6 35 [1] f = 1 MHz; VR = 0 V aaa-028521 103 PZSM (W) aaa-033420 103 IF (mA) 102 102 10 1 10-1 10 10-2 1 10-1 1 tp (ms) 10 10-3 0.4 Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values BZX58550_SER Product data sheet 0.8 VF (V) 1.0 Tj = 25 °C (1) Tj = 25 °C (before surge) Fig. 1. 0.6 Fig. 2. Forward current as a function of forward voltage; typical values (BZX58550-C1V8) All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 5 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes aaa-028551 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 °C Fig. 3. aaa-028553 103 IF (mA) 102 Fig. 4. Forward current as a function of forward voltage; typical values (BZX58550-C7V5) aaa-033421 10-1 3V9 4V3 4V7 5V1 5V6 6V2 6V8 10-4 10-1 10-5 10-2 0.6 0.8 VF (V) 1.0 10-6 Tj = 25 °C 0 2 4 6 VR (V) 8 Tamb = 25 °C Forward current as a function of forward voltage; typical values (BZX58550-C75) Product data sheet 1.0 VF (V) BZX58550-C1V8 2V0 10-2 2V2 2V4 2V7 3V0 10-3 3V3 3V6 1 BZX58550_SER 0.8 IR (A) 10 Fig. 5. 0.6 Tj = 25 °C Forward current as a function of forward voltage; typical values (BZX58550-C6V8) 10-3 0.4 aaa-028552 103 IF (mA) 102 Fig. 6. Reverse current as a function of reverse voltage; typical values (BZX58550-C1V8 to BZX58550-C6V8) All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 6 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes IR (A) aaa-006666 10-1 IR (A) 7V5 10-2 10 12 15 18 22 8V2 10-3 aaa-006667 10-1 30 36 10-2 27 33 43 39 51 47 62 56 75 68 10-3 9V1 11 13 16 20 24 10-4 10-4 10-5 10-5 10-6 10-6 10-7 10-7 10-8 10-8 0 5 10 15 20 VR (V) 10-9 25 Tamb = 25 °C Fig. 7. 20 40 60 VR (V) 80 Tamb = 25 °C Reverse current as a function of reverse voltage; typical values (BZX58550-C7V5 to BZX58550-C24) Fig. 8. Reverse current as a function of reverse voltage; typical values (BZX58550-C27 to BZX58550-C75) 11. Package outline 0.85 0.75 0.65 0.58 1 1.65 1.25 1.55 1.15 2 0.34 0.26 0.17 0.11 Dimensions in mm Fig. 9. 02-12-13 Package outline SOD523 (SC-79) BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 7 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes 12. Soldering 2.15 1.4 solder lands solder resist 0.5 0.6 (2×) (2×) 1.2 solder paste occupied area Dimensions in mm 0.4 (2×) 0.5 (2×) sod523_fr Fig. 10. Reflow soldering footprint SOD523 (SC-79) BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 8 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX58550_SER v.1 20210824 Product data sheet - BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 - © Nexperia B.V. 2021. All rights reserved 9 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BZX58550_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 10 / 11 BZX58550 series Nexperia Low-current voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Package outline.......................................................... 7 12. Soldering..................................................................... 8 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 August 2021 BZX58550_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 August 2021 © Nexperia B.V. 2021. All rights reserved 11 / 11
BZX58550-C51X 价格&库存
很抱歉,暂时无法提供与“BZX58550-C51X”相匹配的价格&库存,您可以联系我们找货
