74HC595N
74HC595N
    NEXPERIA(安世)
    74HC595N
74HC595N 数据手册
74HC595; 74HCT595 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Rev. 7 — 26 January 2015 Product data sheet 1. General description The 74HC595; 74HCT595 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard No. 7A. The 74HC595; 74HCT595 are 8-stage serial shift registers with a storage register and 3-state outputs. The registers have separate clocks. Data is shifted on the positive-going transitions of the shift register clock input (SHCP). The data in each register is transferred to the storage register on a positive-going transition of the storage register clock input (STCP). If both clocks are connected together, the shift register will always be one clock pulse ahead of the storage register. The shift register has a serial input (DS) and a serial standard output (Q7S) for cascading. It is also provided with asynchronous reset (active LOW) for all 8 shift register stages. The storage register has 8 parallel 3-state bus driver outputs. Data in the storage register appears at the output whenever the output enable input (OE) is LOW. 2. Features and benefits       8-bit serial input 8-bit serial or parallel output Storage register with 3-state outputs Shift register with direct clear 100 MHz (typical) shift out frequency ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Applications  Serial-to-parallel data conversion  Remote control holding register 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 4. Ordering information Table 1. Ordering information Type number 74HC595N Package Temperature range Name Description Version 40 C to +125 C DIP16 plastic dual in-line package; 16 leads (300 mil) SOT38-4 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 74HCT595N 74HC595D 74HCT595D 74HC595DB 74HCT595DB 74HC595PW 74HCT595PW 74HC595BQ 74HCT595BQ 5. Functional diagram  '6  6+&3  05 67$*(6+,)75(*,67(5 46  67&3  2(  %,76725$*(5(*,67(5 67$7(2873876 4 4 4 4 4 4 4 4   Fig 1.       PQD Functional diagram 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 2 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state  (1    6+&3 67&3  4 & ' '        4   4  2(    PQD PQD Logic symbol Fig 3. 67$*( ' IEC logic symbol 67$*(672 ' 4 67$*( 4 ' 46 4 )) )) &3    4 '6 5  4 4 Fig 2. 65*  4 05   4 '6   46  &  &3 5 5 6+&3 05 ' 4 ' 4 /$7&+ /$7&+ &3 &3 67&3 2( PQD 4 Fig 4. 4 4 4 4 4 4 4 Logic diagram 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 3 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 6. Pinning information 6.1 Pinning +& +&7 4   9&& 4   4 4   '6 4   2( 4   67&3 4   6+&3 4   05 *1'   +& +&7 46 4  4   9&&  4 4   '6 4   2( 4   67&3 4   6+&3 4   05 *1'  46 DDR DDR Fig 5.  Pin configuration DIP16, SO16 Fig 6. Pin configuration SSOP16, TSSOP16  WHUPLQDO LQGH[DUHD  9&& 4 +& +&7 4   4 4   '6 4   2( 4  4  4   67&3 *1'   6+&3   *1' 46  05 DDR 7UDQVSDUHQWWRSYLHZ (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 7. Pin configuration for DHVQFN16 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 4 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 6.2 Pin description Table 2. Pin description Symbol Pin Description Q1 1 parallel data output 1 Q2 2 parallel data output 2 Q3 3 parallel data output 3 Q4 4 parallel data output 4 Q5 5 parallel data output 5 Q6 6 parallel data output 6 Q7 7 parallel data output 7 GND 8 ground (0 V) Q7S 9 serial data output MR 10 master reset (active LOW) SHCP 11 shift register clock input STCP 12 storage register clock input OE 13 output enable input (active LOW) DS 14 serial data input Q0 15 parallel data output 0 VCC 16 supply voltage 7. Functional description Function table[1] Table 3. Control Input Output Function SHCP STCP OE MR DS Q7S Qn X L X L NC X L a LOW-level on MR only affects the shift registers X  L L X L L empty shift register loaded into storage register X X H L X L Z shift register clear; parallel outputs in