2PC4617
NPN general-purpose transistor
Rev. 05 — 17 November 2009
Product data sheet
1. Product profile
1.1 General description
NPN transistor in a SOT416 (SC-75) plastic package. The PNP complement is 2PA1774.
1.2 Features
Low current (max. 150 mA)
Low voltage (max. 50 V)
1.3 Applications
General-purpose switching and amplification in communication, Electronic Data
Processing (EDP) and consumer applications.
2. Pinning information
Table 1.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Symbol
3
3
1
1
2
2
sym021
3. Ordering information
Table 2.
Type number
2PC4617Q
2PC4617R
2PC4617S
Package
Name
Description
Version
SC-75
plastic surface mounted package; 3 leads
SOT416
2PC4617
NXP Semiconductors
4. Marking
Table 3.
Marking codes
Type number
Marking code
2PC4617Q
ZQ
2PC4617R
ZR
2PC4617S
ZS
5. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
VCEO
collector-base voltage
open emitter
60
V
collector-emitter voltage
open base
50
V
VEBO
emitter-base voltage
open collector
7
V
IC
collector current (DC)
150
mA
ICM
peak collector current
200
mA
IBM
peak base current
200
mA
Ptot
total power dissipation
150
mW
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
[1]
Tamb ≤ 25 °C
[1]
Transistor mounted on an FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint.
6. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-a)
[1]
Conditions
thermal resistance from
junction to ambient
Min
Typ
Max
Unit
833
K/W
2PC4617_5
Product data sheet
[1]
© NXP B.V. 2009. All rights reserved.
2 of 7
2PC4617
NXP Semiconductors
7. Characteristics
Table 6.
Characteristics
Tamb = 25 °C; unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base
cut-off current
IE = 0 A; VCB = 30 V
100
nA
IE = 0 A; VCB = 30 V;
Tj = 150 °C
5
μA
IEBO
emitter-base
cut-off current
IC = 0 A; VEB = 4 V
100
nA
hFE
DC current gain
IC = 1 mA; VCE = 6 V
2PC4617Q
120
270
2PC4617R
180
390
270
560
200
mV
1.5
pF
100
MHz
[1]
2PC4617S
VCEsat
collector-emitter
saturation
voltage
IC = 50 mA; IB = 5 mA
Cc
collector
capacitance
IE = ie = 0 A;
VCB = 12 V; f = 1 MHz
fT
transition
frequency
IC = 2 mA; VCE = 12 V;
f = 100 MHz
[1]
[1]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
2PC4617_5
Product data sheet
[1]
3 of 7
2PC4617
NXP Semiconductors
8. Package outline
Plastic surface-mounted package; 3 leads
SOT416
D
E
B
A
X
HE
v M A
3
Q
A
1
A1
2
e1
c
bp
w M B
Lp
e
detail X
1 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
0.95
0.60
0.1
0.30
0.15
0.25
0.10
1.8
1.4
0.9
0.7
1
0.5
1.75
1.45
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT416
Fig 1.
JEITA
SC-75
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
Package outline SOT416 (SC-75)
2PC4617_5
Product data sheet
4 of 7
2PC4617
NXP Semiconductors
9. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
2PC4617_5
20091117
Product data sheet
2PC4617_4
Modifications:
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
Figure 1 “Package outline SOT416 (SC-75)”: updated
2PC4617_4
20041125
Product data sheet
2PC4617_3
2PC4617_3
19990521
Product specification
2PC4617_2
2PC4617_2
19980721
2PC4617_1
2PC4617_1
19970709
2PC4617_5
Product data sheet
5 of 7
2PC4617
NXP Semiconductors
10. Legal information
10.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
10.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
10.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
10.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
11. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
2PC4617_5
Product data sheet
6 of 7
2PC4617
NXP Semiconductors
12. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
8
9
10
10.1
10.2
10.3
10.4
11
12
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .
Contact information. . . . . . . . . . . . . . . . . . . . . .
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1
1
1
1
1
1
2
2
2
3
4
5
6
6
6
6
6
6
7
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 17 November 2009
Document identifier: 2PC4617_5
很抱歉,暂时无法提供与“2PC4617Q,115”相匹配的价格&库存,您可以联系我们找货
