BZT52H-A5V1X
BZT52H-A5V1X
    NEXPERIA(安世)
    Zener Diode Single 5.1V 1% 60Ohm 830mW 2-Pin SOD-123F
BZT52H-A5V1X 数据手册
BZT52H-A series Voltage regulator diodes Rev. 1 — 25 January 2022 Product data sheet 1. General description General-purpose Zener diodes in an SOD123F small and flat lead Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • Total power dissipation: ≤ 830 mW Wide working voltage range: nominal 2.4 V to 75 V (E24 range) Small plastic package suitable for surface-mounted design Very tight tolerance: ±1 % 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 10 mA Ptot total power dissipation Tamb ≤ 25 °C [1] [2] [3] Min Typ Max Unit [1] - - 0.9 V [2] - - 375 mW [3] - - 830 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02. Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . 5. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline [1] 1 2 Graphic symbol K A 006aaa152 [1] The marking bar indicates the cathode. BZT52H-A series Nexperia Voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number BZT52H-A2V4 to BZT52H-A75 Package Name Description Version - plastic surface-mounted package; 2 leads SOD123F 7. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code Type number Marking code BZT52H-A2V4 FT BZT52H-A6V2 G4 BZT52H-A16 GE BZT52H-A43 GY BZT52H-A2V7 FU BZT52H-A6V8 G5 BZT52H-A18 GF BZT52H-A47 GR BZT52H-A3V0 FV BZT52H-A7V5 G6 BZT52H-A20 GG BZT52H-A51 GS BZT52H-A3V3 FW BZT52H-A8V2 G7 BZT52H-A22 GH BZT52H-A56 GT BZT52H-A3V6 FX BZT52H-A9V1 G8 BZT52H-A24 GJ BZT52H-A62 GU BZT52H-A3V9 FY BZT52H-A10 G9 BZT52H-A27 GK BZT52H-A68 GV BZT52H-A4V3 FZ BZT52H-A11 GA BZT52H-A30 GL BZT52H-A75 GW BZT52H-A4V7 G1 BZT52H-A12 GB BZT52H-A33 GM - - BZT52H-A5V1 G2 BZT52H-A13 GC BZT52H-A36 GN - - BZT52H-A5V6 G3 BZT52H-A15 GD BZT52H-A39 GP - - BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 2 / 12 BZT52H-A series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF Conditions Min Max Unit forward current - 250 mA IZSM non-repetitive peak reverse current - see Table 8,9 and 10 PZSM non-repetitive peak reverse power dissipation Ptot total power dissipation Tamb ≤ 25 °C [1] - 40 W [2] - 375 mW [3] - 830 mW Tj junction temperature - 150 °C Tamb ambient temperature -65 +150 °C Tstg storage temperature -65 +150 °C [1] [2] [3] tp = 100 μs; square wave; Tj = 25 °C prior to surge. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air Rth(j-sp) [1] [2] [3] BZT52H-A_SER Product data sheet thermal resistance from junction to ambient thermal resistance from junction to solder point Typ Max Unit [1] - Min - 330 K/W [2] - - 150 K/W [3] - - 70 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Soldering point of cathode tab. All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 BZT52H-A series Nexperia Voltage regulator diodes 10. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA [1] Min [1] - Typ Max Unit - 0.9 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02. Table 8. Characteristics per type; BZT52H-A2V4 to BZT52H-A24 Tj = 25 °C unless otherwise specified. BZT52H Sel -xxx Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse Temperature current IR (μA) coefficient SZ (mV/K); IZ = 5 mA Diode Non-repetitive capacitance peak reverse Cd (pF) [1] current IZSM (A) [2] Min Max IZ = 1 mA IZ = 5 mA Max VR (V) Min Max Max Max 2V4 A 2.37 2.43 400 85 