high-impedance OFF-state  X L H H Q6S NC logic HIGH-level shifted into shift register stage 0. Contents of all shift register stages shifted through, e.g. previous state of stage 6 (internal Q6S) appears on the serial output (Q7S). X  L H X NC QnS contents of shift register stages (internal QnS) are transferred to the storage register and parallel output stages   L H X Q6S QnS contents of shift register shifted through; previous contents of the shift register is transferred to the storage register and the parallel output stages [1] H = HIGH voltage state; L = LOW voltage state;  = LOW-to-HIGH transition; X = don’t care; NC = no change; Z = high-impedance OFF-state. 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 5 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 6+&3 '6 67&3 05 2( =VWDWH 4 =VWDWH 4 =VWDWH 4 =VWDWH 4 46 PQD Fig 8. Timing diagram 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 25 mA pin Q7S - 35 mA ICC supply current - 70 mA IGND ground current 70 - mA Tstg storage temperature pins Qn total power dissipation Ptot 65 +150 C DIP16 package [1] - 750 mW SO16 package [2] - 500 mW SSOP16 package [3] - 500 mW TSSOP16 package [3] - 500 mW DHVQFN16 package [4] - 500 mW [1] For DIP16 package: Ptot derates linearly with 12 mW/K above 70 C. [2] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. [3] For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. [4] For DHVQFN16 package: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 6 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions 74HC595 74HCT595 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V ns/V VCC = 6.0 V Tamb ambient temperature - - 83 - - - 40 +25 +125 40 +25 +125 C 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V 74HC595 VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = 4 mA; VCC = 4.5 V 3.84 4.32 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.34 5.81 - 5.2 - V IO = 6 mA; VCC = 4.5 V 3.84 4.32 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.34 5.81 - 5.2 - V VI = VIH or VIL all outputs Q7S output Qn bus driver outputs 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 7 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol VOL Parameter LOW-level output voltage 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ Max Min Max IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 4 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V VI = VIH or VIL all outputs Q7S output Qn bus driver outputs IO = 6 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 6.0 V; VO = VCC or GND - - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 - 160 A CI input capacitance - 3.5 - - - pF 74HCT595 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V 4.4 4.5 - 4.4 - V 3.84 4.32 - 3.7 - V 3.7 4.32 - 3.7 - V - 0 0.1 - 0.1 V - 0.15 0.33 - 0.4 V - 0.16 0.33 - 0.4 V - - 1.0 - 1.0 A all outputs IO = 20 A Q7S output IO = 4 mA Qn bus driver outputs IO = 6 mA VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V all outputs IO = 20 A Q7S output IO = 4.0 mA Qn bus driver outputs IO = 6.0 mA II input leakage current 74HC_HCT595 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 8 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions 40 C to +125 C Min Typ Max Min Max Unit IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND - - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 80 - 160 A ICC additional supply current per input pin; IO = 0 A; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V pins MR, SHCP, STCP, OE - 150 675 - 735 A pin DS - 25 113 - 123 A - 3.5 - - - pF CI input capacitance 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 14. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 52 160 - 200 - 240 ns - 19 32 - 40 - 48 ns - 15 27 - 34 - 41 ns VCC = 2 V - 55 175 - 220 - 265 ns VCC = 4.5 V - 20 35 - 44 - 53 ns - 16 30 - 37 - 45 ns VCC = 2 V - 47 175 - 220 - 265 ns VCC = 4.5 V - 17 35 - 44 - 53 ns - 14 30 - 37 - 45 ns VCC = 2 V - 47 150 - 190 - 225 ns VCC = 4.5 V - 17 30 - 38 - 45 ns - 14 26 - 33 - 38 ns VCC = 2 V - 41 150 - 190 - 225 ns VCC = 4.5 V - 15 30 - 38 - 45 ns VCC = 6 V - 12 27 - 33 - 38 ns 74HC595 tpd propagation SHCP to Q7S; see Figure 9 delay VCC = 2 V [2] VCC = 4.5 V VCC = 6 V STCP to Qn; see Figure 10 [2] VCC = 6 V MR to Q7S; see Figure 12 [3] VCC = 6 V ten enable time OE to Qn; see Figure 13 [4] VCC = 6 V tdis disable time OE to Qn; see Figure 13 74HC_HCT595 Product data sheet [5] All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 9 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 14. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 2 V 75 17 - 95 - 110 - ns VCC = 4.5 V 15 6 - 19 - 22 - ns VCC = 6 V 13 5 - 16 - 19 - ns VCC = 2 V 75 11 - 95 - 110 - ns VCC = 4.5 V 15 4 - 19 - 22 - ns VCC = 6 V 13 3 - 16 - 19 - ns VCC = 2 V 75 17 - 95 - 110 - ns VCC = 4.5 V 15 6 - 19 - 22 - ns VCC = 6 V 13 5 - 16 - 19 - ns VCC = 2 V 50 11 - 65 - 75 - ns VCC = 4.5 V 10 4 - 13 - 15 - ns VCC = 6 V 9 3 - 11 - 13 - ns VCC = 2 V 75 22 - 95 - 110 - ns VCC = 4.5 V 15 8 - 19 - 22 - ns VCC = 6 V 13 7 - 16 - 19 - ns 3 6 - 3 - 3 - ns VCC = 4.5 V 3 2 - 3 - 3 - ns VCC = 6 V 3 2 - 3 - 3 - ns VCC = 2 V 50 19 - 65 - 75 - ns VCC = 4.5 V 10 7 - 13 - 15 - ns VCC = 6 V 9 6 - 11 - 13 - ns SHCP HIGH or LOW; see Figure 9 STCP HIGH or LOW; see Figure 10 MR LOW; see Figure 12 tsu set-up time DS to SHCP; see Figure 10 SHCP to STCP; see Figure 11 th hold time DS to SHCP; see Figure 11 VCC = 2 V trec fmax recovery time maximum frequency MR to SHCP; see Figure 12 SHCP or STCP; see Figure 9 and 10 VCC = 2 V 9 30 - 4.8 - 4 - MHz VCC = 4.5 V 30 91 - 24 - 20 - MHz 35 108 - 28 - 24 - MHz - 115 - - - - - pF VCC = 6 V CPD power fi = 1 MHz; VI = GND to VCC dissipation capacitance 74HC_HCT595 Product data sheet [6][7] All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 10 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 14. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max [2] - 25 42 - 53 - 63 ns [2] - 24 40 - 50 - 60 ns [3] - 23 40 - 50 - 60 ns enable time OE to Qn; see Figure 13 [4] - 21 35 - 44 - 53 ns tdis disable time OE to Qn; see Figure 13 [5] tW pulse width 74HCT595; VCC = 4.5 V to 5.5 V propagation SHCP to Q7S; see Figure 9 delay STCP to Qn; see Figure 10 tpd MR to Q7S; see Figure 12 ten set-up time tsu - 18 30 - 38 - 45 ns SHCP HIGH or LOW; see Figure 9 16 6 - 20 - 24 - ns STCP HIGH or LOW; see Figure 10 16 5 - 20 - 24 - ns MR LOW; see Figure 12 20 8 - 25 - 30 - ns DS to SHCP; see Figure 10 16 5 - 20 - 24 - ns SHCP to STCP; see Figure 11 16 8 - 20 - 24 - ns th hold time DS to SHCP; see Figure 11 3 2 - 3 - 3 - ns trec recovery time MR to SHCP; see Figure 12 10 7 - 13 - 15 - ns fmax maximum frequency SHCP and STCP; see Figure 9 and 10 30 52 - 24 - 20 - MHz CPD power fi = 1 MHz; dissipation VI = GND to VCC  1.5 V capacitance - 130 - - - - - pF [1] [7] Typical values are measured at nominal supply voltage. [2] tpd is the same as tPHL and tPLH. [3] tpd is the same as tPHL only. [4] ten is the same as tPZL and tPZH. [5] tdis is the same as tPLZ and tPHZ. [6] [6] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; (CL  VCC2  fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. [7] All 9 outputs switching. 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 11 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 12. Waveforms IPD[ 9, 6+&3LQSXW 90 *1' W: W 3+/ W 3/+ 92+ 90 46RXWSXW  92/ PQD Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. Shift clock pulse, maximum frequency and input to output propagation delays 9, 6+&3LQSXW 90 *1' IPD[ W VX 9, 67&3LQSXW 90 *1' W: W 3+/ W 3/+ 92+ 90 4QRXWSXW  92/ PQD Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 10. Storage clock to output propagation delays 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 12 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 