HEF4516BT,652
HEF4516BT,652
    NEXPERIA(安世)
    HEF4516BT/SO16/TUBE-BULK//
HEF4516BT,652 数据手册
HEF4516B Binary up/down counter Rev. 7 — 11 November 2011 Product data sheet 1. General description The HEF4516B is an edge-triggered synchronous 4-bit binary up/down counter with a clock input (CP), an up/down count control input (UP/DN), an active LOW count enable input (CE), an asynchronous active HIGH parallel load input (PL), four parallel inputs (D0 to D3), four parallel outputs (Q0 to Q3), an active LOW terminal count output (TC), and an overriding asynchronous master reset input (MR). Information on D0 to D3 is loaded into the counter while PL is HIGH, independent of all other input conditions except for MR which must be LOW. When PL and CE are LOW, the counter changes on the LOW-to-HIGH transition of CP. Input UP/DN determines the direction of the count, counting up when HIGH and counting down when LOW. When counting up, TC is LOW when Q0 and Q3 are HIGH and CE is LOW. When counting down, TC is LOW when Q0 to Q3 and CE are LOW. A HIGH on MR resets the counter (Q0 to Q3 = LOW) independent of all other input conditions. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number Package Name Description Version HEF4516BP DIP16 plastic dual in-line package; 16-leads (300 mil) SOT38-4 HEF4516BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4516B NXP Semiconductors Binary up/down counter 4. Functional diagram 4 12 D0 1 15 5 10 9 PL CP 3 D2 D3 PARALLEL LOAD CIRCUITRY SD/CD CE MR TC UP/DOWN COUNTER UP/DN 7 CD Q0 6 Fig 1. D1 13 Q1 11 Q2 14 Q3 2 001aae667 Functional diagram HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 2 of 17 HEF4516B NXP Semiconductors Binary up/down counter D1 D2 D3 D4 MR PL CP UP/DN J SD Q J FF1 CE CD Q J FF2 CP K SD K CD J Q K Q1 TC CD SD Q FF4 CP Q0 Fig 2. Q FF3 CP Q SD CP Q K Q2 CD Q Q3 001aaj798 Logic diagram HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 3 of 17 HEF4516B NXP Semiconductors Binary up/down counter 5. Pinning information 5.1 Pinning HEF4516B PL 1 16 VDD Q3 2 15 CP D3 3 14 Q2 D0 4 13 D2 CE 5 12 D1 Q0 6 11 Q1 TC 7 10 UP/DN VSS 8 9 MR 001aae689 Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description PL 1 parallel load input (active HIGH) D0 to D3 4, 12, 13, 3 parallel input CE 5 count enable input (active LOW) Q0 to Q3 6, 11, 14, 2 parallel output VSS 8 ground supply voltage TC 7 terminal count output (active LOW) MR 9 master reset input UP/DN 10 up/down count control input CP 15 clock pulse input (LOW to HIGH, edge triggered) VDD 16 supply voltage HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 4 of 17 HEF4516B NXP Semiconductors Binary up/down counter 6. Functional description Table 3. Function table[1] MR PL UP/DN CE CP MODE L H X X X parallel load L L X H X no change L L L L  count down L L H L  count up H X X X X reset [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = positive-going transition. CP CE UP/DN MR PL VDD D0 D1 VSS D2 D3 Q0 Q1 Q2 Q3 TC count 5 6 7 8 9 10 11 12 13 14 15 9 8 7 6 5 4 3 2 1 0 0 15 0 001aae693 Fig 4. Timing diagram HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 5 of 17 HEF4516B NXP Semiconductors Binary up/down counter 0 1 2 3 4 15 5 14 6 13 7 11 12 10 count up count down 9 8 001aae692 Logic equation for terminal count: TC = CE    UP  DN   Q0  Q1  Q2  Q3 +  UP  DN   Q0  Q1  Q2  Q3  . Fig 5. State diagram 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions Min Max Unit 0.5 +18 V VI < 0.5 V or VI > VDD + 0.5 V - 10 mA 0.5 VDD + 0.5 V - 10 mA VO < 0.5 V or VO > VDD + 0.5 V II/O input/output current - 10 mA IDD supply current - 50 mA Tstg storage temperature 65 +150 C Tamb ambient temperature total power dissipation Ptot P power dissipation 40 +85 C DIP16 package [1] - 750 mW SO16 package [2] - 500 mW - 100 mW per output [1] For DIP16 package: Ptot derates linearly with 12 mW/K above 70 C. [2] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Typ Max Unit VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature 40 - +85 C HEF4516B Product data sheet Conditions in free air All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 6 of 17 HEF4516B NXP Semiconductors Binary up/down counter Table 5. Recommended operating conditions …continued Symbol Parameter Conditions Min Typ Max Unit t/V input transition rise and fall rate VDD = 5 V - - 3.75 s/V VDD = 10 V - - 0.5 s/V VDD = 15 V - - 0.08 s/V 9. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage Conditions Tamb = 25 C Tamb = 85 C Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V VDD IO < 1 A IO < 1 A HIGH-level output voltage IO < 1 A; VI = VSS or VDD Tamb = 40 C Unit 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V HIGH-level output current VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 mA VO = 4.6 V 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA LOW-level output voltage LOW-level output current IO < 1 A; VI = VSS or VDD VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA II input leakage current VDD = 15 V 15 V - 0.3 - 0.3 - 1.0 A IDD supply current IO = 0 A; VI = VSS or VDD 5V - 20 - 20 - 150 A 10 V - 40 - 40 - 300 A 15 V - 80 - 80 - 600 A - - - - 7.5 - - pF CI input capacitance HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 7 of 17 HEF4516B NXP Semiconductors Binary up/down counter 10. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 C; for test circuit see Figure 8; unless otherwise specified. Symbol tPHL Parameter HIGH to LOW propagation delay Conditions CP to Qn CP to TC PL to Qn PL to TC CE to TC MR to Qn, TC VDD Extrapolation formula Min Typ Max Unit 118 ns + (0.55 ns/pF)CL - 145 290 ns 10 V 49 ns + (0.23 ns/pF)CL - 60 120 ns 15 V 37 ns + (0.16 ns/pF)CL - 45 90 ns 5V 233 ns + (0.55 ns/pF)CL - 260 525 ns 10 V 94 ns + (0.23 ns/pF)CL - 105 210 ns 15 V 67 ns + (0.16 ns/pF)CL - 75 150 ns 5V 98 ns + (0.55 ns/pF)CL - 125 255 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 85 ns 5V [1] 5V 223 ns + (0.55 ns/pF)CL - 250 500 ns 10 V 99 ns + (0.23 ns/pF)CL - 110 220 ns 15 V 72 ns + (0.16 ns/pF)CL - 80 160 ns 5V 138 ns + (0.55 ns/pF)CL - 165 330 ns 10 V 54 ns + (0.23 ns/pF)CL - 65 135 ns 15 V 42 ns + (0.16 ns/pF)CL - 50 100 ns 5V 178 ns + (0.55 ns/pF)CL - 205 405 ns 10 V 54 ns + (0.23 ns/pF)CL - 65 130 ns 37 ns + (0.16 ns/pF)CL - 45 85 ns 128 ns + (0.55 ns/pF)CL - 155 310 ns 10 V 54 ns + (0.23 ns/pF)CL - 65 130 ns 15 V 37 ns + (0.16 ns/pF)CL - 45 90 ns 15 V tPLH LOW to HIGH propagation delay CP to Qn CP to TC PL to Qn PL to TC CE to TC MR to TC HEF4516B Product data sheet 5V [1] 5V 153 ns + (0.55 ns/pF)CL - 180 360 ns 10 V 64 ns + (0.23 ns/pF)CL - 75 150 ns 15 V 47 ns + (0.16 ns/pF)CL - 55 115 ns 5V 143 ns + (0.55 ns/pF)CL - 170 340 ns 10 V 59 ns + (0.23 ns/pF)CL - 70 140 ns 15 V 42 ns + (0.16 ns/pF)CL - 50 105 ns 5V 223 ns + (0.55 ns/pF)CL - 250 500 ns 10 V 99 ns + (0.23 ns/pF)CL - 110 220 ns 15 V 72 ns + (0.16 ns/pF)CL - 80 160 ns 5V 118 ns + (0.55 ns/pF)CL - 145 290 ns 10 V 49 ns + (0.23 ns/pF)CL - 60 125 ns 15 V 37 ns + (0.16 ns/pF)CL - 45 95 ns 5V 198 ns + (0.55 ns/pF)CL - 225 450 ns 10 V 64 ns + (0.23 ns/pF)CL - 75 150 ns 15 V 42 ns + (0.16 ns/pF)CL - 50 100 ns All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 8 of 17 HEF4516B NXP Semiconductors Binary up/down counter Table 7. Dynamic characteristics …continued VSS = 0 V; Tamb = 25 C; for test circuit see Figure 8; unless otherwise specified. Symbol tt Parameter Conditions VDD transition time maximum frequency see Figure 6 fmax pulse width tW CP input LOW; minimum width; see Figure 6 PL input HIGH; minimum width; see Figure 7 MR input HIGH; minimum width; see Figure 7 recovery time trec MR input; see Figure 7 PL input; see Figure 7 set-up time tsu Dn to PL; see Figure 7 UP/DN to CP; see Figure 6 CE to CP; see Figure 6 hold time th Dn to PL; see Figure 7 UP/DN to CP; see Figure 6 CE to CP; see Figure 6 [1] Min Typ Max Unit 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL 5V Extrapolation formula [1] - 20 40 ns 5V 3 6 - MHz 10 V 7 14 - MHz 15 V 9 18 - MHz 5V 95 45 - ns 10 V 35 20 - ns 15 V 25 15 - ns 5V 105 55 - ns 10 V 45 25 - ns 15 V 35 15 - ns 5V 120 60 - ns 10 V 50 25 - ns 15 V 40 20 - ns 5V 130 65 - ns 10 V 45 20 - ns 15 V 30 15 - ns 5V 150 75 - ns 10 V 50 25 - ns 15 V 30 15 - ns 5V 100 50 - ns 10 V 50 25 - ns 15 V 40 20 - ns 5V 250 125 - ns 10 V 100 50 - ns 15 V 75 35 - ns 5V 120 60 - ns 10 V 40 20 - ns 15 V 25 10 - ns 5V +10 40 - ns 10 V +5 20 - ns 15 V 0 20 - ns 5V +35 90 - ns 10 V +15 35 - ns 15 V +15 25 - ns 5V +20 40 - ns 10 V +5 15 - ns 15 V +5 10 - ns The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 9 of 17 HEF4516B NXP Semiconductors Binary up/down counter Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; CL = 50 pF; tr = tf  20 ns; Tamb = 25 C. Symbol PD Parameter VDD dynamic power dissipation Typical formula for PD (W) Where: 5V PD = 1000  fi + (fo  CL)  VDD 10 V PD = 4500  fi + (fo  CL)  VDD2 15 V PD = 11200  fi + (fo  CL)  VDD2 2 fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; (fo  CL) = sum of the outputs. 11. Waveforms tW VI CP input VM VSS tsu VI th VM CE input VSS tsu VI UP/DN input th tsu th VM VSS 001aae672 Measurement points are given in Table 9. Fig 6. Waveforms showing minimum pulse width for CP, set-up and hold times for CE to CP and UP/DN to CP VI CP input VM VSS tW VI VM PL input VSS tsu VI Dn input trec th VM VSS trec VI VM MR input VSS tW 001aae673 Measurement points are given in Table 9. Fig 7. Waveforms showing PL and MR minimum pulse widths and recovery times, and Dn to PL set-up and hold times HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 10 of 17 HEF4516B NXP Semiconductors Binary up/down counter tW VI 90 % 90 % negative pulse VM VM 10 % 0V 10 % tf tr tr tf VI 90 % positive pulse 90 % VM VM 10 % 0V 10 % tW 001aaj781 a. Input waveforms VDD VI VO G DUT RT CL 001aag182 b. Test circuit Test data is given in Table 9. Definitions for test circuit: DUT = Device Under Test CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 8. Test circuit for measuring switching times Table 9. Measurement points and test data Supply voltage 5 V to 15 V HEF4516B Product data sheet Input Load VI VM tr, tf CL VDD 0.5VI  20 ns 50 pF All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 11 of 17 HEF4516B NXP Semiconductors Binary up/down counter 12. Package outline DIP16: plastic dual in-line package; 16 leads (300 mil) SOT38-4 ME seating plane D A2 A A1 L c e Z w M b1 (e 1) b b2 MH 9 16 pin 1 index E 1 8 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 b2 c D (1) E (1) e e1 L ME MH w Z (1) max. mm 4.2 0.51 3.2 1.73 1.30 0.53 0.38 1.25 0.85 0.36 0.23 19.50 18.55 6.48 6.20 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 0.76 inches 0.17 0.02 0.13 0.068 0.051 0.021 0.015 0.049 0.033 0.014 0.009 0.77 0.73 0.26 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.03 Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. OUTLINE VERSION REFERENCES IEC JEDEC JEITA ISSUE DATE 95-01-14 03-02-13 SOT38-4 Fig 9. EUROPEAN PROJECTION Package outline SOT38-4 (DIP16) HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 12 of 17 HEF4516B NXP Semiconductors Binary up/down counter SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 10. Package outline SOT109-1 (SO16) HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 13 of 17 HEF4516B NXP Semiconductors Binary up/down counter 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4516B v.7 20111111 Product data sheet - HEF4516B v.6 Modifications: • • Section Applications removed Table 6: IOH minimum values changed to maximum HEF4516B v.6 20091211 Product data sheet - HEF4516B v.5 HEF4516B v.5 20090812 Product data sheet - HEF4516B v.4 HEF4516B v.4 20090312 Product data sheet - HEF4516B_CNV v.3 HEF4516B_CNV v.3 19950101 Product specification - HEF4516B_CNV v.2 HEF4516B_CNV v.2 19950101 Product specification - - HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 14 of 17 HEF4516B NXP Semiconductors Binary up/down counter 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 15 of 17 HEF4516B NXP Semiconductors Binary up/down counter Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com HEF4516B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 November 2011 © NXP B.V. 2011. All rights reserved. 16 of 17 HEF4516B NXP Semiconductors Binary up/down counter 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2011. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 November 2011 Document identifier: HEF4516B
HEF4516BT,652 价格&库存
很抱歉,暂时无法提供与“HEF4516BT,652”相匹配的价格&库存,您可以联系我们找货
