HPZR-C10-QX
HPZR-C10-QX
    NEXPERIA(安世)
    NEXPERIA - HPZR-C10-QX - Zener Single Diode, 10 V, 682 mW, CFP3 (SOD-123W), 2 Pins, 175 °C, Surface ...
HPZR-C10-QX 数据手册
HPZR-Q series High power voltage regulator diodes Rev. 2 — 12 September 2022 Objective data sheet 1. General description Low-current voltage regulator diodes in a CFP3 (SOD123W) small and flat lead low-profile SurfaceMounted Device (SMD) plastic package. 2. Features and benefits • • • • • Total power dissipation: ≤ 1154 mW Tolerance series: Approximately ±5 % Working voltage range: nominal 5.6 V to 75 V ESD maximum rating 30 kV according IEC 61000-4-2 (contact discharge) Qualified according to AEC-Q101 and recommended for use in automotive applications 3. Applications • Low-currect general regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 100 mA PZSM non-repetitive peak power dissipation square wave; tp ≤ 100 µs Ptot total power dissipation Tamb ≤ 25 °C [1] [2] Min Typ Max Unit [1] - - 1 V - - 800 W [2] - - 1154 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 cathode 1 cm HPZR-Q series Nexperia High power voltage regulator diodes 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline [1] 1 Graphic symbol 2 A K 006aaa152 [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number HPZR-Q series Package Name Description Version CFP3 plastic, surface mounted package; 2 terminals; 2.6 mm x 1.7 mm x 1 mm body SOD123W 7. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code HPZR-C5V6-Q LM HPZR-C15-Q M3 HPZR-C39-Q MF HPZR-C6V7-Q LN HPZR-C17-Q M4 HPZR-C42-Q MG HPZR-C7V0-Q LP HPZR-C18-Q M5 HPZR-C47-Q MH HPZR-C7V6-Q LR HPZR-C19-Q M6 HPZR-C50-Q MJ HPZR-C8V2-Q LS HPZR-C20-Q M7 HPZR-C53-Q MK HPZR-C8V8-Q LT HPZR-C21-Q M8 HPZR-C56-Q ML HPZR-C9V4-Q LU HPZR-C23-Q M9 HPZR-C60-Q MM HPZR-C10-Q LV HPZR-C26-Q MA HPZR-C63-Q MN HPZR-C11-Q LW HPZR-C28-Q MB HPZR-C68-Q MP HPZR-C12-Q LX HPZR-C30-Q MC HPZR-C70-Q MR HPZR-C13-Q LY HPZR-C33-Q MD HPZR-C75-Q MS HPZR-C14-Q M2 HPZR-C35-Q ME - - HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 2 / 12 HPZR-Q series Nexperia High power voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current PZSM non-repetitive peak power dissipation IFSM Ptot Conditions Min Max Unit - 400 mA square wave; tp ≤ 100 µs - 800 W non-repetitive peak forward current single half-sine wave; tp = 8.3 ms - 50 A total power dissipation Tamb ≤ 25 °C [1] - 682 mW [2] - 1154 mW [3] - 2143 mW Tj junction temperature - 175 °C Tamb ambient temperature -55 +175 °C Tstg storage temperature -65 +175 °C Max Unit 30 kV [1] [2] [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Device mounted on ceramic PCB, Al2O3, standard footprint. Table 6. ESD maximum ratings Symbol Parameter Conditions Min Per diode VESD [1] [2] electrostatic discharge voltage IEC 61000-4-2 (contact discharge) [1] [2] Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses. Soldering point of cathode tab. Table 7. ESD standard compliance Test and measurement Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 8 kV HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 HPZR-Q series Nexperia High power voltage regulator diodes 9. Thermal characteristics Table 8. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air Rth(j-sp) [1] [2] [3] [4] thermal resistance from junction to ambient thermal resistance from junction to solder point Min Typ Max Unit [1] - - 220 K/W [2] - - 130 K/W [3] - - 70 K/W [4] - - 18 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Device mounted on ceramic PCB, Al2O3, standard footprint. Soldering point of cathode tab. 10. Characteristics Table 9. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 100 mA [1] Min [1] - Typ Max Unit - 1 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Table 10. Characteristics per type; HPZR-C5V6-Q to HPZR-C8V2-Q Tj = 25 °C unless otherwise specified. HPZR -Cxxx-Q Working voltage VZ (V) IZ = 10 mA Differential resistance RZ (Ω) IZ = 20 mA Reverse current IR (μA) Min Max Max VR (V) Max 5V6 5.20 6.00 600 3.3 63.60 6V7 6.40 7.00 400 5.0 42.40 7V0 6.67 7.37 400 6.0 4.77 7V6 7.22 7.98 250 6.5 11.60 8V2 7.78 8.60 100 7.0 13.25 HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 4 / 12 HPZR-Q series Nexperia High power voltage regulator diodes Table 11. Characteristics per type; HPZR-C8V8-Q to HPZR-C75-Q Tj = 25 °C unless otherwise specified. HPZR -Cxxx-Q Working voltage VZ (V) IZ = 1 mA Differential resistance RZ (Ω) IZ = 20 mA Reverse current IR (μA) Min Max Max VR (V) Max 8V8 8.33 9.21 50 7.5 14.84 9V4 8.89 9.83 25 8.0 16.43 10 9.44 