74LV574D,118
74LV574D,118
    NEXPERIA(安世)
    3.3V D-TYPE F/F POS EDGE 3-S
74LV574D,118 数据手册
74LV574 Octal D-type flip-flop; positive edge-trigger; 3-state Rev. 04 — 14 May 2009 Product data sheet 1. General description The 74LV574 is an octal D-type flip–flop featuring separate D-type inputs for each flip-flop and non-inverting 3-state outputs for bus oriented applications. A clock (CP) and an output enable (OE) input are common to all flip-flops. It is a low-voltage Si-gate CMOS device and is pin and functionally compatible with the 74HC574 and 74HCT574. The eight flip-flops will store the state of their individual D-inputs that meet the set-up and hold times requirements on the LOW to HIGH CP transition. When OE is LOW, the contents of the eight flip-flops is available at the outputs. When OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops. 2. Features n n n n n n n n n Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 °C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 °C ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V Common 3-state output enable input Multiple package options Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV574N −40 °C to +125 °C DIP20 plastic dual in-line package; 20 leads (300 mil) SOT146-1 74LV574D −40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LV574DB −40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74LV574PW −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 4. Functional diagram 11 1 C1 EN 11 2 3 4 5 6 7 8 9 2 CP D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 Q7 19 3 18 17 4 17 16 5 16 15 6 15 7 14 8 13 9 12 18 14 13 12 OE 1 Fig 1. 19 1D mna446 mna798 Logic symbol Fig 2. IEC logic symbol 2 D0 Q0 19 3 D1 Q1 18 4 D2 5 D3 6 D4 7 D5 Q5 14 8 D6 Q6 13 9 D7 Q7 12 Q2 17 FF1 to FF8 3-STATE OUTPUTS Q3 16 Q4 15 11 CP 1 OE mna800 Fig 3. Functional diagram 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 2 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state D0 D1 D Q D2 D CP Q D CP FF1 D3 Q D CP FF2 D4 Q D CP FF3 D5 Q D CP FF4 D7 D6 Q D CP FF5 Q D CP FF6 Q CP FF7 FF8 CP OE Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 mna801 Fig 4. Logic diagram 5. Pinning information 5.1 Pinning 74LV574 74LV574 OE 1 20 VCC OE 1 20 VCC D0 2 19 Q0 D0 2 19 Q0 D1 3 18 Q1 D1 3 18 Q1 D2 4 17 Q2 D2 4 17 Q2 D3 5 16 Q3 D3 5 16 Q3 D4 6 15 Q4 D4 6 15 Q4 D5 7 14 Q5 D5 7 14 Q5 D6 8 13 Q6 D6 8 13 Q6 D7 9 12 Q7 D7 9 12 Q7 GND 10 11 CP GND 10 11 CP 001aaj968 Fig 5. 001aaj969 Pin configuration DIP20, SO20 Fig 6. Pin configuration SSOP20, TSSOP20 5.2 Pin description Table 2. Pin description Symbol Pin Description OE 1 output enable input (active LOW) D0 to D7 2, 3, 4, 5, 6, 7, 8, 9 data input GND 10 ground (0 V) CP 11 clock input (LOW to HIGH; edge triggered) Q0 to Q7 19, 18, 17, 16, 15, 14, 13, 12 data output VCC 20 supply voltage 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 3 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 6. Functional description Table 3. Function table[1] Operating mode Input Internal flip-flop Output OE CP Dn Load and read register L ↑ l L ↑ h H H Load register and disable outputs H ↑ l L Z H ↑ h H Z [1] Qn L L H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW to HIGH CP transition L = LOW voltage level l = LOW voltage level one set-up time prior to the LOW to HIGH CP transition Z = high-impedance OFF-state ↑ = LOW to HIGH clock transition 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage −0.5 +7.0 V IIK input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] - ±50 mA IO output current VO = −0.5 V to (VCC + 0.5 V) - ±35 mA ICC supply current - 70 mA IGND ground current −70 - mA Tstg storage temperature −65 +150 °C DIP20 - 750 mW SO20, SSOP20 and TSSOP20 - 500 mW total power dissipation Ptot Tamb = −40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For DIP20 packages: above 70 °C the value of Ptot derates linearly with 12 mW/K. For SO20 packages: above 70 °C the value of Ptot derates linearly with 8 mW/K. For (T)SSOP20 packages: above 60 °C the value of Ptot derates linearly with 5.5 mW/K. 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 4 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply Conditions voltage[1] Min Typ Max Unit 1.0 3.3 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage −40 °C to +85 °C Conditions Min Max Min Max VCC = 1.2 V 0.9 - - 0.9 - V VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VI = VIH or VIL IO = −100 µA; VCC = 1.2 V - 1.2 - - - V IO = −100 µA; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = −100 µA; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = −100 µA; VCC = 3.0 V 2.8 3.0 - 2.8 - V IO = −100 µA; VCC = 4.5 V 4.3 4.5 - 4.3 - V IO = −8 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V IO = −16 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V 74LV574_4 Product data sheet −40 °C to +125 °C Unit Typ[1] © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 5 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL −40 °C to +85 °C Conditions LOW-level output voltage Min Typ[1] −40 °C to +125 °C Unit Max Min Max VI = VIH or VIL IO = 100 µA; VCC = 1.2 V - 0 - - - V IO = 100 µA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 µA; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 8 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 16 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 µA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 5 - 10 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20 - 160 µA ∆ICC additional supply current per input; VI = VCC − 0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 µA CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 °C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10. Symbol