50 1 -3.5 0.0 450 6.0 2V7 A 2.67 2.73 500 83 20 1 -3.5 0.0 450 6.0 3V0 A 2.97 3.03 500 95 10 1 -3.5 0.0 450 6.0 3V3 A 3.26 3.34 500 95 5 1 -3.5 0.0 450 6.0 3V6 A 3.56 3.64 500 95 5 1 -3.5 0.0 450 6.0 3V9 A 3.86 3.94 500 95 3 1 -3.5 0.0 450 6.0 4V3 A 4.25 4.35 500 95 3 1 -3.5 0.0 450 6.0 4V7 A 4.65 4.75 500 78 3 2 -3.5 0.2 300 6.0 5V1 A 5.04 5.16 480 60 2 2 -2.7 1.2 300 6.0 5V6 A 5.54 5.66 400 40 1 2 -2.0 2.5 300 6.0 6V2 A 6.13 6.27 150 10 3 4 0.4 3.7 200 6.0 6V8 A 6.73 6.87 80 8 2 4 1.2 4.5 200 6.0 7V5 A 7.42 7.58 80 10 1 5 2.5 5.3 150 4.0 8V2 A 8.11 8.29 80 10 0.7 5 3.2 6.2 150 4.0 9V1 A 9.00 9.20 100 10 0.5 6 3.8 7.0 150 3.0 10 A 9.90 10.10 70 10 0.2 7 4.5 8.0 90 3.0 11 A 10.89 11.11 70 10 0.1 8 5.4 9.0 85 2.5 12 A 11.88 12.12 90 10 0.1 8 6.0 10.0 85 2.5 13 A 12.87 13.13 110 10 0.1 8 7.0 11.0 80 2.5 15 A 14.85 15.15 110 15 0.05 10.5 9.2 13.0 75 2.0 16 A 15.84 16.16 170 20 0.05 11.2 10.4 14.0 75 1.5 18 A 17.82 18.18 170 20 0.05 12.6 12.4 16.0 70 1.5 20 A 19.80 20.20 220 20 0.05 14 14.4 18.0 60 1.5 22 A 21.78 22.22 220 25 0.05 15.4 16.4 20.0 60 1.25 24 A 23.76 24.24 220 30 0.05 16.8 18.4 22.0 55 1.25 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 4 / 12 BZT52H-A series Nexperia Voltage regulator diodes Table 9. Characteristics per type; BZT52H-A27 to BZT52H-A51 Tj = 25 °C unless otherwise specified. BZT52H Sel -xxx Working voltage VZ (V); IZ = 2 mA Maximum differential resistance rdif (Ω) Reverse Temperature current IR (μA) coefficient SZ (mV/K); IZ = 2 mA Diode Non-repetitive capacitance peak reverse Cd (pF) [1] current IZSM (A) [2] Min IZ = 1 mA IZ = 5 mA Max VR (V) Min Max Max Max Max 27 A 26.73 27.27 250 40 0.05 18.9 21.4 25.3 50 1.0 30 A 29.70 30.30 250 40 0.05 21 24.4 29.4 50 1.0 33 A 32.67 33.33 250 40 0.05 23.1 27.4 33.4 45 0.9 36 A 35.64 36.36 250 60 0.05 25.2 30.4 37.4 45 0.8 39 A 38.61 39.39 300 75 0.05 27.3 33.4 41.2 45 0.7 43 A 42.57 43.43 325 80 0.05 30.1 37.6 46.6 40 0.6 47 A 46.53 47.47 325 90 0.05 32.9 42.0 51.8 40 0.5 51 A 50.49 51.51 350 100 0.05 35.7 46.6 57.2 40 0.4 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. Table 10. Characteristics per type; BZT52H-A56 to BZT52H-A75 Tj = 25 °C unless otherwise specified. BZT52H Sel -xxx Working voltage VZ (V); IZ = 2 mA Maximum differential resistance rdif (Ω) Min IZ = 0.5 mA IZ = 2 mA Max Max Reverse Temperature current IR (μA) coefficient SZ (mV/K); IZ = 2 mA Diode Non-repetitive capacitance peak reverse Cd (pF) [1] current IZSM (A) [2] VR (V) Min Max Max Max 56 A 55.44 56.56 375 120 0.05 39.2 52.2 63.8 40 0.3 62 A 61.38 62.62 400 140 0.05 43.4 58.8 71.6 35 0.3 68 A 67.32 68.68 400 160 0.05 47.6 65.6 79.8 35 0.25 75 A 74.25 75.75 400 175 0.05 52.5 73.4 88.6 35 0.20 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 BZT52H-A series Nexperia Voltage regulator diodes mbg801 103 PZSM (W) aaa-028550 103 IF (mA) 102 102 10 1 (1) 10-1 10 (2) 10-2 1 10- 1 1 tp (ms) 10 (1) Tj = 25 °C (before surge) (2) Tj = 150 °C (before surge) Fig. 1. aaa-028551 Fig. 2. 