10.40 10 8.5 18.02 11 10.00 11.10 5 9.0 19.61 12 11.10 12.30 2.5 10.0 21.20 13 12.20 13.50 2.5 11.0 22.79 14 13.30 14.70 2.5 12 24.38 15 14.40 15.90 0.1 13 25.97 17 15.60 17.20 0.1 14 27.56 18 16.70 18.50 0.1 15 29.15 19 17.80 19.70 0.1 16 30.74 20 18.90 20.90 0.1 17 32.33 21 20.00 22.10 0.1 18 33.92 23 22.20 24.50 0.1 20 35.51 26 24.40 26.90 0.1 22 36.57 28 26.70 29.50 0.1 24 37.10 30 28.90 31.90 0.1 26 40.28 33 31.10 34.40 0.1 28 43.46 35 33.30 36.80 0.1 30 46.64 39 36.70 40.60 0.1 33 49.82 42 40.00 44.20 0.1 36 53.00 47 44.40 49.10 0.1 40 56.18 50 47.80 52.80 0.1 43 59.36 53 50.00 55.30 0.1 45 62.54 56 53.30 58.90 0.1 48 65.72 60 56.70 62.70 0.1 51 68.90 63 60.00 66.30 0.1 54 72.08 68 64.40 71.20 0.1 58 75.26 70 66.70 73.70 0.1 60 76.32 75 71.10 78.60 0.1 64 77.38 HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 HPZR-Q series Nexperia High power voltage regulator diodes aaa-035292 103 aaa-035293 1 IF (A) PZSM (W) 10-1 102 10-2 10-3 10 10-4 1 10-1 1 tp (ms) 10 10-5 0.4 (1) Tj = 25 °C (before surge) Fig. 1. Fig. 2. aaa-035294 IF (A) VF (V) 1 Forward current as a function of forward voltage; typical values (HPZR-C5V6-Q) aaa-035295 1 IF (A) 10-1 10-1 10-2 10-2 10-3 10-3 10-4 10-4 10-5 0.4 0.6 0.8 VF (V) 1 10-5 0.4 Tj = 25 °C Fig. 3. 0.8 Tj = 25 °C Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values 1 0.6 Objective data sheet 0.8 VF (V) 1 Tj = 25 °C Forward current as a function of forward voltage; typical values (HPZR-C7V0-Q) HPZR-Q_SER 0.6 Fig. 4. Forward current as a function of forward voltage; typical values (HPZR-C8V2-Q) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 HPZR-Q series Nexperia High power voltage regulator diodes aaa-035296 1 IF (A) 10-1 10-2 10-3 10-4 10-5 0.4 0.6 0.8 VF (V) 1 Tj = 25 °C Fig. 5. Forward current as a function of forward voltage; typical values (HPZR-C68-Q) 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 1.9 1.5 1.1 0.9 1 0.6 0.3 3.7 3.3 2.8 2.4 2 1.05 0.75 Dimensions in mm Fig. 6. HPZR-Q_SER Objective data sheet 0.22 0.10 08-11-06 Package outline CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 HPZR-Q series Nexperia High power voltage regulator diodes 13. Soldering Footprint information for reflow soldering of CFP3 package SOD123W 4.4 2.9 2.8 2.1 1.6 1.1 1.2 1.4 1.1 1.2 1.4 recommended stencil thickness: 0.1 mm occupied area solder resist solder land solder paste Dimensions in mm Issue date Fig. 7. HPZR-Q_SER Objective data sheet 17-06-09 20-02-28 sod123w_fr Reflow soldering footprint for CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 HPZR-Q series Nexperia High power voltage regulator diodes Wave soldering footprint information SOD123W 8.3 4.8 1.8 3.5 2.4 (2×) 2.55 (2×) 3.0 (2×) occupied area solder resist solder lands dummy track (solder resist and Cu free) 3.15 (2×) Dimensions in mm Issue date Fig. 8. HPZR-Q_SER Objective data sheet 17-06-06 17-06-07 sod123w_fw Wave soldering footprint for CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 HPZR-Q series Nexperia High power voltage regulator diodes 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HPZR-Q_SER v.1 20220912 Product data sheet - HPZR-Q_SER v.1 Modifications: • HPZR-Q_SER v.1 20220520 - - HPZR-Q_SER Objective data sheet Product status changed Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 HPZR-Q series Nexperia High power voltage regulator diodes equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 HPZR-Q series Nexperia High power voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 4 11. Test information.......................................................... 7 12. Package outline.......................................................... 7 13. Soldering..................................................................... 8 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 September 2022 HPZR-Q_SER Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
HPZR-C10-QX
物料型号:HPZR-Q系列 器件简介:高功率电压调节二极管,用于低电流电压调节,采用CFP3(SOD123W)小型扁平引脚表面贴装器件(SMD)塑料封装。
引脚分配:1号引脚为阴极(K),2号引脚为阳极(A)。
参数特性:典型工作电压范围为5.6V至75V,总功率耗散不超过1154mW,正向电压(VF)在100mA时为1V,非重复峰值功率耗散(PzsM)为800W。
功能详解:用于低电流通用调节功能,具有高功率耗散能力和稳定的电压调节特性。
应用信息:推荐用于汽车应用,符合AEC-Q101标准。
封装信息:CFP3塑料表面贴装包,2个端子,2.6mm x 1.7mm x 1mm的尺寸。
以上信息摘自Nexperia的HPZR-Q系列高功率电压调节二极管的数据手册。
HPZR-C10-QX 价格&库存
很抱歉,暂时无法提供与“HPZR-C10-QX”相匹配的价格&库存,您可以联系我们找货
HPZR-C10-QX
  • 1+5.740181+0.74595
  • 10+3.5380010+0.45978
  • 50+2.5728450+0.33435
  • 100+2.25692100+0.29330
  • 500+1.70163500+0.22114
库存:3001
HPZR-C10-QX
  • 3000+1.293943000+0.16815
  • 9000+1.120269000+0.14558
库存:3001