Parameter tpd −40 °C to +85 °C Conditions Max Min Max VCC = 1.2 V - 80 - - - ns VCC = 2.0 V - 27 34 - 43 ns [2] - 20 25 - 31 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 13 - - - ns VCC = 3.0 V to 3.6 V [3] - 15 20 - 25 ns - - 17 - 21 ns VCC = 1.2 V - 70 - - - ns VCC = 2.0 V - 24 34 - 43 ns - 18 25 - 31 ns - 13 20 - 25 ns - - 17 - 21 ns VCC = 4.5 V to 5.5 V enable time OE to Qn; see Figure 8 [4] VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V [3] 74LV574_4 Product data sheet Unit Min propagation delay CP to Qn; see Figure 7 VCC = 2.7 V ten −40 °C to +125 °C Typ[1] © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 6 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10. Symbol Parameter tdis disable time −40 °C to +85 °C Conditions pulse width Min VCC = 1.2 V - 75 - - - ns VCC = 2.0 V - 27 27 - 34 ns OE to Qn; Figure 8 21 - 26 ns VCC = 3.0 V to 3.6 V - 16 17 - 21 ns VCC = 4.5 V to 5.5 V [3] - - 15 - 18 ns 34 9 - 41 - ns 25 6 - 30 - ns 20 5 - 24 - ns VCC = 1.2 V - 10 - - - ns VCC = 2.0 V 22 4 - 26 - ns CP, HIGH or LOW; see Figure 7 [3] Dn to CP; see Figure 9 VCC = 2.7 V 16 3 - 19 - ns 13 2 - 15 - ns VCC = 1.2 V - −10 - - - ns VCC = 2.0 V 5 −4 - 5 - ns VCC = 2.7 V 5 −3 - 5 - ns 5 −2 - 5 - ns [3] VCC = 3.0 V to 3.6 V hold time Dn to CP; see Figure 9 [3] VCC = 3.0 V to 3.6 V maximum frequency fmax power dissipation capacitance CPD see Figure 7 VCC = 2.0 V 15 40 - 12 - MHz VCC = 2.7 V 19 58 - 16 - MHz 24 70 - 20 - MHz VCC = 3.0 V to 3.6 V [3] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [6] [1] Typical values are measured at Tamb = 25 °C. [2] tpd is the same as tPLH and tPHL. [3] Typical value measured at VCC = 3.3 V. [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPHZ and tPLZ. [6] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + ∑(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; ∑(CL × VCC2 × fo) = sum of outputs. 74LV574_4 Product data sheet Max 21 VCC = 3.0 V to 3.6 V th Min - VCC = 2.7 V set-up time Max [3] VCC = 2.0 V tsu Unit [5] VCC = 2.7 V tW −40 °C to +125 °C Typ[1] 25 pF © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 7 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 11. Waveforms 1/f max VI CP input VM GND tW t PHL t PLH VOH VM Qn output VOL mna894 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The clock (CP) to output (Qn) propagation delays, the clock pulse (CP) and the maximum clock pulse frequency VI OE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled mna644 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. Enable and disable times 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 8 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state VI VM CP input GND tsu tsu th th VI VM Dn input GND VOH VM Qn output VOL mna202 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. Table 8. The data set-up and hold times for the Dn input to the CP input) Measurement points Supply voltage Input Output VCC VM VM Vx Vy < 2.7 V 0.5VCC 0.5VCC VOL + 0.3 V VOH − 0.3 V 2.7 V to 3.6 V 1.5 V 1.5 V VOL + 0.3 V VOH − 0.3 V ≥ 4.5 V 0.5VCC 0.5VCC VOL + 0.3 V VOH − 0.3 V 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 9 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI RL VO G DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VCC VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ < 2.7 V VCC ≤ 2.5 ns 50 pF 1 kΩ open GND 2VCC 2.7 V to 3.6 V 2.7 V ≤ 2.5 ns 15 pF, 50 pF 1 kΩ open GND 2VCC ≥ 4.5 V VCC ≤ 2.5 ns 50 pF 1 kΩ open GND 2VCC 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 10 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 12. Package outline DIP20: plastic dual in-line package; 20 leads (300 mil) SOT146-1 ME seating plane D A2 A A1 L c e Z b1 w M (e 1) b MH 11 20 pin 1 index E 1 10 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 c mm 4.2 0.51 3.2 1.73 1.30 0.53 0.38 0.36 0.23 26.92 26.54 inches 0.17 0.02 0.13 0.068 0.051 0.021 0.015 0.014 0.009 1.060 1.045 D e e1 L ME MH w Z (1) max. 6.40 6.22 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 2 0.25 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.078 (1) E (1) Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. OUTLINE VERSION SOT146-1 REFERENCES IEC JEDEC JEITA MS-001 SC-603 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-13 Fig 11. Package outline SOT146-1 (DIP20) 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 11 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 12. Package outline SOT163-1 (SO20) 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 12 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 1 10 w M bp e detail X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8 o 0 o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 13. Package outline SOT339-1 (SSOP20) 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 13 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 14. Package outline SOT360-1 (TSSOP20) 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 14 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV574_4 20090514 Product data sheet - 74LV574_3 Modifications: • Typo removed from Figure 8 and Table 8 adapted accordingly 74LV574_3 20090416 Product data sheet - 74LV574_2 74LV574_2 19970203 Product specification - 74LV574_1 74LV574_1 19980610 Product specification - - 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 15 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74LV574_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 14 May 2009 16 of 17 74LV574 NXP Semiconductors Octal D-type flip-flop; positive edge-trigger; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 14 May 2009 Document identifier: 74LV574_4
74LV574D,118 价格&库存
很抱歉,暂时无法提供与“74LV574D,118”相匹配的价格&库存,您可以联系我们找货
