74LVC2T45GT
74LVC2T45GT
    NEXPERIA(安世)
    74LVC2T45GT
74LVC2T45GT 数据手册
74LVC2T45; 74LVCH2T45 Dual supply translating transceiver; 3-state Rev. 8 — 29 March 2013 Product data sheet 1. General description The 74LVC2T45; 74LVCH2T45 are dual bit, dual supply translating transceivers with 3-state outputs that enable bidirectional level translation. They feature two 2-bits input-output ports (nA and nB), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 1.2 V and 5.5 V making the device suitable for translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins nA and DIR are referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows transmission from nA to nB and a LOW on DIR allows transmission from nB to nA. The devices are fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A port and B port are in the high-impedance OFF-state. Active bus hold circuitry in the 74LVCH2T45 holds unused or floating data inputs at a valid logic level. 2. Features and benefits  Wide supply voltage range:  VCC(A): 1.2 V to 5.5 V  VCC(B): 1.2 V to 5.5 V  High noise immunity  Complies with JEDEC standards:  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8C (2.7 V to 3.6 V)  JESD36 (4.5 V to 5.5 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 4000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Maximum data rates:  420 Mbps (3.3 V to 5.0 V translation)  210 Mbps (translate to 3.3 V))  140 Mbps (translate to 2.5 V)  75 Mbps (translate to 1.8 V)  60 Mbps (translate to 1.5 V) 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state         Suspend mode Latch-up performance exceeds 100 mA per JESD 78 Class II 24 mA output drive (VCC = 3.0 V) Inputs accept voltages up to 5.5 V Low power consumption: 16 A maximum ICC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74LVC2T45DC Package Temperature range Name Description 40 C to +125 C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1  1.95  0.5 mm 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1  0.5 mm 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT996-2 8 terminals; body 3  2  0.5 mm 40 C to +125 C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6  1.6  0.5 mm SOT902-2 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2  1.0  0.35 mm SOT1116 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1.0  0.35 mm SOT1203 74LVCH2T45DC 74LVC2T45GT 74LVCH2T45GT 74LVC2T45GF 74LVCH2T45GF 74LVC2T45GD 74LVCH2T45GD 74LVC2T45GM 74LVCH2T45GM 74LVC2T45GN 74LVCH2T45GN 74LVC2T45GS 74LVCH2T45GS Version SOT1089 4. Marking Table 2. Marking Type number Marking code[1] 74LVC2T45DC V45 74LVCH2T45DC X45 74LVC2T45GT V45 74LVCH2T45GT X45 74LVC2T45GF V5 74LVCH2T45GF X5 74LVC2T45GD V45 74LVCH2T45GD X45 74LVC2T45GM V45 74LVCH2T45GM X45 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 2 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 2. Marking …continued Type number Marking code[1] 74LVC2T45GN V5 74LVCH2T45GN X5 74LVC2T45GS V5 74LVCH2T45GS X5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram DIR 5 DIR 1A 2 1A 7 1B 1B 2A 3 2A 6 2B 2B VCC(A) VCC(B) VCC(A) VCC(B) 001aag577 Fig 1. Logic symbol 001aag578 Fig 2. Logic diagram 6. Pinning information 6.1 Pinning 74LVC2T45 74LVCH2T45 VCC(A) 1 8 VCC(B) 1A 2 7 1B 2A 3 6 2B GND 4 5 DIR 74LVC2T45 74LVCH2T45 VCC(A) 1 8 VCC(B) 1A 2 7 1B 2A 3 6 2B GND 4 5 DIR 001aai905 Transparent top view 001aai904 Fig 3. Pin configuration SOT765-1 74LVC_LVCH2T45 Product data sheet Fig 4. Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 3 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state VCC(B) 74LVC2T45 74LVCH2T45 74LVC2T45 74LVCH2T45 1 8 VCC(B) 1A 2 7 1B 2A 3 6 2B GND 4 5 DIR 1 2B DIR 7 VCC(A) 2 6 1A 3 5 2A GND 4 VCC(A) 1B 8 terminal 1 index area 001aaj617 Transparent top view Transparent top view Fig 5. 