9, 90 6+&3LQSXW *1' W VX W VX WK WK 9, 90 '6LQSXW *1' 92+ 90 46RXWSXW 92/ PQD Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig 11. Data set-up and hold times 9, 90 05LQSXW  *1' W: W UHF 9, 6+&3LQSXW  *1' 90 W 3+/ 92+ 90 46RXWSXW 92/ PQD Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 12. Master reset to output propagation delays 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 13 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state WU WI  90 2(LQSXW  W3/= W3=/ 4QRXWSXW 90 /2:WR2)) 2))WR/2:  W3+= W3=+  4QRXWSXW 90 +,*+WR2)) 2))WR+,*+ RXWSXWV HQDEOHG RXWSXWV HQDEOHG RXWSXWV GLVDEOHG PVD Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 13. Enable and disable times Table 8. Measurement points Type Input Output VM VM 74HC595 0.5VCC 0.5VCC 74HCT595 1.3 V 1.3 V 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 14 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RL = load resistance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. S1 = test selection switch. Fig 14. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC595 VCC 6 ns 50 pF 1 k open GND VCC 74HCT595 3V 6 ns 50 pF 1 k open GND VCC 74HC_HCT595 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 15 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 13. Package outline ',3SODVWLFGXDOLQOLQHSDFNDJHOHDGV PLO  627 0( VHDWLQJSODQH ' $ $ $ / F H = Z 0 E E  H   E  0+ SLQLQGH[ (     PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $  PLQ $  PD[ E E E F '   (   H H / 0( 0+ Z =   PD[ PP                          LQFKHV                          1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627   -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 15. Package outline SOT38-4 (DIP16) 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 16 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT109-1 (SO16) 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 17 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 17. Package outline SOT338-1 (SSOP16) 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 18 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 18. Package outline SOT403-1 (TSSOP16) 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 19 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H / Y Z \ \        H  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 19. Package outline SOT763-1 (DHVQFN16) 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 20 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 14. Abbreviations Table 10. Abbreviations Acronym Abbreviation CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT595 v.7 20150126 Product data sheet - 74HC_HCT595 v.6 Modifications: 74HC_HCT595 v.6 Modifications: • Table 7: Power dissipation capacitance condition for 74HCT595 is corrected. 20111212 • Product data sheet - 74HC_HCT595 v.5 Legal pages updated. 74HC_HCT595 v.5 20110628 Product data sheet - 74HC_HCT595 v.4 74HC_HCT595 v.4 20030604 Product specification - 74HC_HCT595_CNV v.3 74HC_HCT595_CNV v.3 19980604 Product specification - - 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 21 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT595 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 22 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74HC_HCT595 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 23 of 24 74HC595; 74HCT595 NXP Semiconductors 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 16 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21 Legal information. . . . . . . . . . . . . . . . . . . . . . . 22 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Contact information. . . . . . . . . . . . . . . . . . . . . 23 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP Semiconductors N.V. 2015. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 26 January 2015 Document identifier: 74HC_HCT595
74HC595N 价格&库存
很抱歉,暂时无法提供与“74HC595N”相匹配的价格&库存,您可以联系我们找货
