74HC132BQ-Q100
74HC132BQ-Q100
    NEXPERIA(安世)
    NEXPERIA - 74HC132BQ-Q100 - Logic IC, NAND Gate, Quad, 2 Inputs, 14 Pins, DHVQFN, 74HC132
74HC132BQ-Q100 数据手册
74HC132-Q100; 74HCT132-Q100 Quad 2-input NAND Schmitt trigger Rev. 4 — 12 June 2018 1 Product data sheet General description The 74HC132-Q100; 74HCT132-Q100 is a quad 2-input NAND gate with Schmitt-trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2 Features and benefits • Automotive product qualification in accordance with AEC-Q100 (Grade 1) – Specified from -40 °C to +85 °C and from -40 °C to +125 °C • Complies with JEDEC standard no. 7A • ESD protection: – MIL-STD-883, method 3015 exceeds 2000 V – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) • Multiple package options 3 Applications • Wave and pulse shapers • Astable multivibrators • Monostable multivibrators 4 Ordering information Table 1. Ordering information Type number 74HC132D-Q100 Package Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced SOT762-1 very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74HCT132D-Q100 74HC132PW-Q100 74HCT132PW-Q100 74HC132BQ-Q100 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 5 Functional diagram 1 1A 1Y 2 4 1B 2A 2Y 5 9 2B 1 6 4 3B & 3 & 6 & 8 2 3A 3Y 10 3 5 8 9 10 12 4Y 13 4B 12 11 & Y 11 13 B mna409 mna408 mna407 Figure 1. Logic symbol 6 A 4A Figure 3. Logic diagram (one Schmitt trigger) Figure 2. IEC logic symbol Pinning information 6.1 Pinning 1 1A terminal 1 index area 13 4B 1Y 3 12 4A 2A 4 11 4Y 2B 5 10 3B 2Y 6 9 3A GND 7 8 3Y Figure 4. Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) Product data sheet 12 4A 4 11 4Y 2B 5 2Y 6 GND(1) 13 4B 10 3B 9 3A aaa-028548 Transparent top view aaa-003901 74HC_HCT132_Q100 3 2A 8 14 VCC 2 1Y 3Y 1 1B 2 7 1A 1B GND 74HC132-Q100 74HCT132-Q100 14 VCC 74HC132-Q100 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Figure 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10, 13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 7 Functional description Table 3. Function table [1] Input Output nA nB nY L L H L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC IIK Conditions supply voltage input clamping current Min Max Unit -0.5 +7 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA [1] - ±20 mA - ±25 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation SO14, TSSOP14 and DHVQFN14 packages [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 °C. 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 9 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC132-Q100 74HCT132-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C 10 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max HIGH-level output VI = VT+ or VTvoltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level output VI = VT+ or VTvoltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC132-Q100 VOH VOL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V 74HCT132-Q100 VOH HIGH-level output VI = VT+ or VT-; VCC = 4.5 V voltage IO = -20 μA IO = -4.0 mA VOL LOW-level output VI = VT+ or VT-; VCC = 4.5 V voltage IO = 20 μA; IO = 4.0 mA; II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - 30 108 - 135 - 147 μA CI input capacitance - 3.5 - - - - - pF 11 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 7. Symbol Parameter Conditions 25 °C −40 °C to +125 °C Unit Min Typ Max Max (85 °C) Max (125 °C) VCC = 2.0 V - 36 125 155 190 ns VCC = 4.5 V - 13 25 31 38 ns VCC = 5.0 V; CL = 15 pF - 11 - - - ns - 10 21 26 32 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 24 - - - pF 74HC132-Q100 tpd propagation delay nA, nB to nY; see Figure 6 [1] VCC = 6.0 V tt transition time [2] see Figure 6 VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT132_Q100 Product data sheet per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger Symbol Parameter Conditions 25 °C −40 °C to +125 °C Unit Min Typ Max Max (85 °C) Max (125 °C) - 20 33 41 50 ns 74HCT132-Q100 tpd [1] propagation delay nA, nB to nY; see Figure 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF tt CPD transition time power dissipation capacitance - 17 - - - ns VCC = 4.5 V; see Figure 6 [2] - 7 15 19 22 ns per package; VI = GND to VCC - 1.5 V [3] - 20 - - - pF [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL × VCC × fo) = sum of outputs. 