001aai906 Pin configuration SOT996-2 Fig 6. Pin configuration SOT902-2 6.2 Pin description Table 3. Pin description Symbol Pin VCC(A) Description SOT765-1, SOT833-1, SOT1089, SOT996-2, SOT1116 and SOT1203 SOT902-2 1 7 supply voltage A (port A and DIR) 1A 2 6 data input or output 2A 3 5 data input or output GND 4 4 ground (0 V) DIR 5 3 direction control 2B 6 2 data input or output 1B 7 1 data input or output VCC(B) 8 8 supply voltage B (port B) 7. Functional description Table 4. Function table[1] Supply voltage Input Input/output[2] VCC(A), VCC(B) DIR nA nB 1.2 V to 5.5 V L nA = nB input 1.2 V to 5.5 V H input nB = nA GND[3] X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. [2] The input circuit of the data I/O is always active. [3] When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 4 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC(A) supply voltage A VCC(B) supply voltage B IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions VI < 0 V [1] Min Max Unit 0.5 +6.5 V 0.5 +6.5 V 50 - mA 0.5 +6.5 V mA 50 - [1][2][3] 0.5 VCCO + 0.5 V Suspend or 3-state mode [1] 0.5 +6.5 V [2] - 50 mA - 100 mA VO < 0 V Active mode IO output current VO = 0 V to VCCO ICC supply current ICC(A) or ICC(B) IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot [1] Tamb = 40 C to +125 C The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] VCCO is the supply voltage associated with the output port. [3] VCCO + 0.5 V should not exceed 6.5 V. [4] [4] For VSSOP8 packages: above 110 C the value of Ptot derates linearly with 8.0 mW/K. For XSON8 and XQFN8 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Min Max Unit VCC(A) supply voltage A Conditions 1.2 5.5 V VCC(B) supply voltage B 1.2 5.5 V VI input voltage 0 5.5 V output voltage VO Active mode [1] Suspend or 3-state mode Tamb t/V ambient temperature input transition rise and fall rate VCCI = 1.2 V V V 40 +125 C - 20 ns/V - 20 ns/V VCCI = 2.3 V to 2.7 V - 20 ns/V VCCI = 3 V to 3.6 V - 10 ns/V VCCI = 4.5 V to 5.5 V - 5 ns/V [1] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the input port. Product data sheet VCCO 5.5 VCCI = 1.4 V to 1.95 V [2] 74LVC_LVCH2T45 [2] 0 0 All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 5 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 10. Static characteristics Table 7. Typical static characteristics at Tamb = 25 C At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH HIGH-level output voltage Conditions LOW-level output voltage Typ Max Unit [1] - 1.09 - V [1] - 0.07 - V - - 1 A VI = VIH or VIL IO = 3 mA; VCCO = 1.2 V VOL Min VI = VIH or VIL IO = 3 mA; VCCO = 1.2 V II input leakage current DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V [2] IBHL bus hold LOW current A or B port; VI = 0.42 V; VCCI = 1.2 V [2] - 19 - A A or B port; VI = 0.78 V; VCCI = 1.2 V [2] - 19 - A - 19 - A IBHH bus hold HIGH current IBHLO bus hold LOW overdrive current A or B port; VCCI = 1.2 V [2][3] IBHHO bus hold HIGH overdrive current A or B port; VCCI = 1.2 V [2][3] - 19 - A IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V [1] - - 1 A IOFF power-off leakage current A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - - 1 A B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - - 1 A CI input capacitance DIR input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 2.2 - pF CI/O input/output capacitance A and B port; suspend mode; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 6.0 - pF [1] VCCO is the supply voltage associated with the output port. [2] VCCI is the supply voltage associated with the data input port. [3] To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 6 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage 40 C to +85 C Conditions 40 C to +125 C Unit Min Max Min Max VCCI = 1.2 V 0.8VCCI - 0.8VCCI - V VCCI = 1.4 V to 1.95 V 0.65VCCI - 0.65VCCI - V [1] data input VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCCI - 0.7VCCI - V VCCI = 1.2 V 0.8VCC(A) - 0.8VCC(A) - V VCCI = 1.4 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V 0.7VCC(A) - 0.7VCC(A) - V VCCI = 1.2 V - 0.2VCCI - 0.2VCCI V VCCI = 1.4 V to 1.95 V - 0.35VCCI - 0.35VCCI V DIR input VCCI = 4.5 V to 5.5 V VIL LOW-level input voltage [1] data input VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCCI - 0.3VCCI V DIR input VOH HIGH-level output voltage 74LVC_LVCH2T45 Product data sheet VCCI = 1.2 V - 0.2VCC(A) - 0.2VCC(A) V VCCI = 1.4 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCC(A) - VCCO  0.1 - VCCO  0.1 0.3VCC(A) V VI = VIH IO = 100 A; VCCO = 1.2 V to 4.5 V [2] - V IO = 6 mA; VCCO = 1.4 V 1.0 - 1.0 - V IO = 8 mA; VCCO = 1.65 V 1.2 - 1.2 - V IO = 12 mA; VCCO = 2.3 V 1.9 - 1.9 - V IO = 24 mA; VCCO = 3.0 V 2.4 - 2.4 - V IO = 32 mA; VCCO = 4.5 V 3.8 - 3.8 - V All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 7 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 8. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL LOW-level output voltage 40 C to +85 C Conditions Min Max Min Max IO = 100 A; VCCO = 1.2 V to 4.5 V - 0.1 - 0.1 V IO = 6 mA; VCCO = 1.4 V - 0.3 - 0.3 V IO = 8 mA; VCCO = 1.65 V - 0.45 - 0.45 V VI = VIL IO = 12 mA; VCCO = 2.3 V - 0.3 - 0.3 V IO = 24 mA; VCCO = 3.0 V - 0.55 - 0.55 V IO = 32 mA; VCCO = 4.5 V - 0.55 - 0.55 V - 2 - 10 A 15 - 10 - A 25 - 20 - A input leakage current IBHL bus hold LOW A or B port current VI = 0.49 V; VCCI = 1.4 V DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V [1] VI = 0.58 V; VCCI = 1.65 V VI = 0.70 V; VCCI = 2.3 V 45 - 45 - A VI = 0.80 V; VCCI = 3.0 V 100 - 80 - A 100 - 100 - A VI = 1.35 V; VCCI = 4.5 V bus hold HIGH A or B port current VI = 0.91 V; VCCI = 1.4 V [1] 15 - 10 - A VI = 1.07 V; VCCI = 1.65 V 25 - 20 - A VI = 1.60 V; VCCI = 2.3 V 45 - 45 - A VI = 2.00 V; VCCI = 3.0 V 100 - 80 - A 100 - 100 - A 125 - 125 - A 200 - 200 - A VCCI = 2.7 V 300 - 300 - A VCCI = 3.6 V 500 - 500 - A 900 - 900 - A 125 - 125 - A 200 - 200 - A VCCI = 2.7 V 300 - 300 - A VCCI = 3.6 V 500 - 500 - A 900 - 900 - A - 2 - 10 A VI = 3.15 V; VCCI = 4.5 V IBHLO [1][3] bus hold LOW A or B port overdrive VCCI = 1.6 V current VCCI = 1.95 V VCCI = 5.5 V IBHHO [1][3] bus hold HIGH A or B port overdrive VCCI = 1.6 V current VCCI = 1.95 V VCCI = 5.5 V IOZ OFF-state output current 74LVC_LVCH2T45 Product data sheet Unit [2] II IBHH 40 C to +125 C A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V [2] All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 8 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 8. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter IOFF power-off leakage current ICC supply current 40 C to +85 C Conditions 40 C to +125 C Unit Min Max Min Max A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - 2 - 10 A B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - 2 - 10 A VCC(A), VCC(B) = 1.2 V to 5.5 V - 8 - 8 A VCC(A), VCC(B) = 1.65 V to 5.5 V - 3 - 3 A VCC(A) = 5.5 V; VCC(B) = 0 V - 2 - 2 A VCC(A) = 0 V; VCC(B) = 5.5 V 2 - 2 - A - 8 - 8 A A port; VI = 0 V or VCCI; IO = 0 A [1] B port; VI = 0 V or VCCI; IO = 0 A VCC(A), VCC(B) = 1.2 V to 5.5 V - 3 - 3 A VCC(B) = 0 V; VCC(A) = 5.5 V 2 - 2 - A VCC(B) = 5.5 V; VCC(A) = 0 V - 2 - 2 A VCC(A), VCC(B) = 1.2 V to 5.5 V - 16 - 16 A VCC(A), VCC(B) = 1.65 V to 5.5 V - 4 - 4 A - 50 - 75 A - 50 - 75 A - 50 - 75 A VCC(A), VCC(B) = 1.65 V to 5.5 V A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI ICC additional per input; supply current VCC(A), VCC(B) = 3.0 V to 5.5 V A port; A port at VCC(A)  0.6 V; DIR at VCC(A); B port = open [4] DIR input; DIR at VCC(A)  0.6 V; A port at VCC(A) or GND; B port = open B port; B port at VCC(B)  0.6 V; DIR at GND; A port = open [1] VCCI is the supply voltage associated with the data input port. [2] VCCO is the supply voltage associated with the output port. [4] [3] To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. [4] For non bus hold parts only (74LVC2T45). 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 9 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 11. Dynamic characteristics Table 9. Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 C Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for waveforms see Figure 7 and Figure 8. Symbol Parameter tPLH tPHL tPHZ tPLZ [1] Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V A to B 10.6 8.1 7.0 5.8 5.3 5.1 ns B to A 10.6 9.5 9.0 8.5 8.3 8.2 ns HIGH to LOW propagation delay A to B 10.1 7.1 6.0 5.3 5.2 5.4 ns B to A 10.1 8.6 8.1 7.8 7.6 7.6 ns HIGH to OFF-state propagation delay DIR to A 9.4 9.4 9.4 9.4 9.4 9.4 ns DIR to B 12.0 9.4 9.0 7.8 8.4 7.9 ns LOW to OFF-state propagation delay DIR to A 7.1 7.1 7.1 7.1 7.1 7.1 ns OFF-state to LOW propagation delay tPZL VCC(B) LOW to HIGH propagation delay OFF-state to HIGH propagation delay tPZH Conditions DIR to B 9.5 7.8 7.7 6.9 7.6 7.0 ns DIR to A [1] 20.1 17.3 16.7 15.4 15.9 15.2 ns DIR to B [1] 17.7 15.2 14.1 12.9 12.4 12.2 ns DIR to A [1] 22.1 18.0 17.1 15.6 16.0 15.5 ns DIR to B [1] 19.5 16.5 15.4 14.7 14.6 14.8 ns tPZH and tPZL are calculated values using the formula shown in Section 14.4 “Enable times”. Table 10. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 C Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for waveforms see Figure 7 and Figure 8. Symbol Parameter tPLH tPHL tPHZ tPLZ [1] Unit 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V A to B 10.6 9.5 9.0 8.5 8.3 8.2 ns B to A 10.6 8.1 7.0 5.8 5.3 5.1 ns HIGH to LOW propagation delay A to B 10.1 8.6 8.1 7.8 7.6 7.6 ns B to A 10.1 7.1 6.0 5.3 5.2 5.4 ns HIGH to OFF-state propagation delay DIR to A 9.4 6.5 5.7 4.1 4.1 3.0 ns DIR to B 12.0 6.1 5.4 4.6 4.3 4.0 ns LOW to OFF-state propagation delay DIR to A 7.1 4.9 4.5 3.2 3.4 2.5 ns DIR to B 9.5 7.3 6.6 5.9 5.7 5.6 ns DIR to A [1] 20.1 15.4 13.6 11.7 11.0 10.7 ns DIR to B [1] 17.7 14.4 13.5 11.7 11.7 10.7 ns DIR to A [1] 22.1 13.2 11.4 9.9 9.5 9.4 ns DIR to B [1] 19.5 15.1 13.8 11.9 11.7 10.6 ns OFF-state to LOW propagation delay tPZL VCC(A) 1.2 V LOW to HIGH propagation delay OFF-state to HIGH propagation delay tPZH Conditions tPZH and tPZL are calculated values using the formula shown in Section 14.4 “Enable times”. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 10 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 C [1][2] Voltages are referenced to GND (ground = 0 V). Symbol Parameter power dissipation capacitance CPD [1] Conditions VCC(A) and VCC(B) Unit 1.8 V 2.5 V 3.3 V 5.0 V A port: (direction A to B); B port: (direction B to A) 2 3 3 4 pF A port: (direction B to A); B port: (direction A to B) 15 16 16 18 pF CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. [2] fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL =  . Table 12. Dynamic characteristics for temperature range 40 C to +85 C Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V tPLH LOW to HIGH propagation delay A to B 2.8 21.3 2.4 17.6 2.0 13.5 1.7 11.8 1.6 10.5 ns B to A 2.8 21.3 2.6 19.1 2.3 14.9 2.3 12.4 2.2 12.0 ns tPHL HIGH to LOW propagation delay A to B 2.6 19.3 2.2 15.3 1.8 11.8 1.7 10.9 1.7 10.8 ns B to A 2.6 19.3 2.4 17.3 2.3 13.2 2.2 11.3 2.3 11.0 3.0 18.7 ns ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 3.0 18.7 3.0 18.7 3.0 18.7 3.0 18.7 3.5 24.8 3.5 23.6 3.0 11.0 3.3 11.3 2.8 10.3 ns tPLZ LOW to OFF-state propagation delay 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 ns 9.4 ns tPZH tPZL DIR to A DIR to B 2.8 18.3 3.0 17.2 2.5 9.4 3.0 10.1 2.5 OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 39.6 - 36.3 - 24.3 - 22.5 - 21.4 ns [1] - 32.7 - 29.0 - 24.9 - 23.2 - 21.9 ns OFF-state to LOW propagation delay DIR to A [1] - 44.1 - 40.9 - 24.2 - 22.6 - 21.3 ns DIR to B [1] - 38.0 - 34.0 - 30.5 - 29.6 - 29.5 ns VCC(A) = 1.65 V to 1.95 V tPLH tPHL tPHZ tPLZ LOW to HIGH propagation delay A to B 2.6 19.1 2.2 17.7 2.2 9.3 1.7 7.2 1.4 6.8 B to A 2.4 17.6 2.2 17.7 2.3 16.0 2.1 15.5 1.9 15.1 ns HIGH to LOW propagation delay A to B 2.4 17.3 2.0 14.3 1.6 8.5 1.8 7.1 1.7 7.0 B to A 2.2 15.3 2.0 14.3 2.1 12.9 2.0 12.6 1.8 12.2 ns HIGH to OFF-state DIR to A propagation delay DIR to B 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 ns 3.2 24.1 3.2 21.9 2.7 11.5 3.0 10.3 2.5 8.2 LOW to OFF-state propagation delay DIR to A 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 ns DIR to B 2.5 17.6 2.6 16.0 2.2 9.2 2.7 8.4 2.4 7.1 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 ns ns ns ns © NXP B.V. 2013. All rights reserved. 