BUK7Y53-100B
BUK7Y53-100B
    NEXPERIA(安世)
    NEXPERIA - BUK7Y53-100B - Power MOSFET, N Channel, 100 V, 24.8 A, 0.04 ohm, SC-100, Surface Mount
BUK7Y53-100B 数据手册
BUK7Y53-100B N-channel TrenchMOS standard level FET Rev. 3 — 13 October 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using NXP High-Performance Automotive (HPA) TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Q101 compliant „ Suitable for standard level gate drive sources „ Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications „ 12 V, 24 V and 42 V loads „ General purpose power switching „ Automotive systems „ Solenoid drivers „ DC-to-DC converters „ Transmission control „ Engine management 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 4 - - 24.8 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 85 W VGS = 10 V; ID = 10 A; Tj = 25 °C; see Figure 12; see Figure 13 - 40 53 mΩ V Static characteristics RDSon drain-source on-state resistance BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit - - 81 mJ - 8.5 - nC Avalanche ruggedness EDS(AL)S non-repetitive ID = 24.8 A; Vsup ≤ 100 V; drain-source RGS = 50 Ω; VGS = 10 V; avalanche energy Tj(init) = 25 °C; unclamped Dynamic characteristics QGD gate-drain charge ID = 10 A; VDS = 80 V; VGS = 10 V; see Figure 14 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 c source Simplified outline 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number BUK7Y53-100B BUK7Y53-100B Product data sheet Package Name Description LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 Version © NXP B.V. 2010. All rights reserved. 2 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage RGS = 20 kΩ - 100 V VGS gate-source voltage ID drain current -20 20 V Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 4 - 24.8 A Tmb = 100 °C; VGS = 10 V; see Figure 1 - 17.6 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 4 - 99 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 85 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 24.8 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 99 A - 81 mJ - - J Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy ID = 24.8 A; Vsup ≤ 100 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped EDS(AL)R repetitive drain-source avalanche energy see Figure 3 [1] Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. [2] Repetitive avalanche rating limited by an average junction temperature of 170 °C. [3] Refer to application note AN10273 for further information. BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 [1][2][3] © NXP B.V. 2010. All rights reserved. 3 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 003aac515 30 ID (A) Pder (%) 20 80 10 40 0 0 0 Fig 1. 03na19 120 50 100 150 Tmb (°C) 0 200 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aac494 102 IAL (A) (1) 10 (2) 1 (3) -1 10 10-2 10-3 Fig 3. 10-2 10-1 1 tAL (ms) 10 Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 4 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 003aad637 103 I D (A) 102 Limit RDSon = V DS / ID tp = 10 μs 100 μs 10 DC 1 1 ms 10 ms 100 ms 10-1 10-1 Fig 4. 1 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 5 - - 1.76 K/W 003aac482 10 Zth (j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10-1 0.05 δ= P 0.02 Fig 5. t tp single shot 10-2 10-6 tp T T 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration. BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 5 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 90 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 2 3 4 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10 - - 4.4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10 1 - - V µA IDSS drain leakage current VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.02 1 VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VDS = 0 V; VGS = 20 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -20 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 10 A; Tj = 175 °C; see Figure 12; see Figure 13 - - 138 mΩ VGS = 10 V; ID = 10 A; Tj = 25 °C; see Figure 12; see Figure 13 - 40 53 mΩ ID = 10 A; VDS = 80 V; VGS = 10 V; see Figure 14 - 22 - nC - 4.3 - nC - 8.5 - nC - 1100 1467 pF - 142 170 pF - 63 86 pF - 15.3 - ns RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 15 VDS = 30 V; RL = 3 Ω; VGS = 10 V; RG(ext) = 10 Ω tr rise time - 7.8 - ns td(off) turn-off delay time - 34 - ns tf fall time - 7.7 - ns Source-drain diode VSD source-drain voltage IS = 15 A; VGS = 25 V; Tj = 25 °C; see Figure 16 - 0.85 1.2 V trr reverse recovery time - 56 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V - 155 - nC BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 6 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 003aad631 30 10 ID (A) 24 003aad632 300 4.1 VGS (V) = 5.0 4.4 VGS (V) = 4.6 RDSon (mΩ) 4.8 4.8 200 18 4.6 12 4.4 100 5.0 6 4.1 10 0 0 0 Fig 6. 1 2 3 4 VDS (V) 0 5 Output characteristics: drain current as a function of drain-source voltage; typical values. Fig 7. 003aad633 25 ID (A) 5 10 15 I D (A) 20 Drain-source on-state resistance as a function of drain current; typical values. 003aad638 20 gfs (S) 20 15 15 10 10 Tj = 175 °C 25 °C 5 5 0 0 0 Fig 8. 2 4 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values. BUK7Y53-100B Product data sheet 0 6 Fig 9. 7 14 21 I D (A) 28 Forward transconductance as a function of drain current; typical values. All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 7 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 03aa32 5 ID (A) VGS(th) (V) 4 typ max 10−3 typ 2 min 10−2 max 3 10−4 min 10−5 1 0 −60 03aa35 10−1 10−6 0 60 120 0 180 2 4 Tj (°C) Fig 10. Gate-source threshold voltage as a function of junction temperature 03aa29 3 6 VGS (V) Fig 11. Sub-threshold drain current as a function of gate-source voltage 003aad639 150 RDSON (mΩ) a 2 100 1 50 0 -60 0 0 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature BUK7Y53-100B Product data sheet 2 8 14 VGS (V) 20 Fig 13. Drain-source on-state resistance as a function of gate-source voltage; typical values. All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 8 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 003aad635 10 003aad636 104 VGS (V) C (pF) 8 103 VDS = 14 V Ciss 6 VDS = 80 V 4 Coss 102 Crss 2 0 0 6 12 18 QG (nC) 10 10-1 24 Fig 14. Gate-source voltage as a function of gate charge; typical values. 1 10 VDS (V) 102 Fig 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values. 003aad634 25 IS (A) 20 15 10 Tj = 175 °C 25 °C 5 0 0 0.4 0.8 VS D (V) 1.2 Fig 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values. BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 9 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 17. Package outline SOT669 (LFPAK) BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 10 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK7Y53-100B v.3 20101013 Product data sheet - BUK7Y53-100B_2 - BUK7Y53-100B_1 Modifications: BUK7Y53-100B_2 BUK7Y53-100B Product data sheet • Status changed from objective to product. 20100211 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 11 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK7Y53-100B Product data sheet Suitability for use in automotive applications — This NXP Semiconductors product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 12 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. 9.4 No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BUK7Y53-100B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 13 October 2010 © NXP B.V. 2010. All rights reserved. 13 of 14 BUK7Y53-100B NXP Semiconductors N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 13 October 2010 Document identifier: BUK7Y53-100B
BUK7Y53-100B 价格&库存
很抱歉,暂时无法提供与“BUK7Y53-100B”相匹配的价格&库存,您可以联系我们找货