1 1 10-1 10-1 10-2 10-2 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 °C Fig. 3. Product data sheet 1.0 aaa-028552 0.6 0.8 VF (V) 1.0 Tj = 25 °C Forward current as a function of forward voltage; typical values (BZT52H-A6V8) BZT52H-A_SER VF (V) 103 IF (mA) 102 10 0.6 0.8 Forward current as a function of forward voltage; typical values (BZT52H-A2V4) 10 10-3 0.4 0.6 Tj = 25 °C Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values 103 IF (mA) 102 10-3 0.4 Fig. 4. Forward current as a function of forward voltage; typical values (BZT52H-A7V5) All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 BZT52H-A series Nexperia Voltage regulator diodes aaa-028553 103 IF (mA) 102 mld444 0.5 SZ (mV/K) 4V7 0 4V3 10 - 0.5 2V4 1 2V7 3V9 -1 10-1 10-3 0.4 0.6 0.8 VF (V) 3V3 3V0 -2 10- 1 1.0 Tj = 25 °C Fig. 5. 3V6 - 1.5 10-2 1 10 IZ (mA) 102 Tj = 25 °C to 150 °C Forward current as a function of forward voltage; typical values (BZT52H-A75) Fig. 6. mld445 12 IR (A) 15 SZ (mV/K) 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 8 4 0 Temperature coefficient as a function of working current; typical values (BZT52H-A2V4 to BZT52H-A4V7) aaa-006665 10-1 2V4 10-2 2V7 10-3 3V0 3V3 3V6 3V9 4V3 4V7 5V1 10-4 10-5 5V6 10-6 6V2 6V8 10-7 10-8 -4 10- 1 1 10 IZ (mA) 102 10-9 Tj = 25 °C to 150 °C Fig. 7. Product data sheet 2 4 6 VR (V) 8 Tj = 25 °C Temperature coefficient as a function of working current; typical values (BZT52H-A5V1 to BZT52H-A15) BZT52H-A_SER 0 Fig. 8. Reverse current as a function of reverse voltage; typical values (BZT52H-A2V4 to BZT52H-A6V8) All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 BZT52H-A series Nexperia Voltage regulator diodes IR (A) aaa-006666 10-1 IR (A) 7V5 10-2 10 12 15 18 22 8V2 10-3 aaa-006667 10-1 30 36 10-2 27 33 43 39 51 47 62 56 75 68 10-3 9V1 11 13 16 20 24 10-4 10-4 10-5 10-5 10-6 10-6 10-7 10-7 10-8 10-8 0 5 10 15 20 VR (V) 10-9 25 Tj = 25 °C Fig. 9. 20 40 60 VR (V) 80 Tj = 25 °C Reverse current as a function of reverse voltage; typical values (BZT52H-A7V5 to BZT52H-A24) Fig. 10. Reverse current as a function of reverse voltage; typical values (BZT52H-A27 to BZT52H-A75) 11. Package outline 1.7 1.5 1.2 1.0 1 0.55 0.35 3.6 3.4 2.7 2.5 2 0.70 0.55 Dimensions in mm 0.25 0.10 04-11-29 Fig. 11. Package outline SOD123F BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 BZT52H-A series Nexperia Voltage regulator diodes 12. Soldering Footprint information for reflow soldering of plastic surface-mounted, 2 leads package SOD123F 4.4 2.9 2.8 1.1 1.2 (2×) (2×) 2.1 1.6 1.1 (2×) 1.2 (2×) solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sod123f_fr Reflow soldering is the only recommended soldering method. Fig. 12. Reflow soldering footprint SOD123F BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 BZT52H-A series Nexperia Voltage regulator diodes 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BZT52H-A_SER v.1 Product data sheet - - BZT52H-A_SER Product data sheet 20220125 All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 BZT52H-A series Nexperia Voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BZT52H-A_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 BZT52H-A series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Package outline.......................................................... 8 12. Soldering..................................................................... 9 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 January 2022 BZT52H-A_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 January 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
BZT52H-A5V1X 价格&库存
很抱歉,暂时无法提供与“BZT52H-A5V1X”相匹配的价格&库存,您可以联系我们找货