11 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 12. Dynamic characteristics for temperature range 40 C to +85 C …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V tPZH tPZL Min Max Min Max Min Max Min Max Min OFF-state to HIGH DIR to A propagation delay DIR to B [1] Max - 35.2 - 33.7 - 25.2 - 23.9 - 22.2 ns [1] - 29.6 - 28.2 - 19.8 - 17.7 - 17.3 ns OFF-state to LOW propagation delay DIR to A [1] - 39.4 - 36.2 - 24.4 - 22.9 - 20.4 ns DIR to B [1] - 34.4 - 31.4 - 25.6 - 24.2 - 24.1 ns VCC(A) = 2.3 V to 2.7 V LOW to HIGH propagation delay A to B 2.3 17.9 2.3 16.0 1.5 8.5 1.3 6.2 1.1 4.8 ns B to A 2.0 13.5 2.2 9.3 1.5 8.5 1.4 8.0 1.0 7.5 ns tPHL HIGH to LOW propagation delay A to B 2.3 15.8 2.1 12.9 1.4 7.5 1.3 5.4 0.9 4.6 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B tPLH B to A 11.8 1.9 8.5 1.4 7.5 1.3 7.0 0.9 6.2 ns 8.1 2.1 8.1 2.1 8.1 2.1 8.1 2.1 8.1 ns 3.0 22.5 3.0 21.4 2.5 11.0 2.8 9.3 2.3 6.9 ns 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 ns 5.8 ns tPLZ LOW to OFF-state propagation delay 2.3 14.6 2.5 13.2 2.0 9.0 2.5 8.4 1.8 tPZH OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 28.1 - 22.5 - 17.5 - 16.4 - 13.3 ns [1] - 23.7 - 21.8 - 14.3 - 12.0 - 10.6 ns OFF-state to LOW propagation delay DIR to A [1] - 34.3 - 29.9 - 18.5 - 16.3 - 13.1 ns DIR to B [1] - 23.9 - 21.0 - 15.6 - 13.5 - 12.7 ns tPZL DIR to A 1.8 2.1 DIR to B VCC(A) = 3.0 V to 3.6 V tPLH tPHL tPHZ tPLZ tPZH tPZL LOW to HIGH propagation delay A to B 2.3 17.1 2.1 15.5 1.4 8.0 0.8 5.6 0.7 4.4 ns B to A 1.7 11.8 1.7 7.2 1.3 6.2 0.7 5.6 0.6 5.4 ns HIGH to LOW propagation delay A to B 2.2 15.6 2.0 12.6 1.3 7.0 0.8 5.0 0.7 4.0 ns B to A 1.7 10.9 1.8 7.1 1.3 5.4 0.8 5.0 0.7 4.5 ns HIGH to OFF-state DIR to A propagation delay DIR to B 2.3 7.3 2.3 7.3 2.3 7.3 2.3 7.3 2.7 7.3 ns 2.9 18.0 2.9 16.5 2.3 10.1 2.7 8.6 2.2 6.3 ns LOW to OFF-state propagation delay DIR to A 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 ns DIR to B 2.3 13.6 2.4 12.5 1.9 7.8 2.3 7.1 1.7 4.9 ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 25.4 - 19.7 - 14.0 - 12.7 - 10.3 ns [1] - 22.7 - 21.1 - 13.6 - 11.2 - 10.0 ns OFF-state to LOW propagation delay DIR to A [1] - 28.9 - 23.6 - 15.5 - 13.6 - 10.8 ns DIR to B [1] - 22.9 - 19.9 - 14.3 - 12.3 - 11.3 ns 15.1 1.0 7.5 0.7 5.4 0.5 3.9 ns VCC(A) = 4.5 V to 5.5 V tPLH LOW to HIGH propagation delay A to B 2.2 16.6 1.9 B to A 1.6 10.5 1.4 6.8 1.0 4.8 0.7 4.4 0.5 3.9 ns tPHL HIGH to LOW propagation delay A to B 2.3 15.3 1.8 12.2 1.0 6.2 0.7 4.5 0.5 3.5 ns B to A 1.7 10.8 1.7 7.0 0.9 4.6 0.7 4.0 0.5 3.5 ns 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 ns 2.9 17.3 2.9 16.1 2.3 9.7 2.7 8.0 2.5 5.7 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 12 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 12. Dynamic characteristics for temperature range 40 C to +85 C …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V Min tPLZ tPZH tPZL [1] LOW to OFF-state propagation delay Max Min Max Min Max Min Max Min Max DIR to A 1.4 3.7 1.4 3.7 1.3 3.7 1.0 3.7 0.9 3.7 ns DIR to B 2.3 13.1 2.4 12.1 1.9 7.4 2.3 7.0 1.8 4.5 ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 23.6 - 18.9 - 12.2 - 11.4 - 8.4 ns [1] - 20.3 - 18.8 - 11.2 - 9.1 - 7.6 ns OFF-state to LOW propagation delay DIR to A [1] - 28.1 - 23.1 - 14.3 - 12.0 - 9.2 ns DIR to B [1] - 20.7 - 17.6 - 11.6 - 9.9 - 8.9 ns tPZH and tPZL are calculated values using the formula shown in Section 14.4 “Enable times”. Table 13. Dynamic characteristics for temperature range 40 C to +125 C Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V tPLH tPHL tPHZ tPLZ tPZH tPZL LOW to HIGH propagation delay A to B 2.5 23.5 2.1 19.4 1.8 14.9 1.5 13.0 1.4 11.6 B to A 2.5 23.5 2.3 21.1 2.0 16.4 2.0 13.7 1.9 13.2 ns HIGH to LOW propagation delay A to B 2.3 21.3 1.9 16.9 1.6 13.0 1.5 12.0 1.5 11.9 B to A 2.3 21.3 2.1 19.1 2.0 14.6 1.9 12.5 2.0 12.1 ns 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 ns 3.1 27.3 3.1 26.0 2.7 12.1 2.9 12.5 2.5 11.4 DIR to A 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 ns DIR to B 2.5 20.2 2.7 19.0 2.2 10.4 2.7 11.2 2.2 10.4 ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 43.7 - 40.1 - 26.8 - 24.9 - 23.6 ns [1] - 36.1 - 32.0 - 27.5 - 25.6 - 24.2 ns OFF-state to LOW propagation delay DIR to A [1] - 48.6 - 45.1 - 26.7 - 25.0 - 23.5 ns DIR to B [1] - 41.9 - 37.5 - 33.6 - 32.6 - 32.5 ns 19.5 1.9 10.3 1.5 8.0 1.2 7.5 HIGH to OFF-state DIR to A propagation delay DIR to B LOW to OFF-state propagation delay ns ns ns VCC(A) = 1.65 V to 1.95 V tPLH LOW to HIGH propagation delay A to B 2.3 21.1 1.9 B to A 2.1 19.4 1.9 19.5 2.0 17.6 1.8 17.1 1.7 16.7 ns tPHL HIGH to LOW propagation delay A to B 2.1 19.1 1.8 15.8 1.4 9.4 1.6 7.9 1.5 7.7 B to A 1.9 16.9 1.8 15.8 1.8 14.2 1.8 13.9 1.6 13.5 ns 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 ns 2.8 26.6 2.8 24.1 2.4 12.7 2.7 11.4 2.2 9.1 ns 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 ns 7.9 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B tPLZ LOW to OFF-state propagation delay tPZH DIR to A DIR to B OFF-state to HIGH DIR to A propagation delay DIR to B 74LVC_LVCH2T45 Product data sheet ns ns 2.2 19.4 2.3 17.6 1.9 10.2 2.4 9.3 2.1 [1] - 38.8 - 37.1 - 27.8 - 26.4 - 24.6 ns [1] - 32.7 - 31.1 - 21.9 - 19.6 - 19.1 ns All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 13 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 13. Dynamic characteristics for temperature range 40 C to +125 C …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V tPZL OFF-state to LOW propagation delay Min Max Min Max Min Max Min Max Min DIR to A [1] Max - 43.5 - 39.9 - 26.9 - 25.3 - 22.6 ns DIR to B [1] - 38.0 - 34.7 - 28.3 - 26.8 - 26.6 ns VCC(A) = 2.3 V to 2.7 V tPLH LOW to HIGH propagation delay A to B 2.0 19.7 2.0 17.6 1.3 9.4 1.1 6.9 0.9 5.3 ns B to A 1.8 14.9 1.9 10.3 1.3 9.4 1.2 8.8 0.9 8.3 ns tPHL HIGH to LOW propagation delay A to B 2.0 17.4 1.8 14.2 1.2 8.3 1.1 6.0 0.8 5.1 ns B to A 1.6 13.0 1.7 9.4 1.2 8.3 1.1 7.7 0.8 6.9 ns 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 ns 2.7 24.8 2.7 23.6 2.2 12.1 2.5 10.3 2.0 7.6 ns 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 ns 6.4 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B tPLZ LOW to OFF-state propagation delay tPZH tPZL DIR to A DIR to B 2.0 16.1 2.2 14.6 1.8 9.9 2.2 9.3 1.6 OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 31.0 - 24.9 - 19.3 - 18.1 - [1] - 26.1 - 24.0 - 15.8 - 13.3 - 11.7 OFF-state to LOW propagation delay DIR to A [1] - 37.8 - 33.0 - 20.4 - 18.0 - 14.5 ns DIR to B [1] - 26.4 - 23.2 - 17.3 - 15.0 - 14.1 ns 14.7 ns ns VCC(A) = 3.0 V to 3.6 V tPLH tPHL tPHZ tPLZ tPZH tPZL LOW to HIGH propagation delay A to B 2.0 18.9 1.8 17.1 1.2 8.8 0.7 6.2 0.6 4.9 ns B to A 1.5 13.0 1.5 8.0 1.1 6.9 0.6 6.2 0.5 6.0 ns HIGH to LOW propagation delay A to B 1.9 17.2 1.8 13.9 1.1 7.7 0.7 5.5 0.6 4.4 ns B to A 1.5 12.0 1.6 7.9 1.1 6.0 0.7 5.5 0.6 5.0 ns HIGH to OFF-state DIR to A propagation delay DIR to B LOW to OFF-state propagation delay DIR to A DIR to B 2.0 8.1 2.0 8.1 2.0 8.1 2.0 8.1 2.4 8.1 ns 2.6 19.8 2.6 18.2 2.0 11.2 2.4 9.5 1.9 7.0 ns 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 ns 2.0 15.0 2.1 13.8 1.7 8.6 2.0 7.9 1.5 5.4 ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 28.0 - 21.8 - 15.5 - 14.1 - 11.4 ns [1] - 25.1 - 23.3 - 15.0 - 12.4 - 11.1 ns OFF-state to LOW propagation delay DIR to A [1] - 31.8 - 26.1 - 17.2 - 15.0 - 12.0 ns DIR to B [1] - 25.3 - 22.0 - 15.8 - 13.6 - 12.5 ns VCC(A) = 4.5 V to 5.5 V LOW to HIGH propagation delay A to B 1.9 18.3 1.7 16.7 0.9 8.3 0.6 6.0 0.4 4.3 ns B to A 1.4 11.6 1.2 7.5 0.9 5.3 0.6 4.9 0.4 4.3 ns tPHL HIGH to LOW propagation delay A to B 2.0 16.9 1.6 13.5 0.9 6.9 0.6 5.0 0.4 3.9 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B tPLH tPLZ LOW to OFF-state propagation delay 74LVC_LVCH2T45 Product data sheet B to A 1.5 11.9 1.5 7.7 0.8 5.1 0.6 4.4 0.4 3.9 ns 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 ns 2.6 19.1 2.6 17.8 2.0 10.7 2.4 8.8 2.2 6.3 ns DIR to A 1.2 4.1 1.2 4.1 1.1 4.1 0.9 4.1 0.8 4.1 ns DIR to B 2.0 14.5 2.1 13.4 1.7 8.2 2.0 7.7 1.6 5.0 ns All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 14 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 13. Dynamic characteristics for temperature range 40 C to +125 C …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8. Symbol Parameter Conditions VCC(B) Unit 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V 5.0 V  0.5 V tPZH tPZL [1] Min Max Min Max Min Max Min Max Min Max OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 26.1 - 20.9 - 13.5 - 12.6 - 9.3 ns [1] - 22.4 - 20.8 - 12.4 - 10.1 - 8.4 ns OFF-state to LOW propagation delay DIR to A [1] - 31.0 - 25.5 - 15.8 - 13.2 - 10.2 ns DIR to B [1] - 22.9 - 19.5 - 12.9 - 11.0 - 9.9 ns tPZH and tPZL are calculated values using the formula shown in Section 14.4 “Enable times”. 12. Waveforms VI VM nA, nB input GND tPLH tPHL VOH VM nB, nA output 001aaj644 VOL Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The data input (A, B) to output (B, A) propagation delay times VI DIR input VM GND t PLZ output LOW-to-OFF OFF-to-LOW t PZL VCCO VM VX VOL t PHZ VOH t PZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled 001aae968 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. Enable and disable times 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 15 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state Table 14. Measurement points Supply voltage Input[1] Output[2] VCC(A), VCC(B) VM VM VX VY 1.2 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH  0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH  0.15 V 3.0 V to 5.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH  0.3 V [1] VCCI is the supply voltage associated with the data input port. [2] VCCO is the supply voltage associated with the output port. tW VI 90 % negative pulse VM VM 10 % 0V tf tr tr tf VI 90 % positive pulse VM VM 10 % 0V tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 15. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig 9. Table 15. Test circuit for measuring switching times Test data Supply voltage Input VCC(A), VCC(B) VI[1] t/V[2] CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ[3] 1.2 V to 5.5 V VCCI  1.0 ns/V 15 pF 2 k open GND 2VCCO [1] Load VEXT VCCI is the supply voltage associated with the data input port. [2] dV/dt  1.0 V/ns. [3] VCCO is the supply voltage associated with the output port. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 16 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 13. Typical propagation delay characteristics 001aai907 14 tPHL (ns) 12 001aai908 14 tPLH (ns) 12 (1) (1) 10 10 (2) 8 (2) 8 (3) 6 (3) (4) (5) (6) 6 (4) (5) (6) 4 4 2 2 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai909 14 tPHL (ns) 12 0 5 10 15 20 25 35 30 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai910 14 tPLH (ns) 12 (1) (1) 10 (2) (3) 10 8 (4) (5) (6) 8 (2) (3) (4) (5) 6 6 4 4 2 2 0 (6) 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 10. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.2 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 17 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 001aai911 14 tPHL (ns) 12 001aai912 14 tPLH (ns) 12 (1) 10 10 (1) 8 8 (2) (2) (3) 6 6 (3) (4) (5) (6) (4) 4 4 (5) 2 2 (6) 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai913 14 tPHL (ns) 12 10 0 5 10 15 20 25 35 30 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai914 14 tPLH (ns) 12 10 (1) 8 (1) 8 6 (2) (3) (4) 6 (2) (3) (4) (5) (5) (6) (6) 4 4 2 2 0 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 11. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.5 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 18 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 001aai915 14 tPHL (ns) 12 001aai916 14 tPLH (ns) 12 (1) 10 10 (1) 8 8 (2) (2) 6 6 (3) 4 (4) (5) (6) (3) (4) 4 (5) (6) 2 2 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai917 14 tPHL (ns) 12 10 0 5 10 15 20 25 35 30 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai918 14 tPLH (ns) 12 10 8 8 (1) (1) 6 4 (2) (3) (4) (5) (6) 6 (2) (3) (4) (5) (6) 4 2 2 0 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 12. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.8 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 19 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 001aai919 14 tPHL (ns) 12 10 001aai920 14 tPLH (ns) 12 (1) 10 (1) 8 8 (2) (2) 6 6 (3) (3) 4 (4) (5) (6) 4 (4) (5) (6) 2 2 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai921 14 tPHL (ns) 12 0 8 8 20 25 (2) (3) (4) (5) (6) 35 30 CL (pF) 001aai922 (1) 6 (1) 2 15 14 tPLH (ns) 12 10 4 10 b. LOW to HIGH propagation delay (A to B) 10 6 5 (2) (3) (4) (5) (6) 4 2 0 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 13. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 2.5 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 20 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 001aai923 14 tPHL (ns) 12 10 001aai924 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) (2) 6 6 (3) (3) 4 4 (4) (5) (6) 2 (4) (5) (6) 2 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai925 14 tPHL (ns) 12 0 8 8 (2) (3) (4) (5) (6) 4 2 0 15 20 25 35 30 CL (pF) 001aai926 14 tPLH (ns) 12 10 (1) 10 b. LOW to HIGH propagation delay (A to B) 10 6 5 6 (1) 4 (2) (3) 2 (4) (5) (6) 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 14. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 3.3 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 21 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 001aai927 14 tPHL (ns) 12 10 001aai928 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) 6 (2) 6 (3) (3) 4 4 (4) (5) (6) 2 (4) (5) (6) 2 0 0 0 5 10 15 20 25 35 30 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai929 14 tPHL (ns) 12 0 5 10 15 20 25 35 30 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai930 14 tPLH (ns) 12 10 10 8 8 6 (1) 6 4 (2) (3) 4 (2) (3) 2 (4) (5) (6) 2 (4) (5) (6) 0 (1) 0 0 5 10 15 20 25 35 30 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 5 10 15 20 25 35 30 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig 15. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 5 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 22 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state 14. Application information 14.1 Unidirectional logic level-shifting application The circuit given in Figure 16 is an example of the 74LVC2T45; 74LVCH2T45 being used in a unidirectional logic level-shifting application. VCC1 VCC1 VCC2 VCC(A) 1A 1 8 VCC(B) VCC2 1B 2 74LVC2T45 7 2A 2B 74LVCH2T45 3 6 VCC1 GND 4 5 DIR system-1 VCC2 system-2 001aai931 Fig 16. Unidirectional logic level-shifting application Table 16. Description of unidirectional logic level-shifting application Pin Name Function Description 1 VCC(A) VCC1 supply voltage of system-1 (1.2 V to 5.5 V) 2 1A OUT output level depends on VCC1 voltage 3 2A OUT output level depends on VCC1 voltage 4 GND GND device GND 5 DIR DIR the GND (LOW level) determines B port to A port direction 6 2B IN input threshold value depends on VCC2 voltage 7 1B IN input threshold value depends on VCC2 voltage 8 VCC(B) VCC2 supply voltage of system-2 (1.2 V to 5.5 V) 14.2 Bidirectional logic level-shifting application Figure 17 shows the 74LVC2T45; 74LVCH2T45 being used in a bidirectional logic level-shifting application. Since the device does not have an output enable pin, the system designer should take precautions to avoid bus contention between system-1 and system-2 when changing directions. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 29 March 2013 © NXP B.V. 2013. All rights reserved. 23 of 36 74LVC2T45; 74LVCH2T45 NXP Semiconductors Dual supply translating transceiver; 3-state VCC1 VCC1 I/O-1 VCC(A) PULL-UP/DOWN VCC2 VCC2 1A 2A GND 1 8 VCC(B) PULL-UP/DOWN I/O-2 1B 2 74LVC2T45 7 2B 74LVCH2T45 3 6 4 5 DIR DIR CTRL DIR CTRL system-1 system-2 001aai932 Pull-up or pull-down only needed for 74LVC2T45. Fig 17. Bidirectional logic level-shifting application Table 17 gives a sequence that will illustrate data transmission from system-1 to system-2 and then from system-2 to system-1. Description of bidirectional logic level-shifting application[1] Table 17. State DIR CTRL I/O-1 I/O-2 Description 1 H output input system-1 data to system-2 2 H Z Z system-2 is getting ready to send data to system-1. I/O-1 and I/O-2 are disabled. The bus-line state depends on bus hold 3 L Z Z DIR bit is set LOW. I/O-1 and I/O-2 still are disabled. The bus-line state depends on bus hold 4 L input output system-2 data to system-1 [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 14.3 Power-up considerations The device is designed such that no special power-up sequence is required other than GND being applied first. Table 18. Typical total supply current (ICC(A) + ICC(B)) VCC(A) VCC(B) Unit 0V 1.8 V 2.5 V 3.3 V 5.0 V 0V 0
74LVC2T45GT 价格&库存
很抱歉,暂时无法提供与“74LVC2T45GT”相匹配的价格&库存,您可以联系我们找货