11.1 Waveforms and test circuit VI nA, nB input GND VOH VM tPHL VY nY output VOL tTHL tPLH VM VX tTLH 001aai814 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Input to output propagation delays Table 8. Measurement points Type Input Output VM VM VX VY 74HC132-Q100 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT132-Q100 1.3 V 1.3 V 0.1VCC 0.9VCC 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Figure 7. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC132-Q100 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT132-Q100 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 12 Transfer characteristics Table 10. Transfer characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for waveforms see Figure 8 to Figure 11. Symbol Parameter Conditions Tamb = 25 °C Tamb = −40 °C to +85 °C Tamb = −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 0.7 1.18 1.5 0.7 1.5 0.7 1.5 V VCC = 4.5 V 1.7 2.38 3.15 1.7 3.15 1.7 3.15 V VCC = 6.0 V 2.1 3.14 4.2 2.1 4.2 2.1 4.2 V VCC = 2.0 V 0.3 0.63 1.0 0.3 1.0 0.3 1.0 V VCC = 4.5 V 0.9 1.67 2.2 0.9 2.2 0.9 2.2 V VCC = 6.0 V 1.2 2.26 3.0 1.2 3.0 1.2 3.0 V VCC = 2.0 V 0.2 0.55 1.0 0.2 1.0 0.2 1.0 V VCC = 4.5 V 0.4 0.71 1.4 0.4 1.4 0.4 1.4 V VCC = 6.0 V 0.6 0.88 1.6 0.6 1.6 0.6 1.6 V positive-going threshold voltage VCC = 4.5 V 1.2 1.41 1.9 1.2 1.9 1.2 1.9 V VCC = 5.5 V 1.4 1.59 2.1 1.4 2.1 1.4 2.1 V negative-going threshold voltage VCC = 4.5 V 0.5 0.85 1.2 0.5 1.2 0.5 1.2 V VCC = 5.5 V 0.6 0.99 1.4 0.6 1.4 0.6 1.4 V hysteresis voltage VCC = 4.5 V 0.4 0.56 - 0.4 - 0.4 - V VCC = 5.5 V 0.4 0.60 - 0.4 - 0.4 - V 74HC132-Q100 VT+ VT- VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage 74HCT132-Q100 VT+ VTVH 12.1 Transfer characteristics waveforms VO VI VI VH VT- VT+ Figure 8. Transfer characteristics 74HC_HCT132_Q100 Product data sheet VT+ VH VT- VO mna207 mna208 Figure 9. Transfer characteristics definitions All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger aaa-003889 50 aaa-003890 500 ICC (µA) ICC (µA) 40 400 30 300 20 200 10 100 0 0 1 VIN (V) 0 2 a. VCC = 2.0 V 0 1 2 3 4 VIN (V) 5 b. VCC = 4.5 V aaa-003892 1.0 ICC (mA) 0.8 0.6 0.4 0.2 0 0 1.2 2.4 3.6 4.8 6.0 VIN (V) c. VCC = 6.0 V Figure 10. Typical 74HC132-Q100 transfer characteristics 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger aaa-003893 1.5 aaa-003895 1.8 ICC (mA) 1.5 ICC (mA) 1.2 1.2 0.9 0.9 0.6 0.6 0.3 0 0.3 0 1 2 3 4 VIN (V) a. VCC = 4.5 V 0 5 0 1 2 3 4 5 VIN (V) 6 b. VCC = 5.5 V Figure 11. Typical 74HCT132-Q100 transfer characteristics 13 Application information The slow input rise and fall times cause additional power dissipation, this can be calculated using the following formula: Padd = fi × (tr × ΔICC(AV) + tf × ΔICC(AV)) × VCC where: Padd = additional power dissipation (μW); fi = input frequency (MHz); tr = rise time (ns); 10 % to 90 %; ΔICC(AV) = average additional supply current (μA). tf = fall time (ns); 90 % to 10 %; Average ΔICC(AV) differs with positive or negative input transitions, as shown in Figure 12 and Figure 13. An example of a relaxation circuit using the 74HC132-Q100; 74HCT132-Q100 is shown in Figure 14. 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger aaa-003897 400 average ICC (µA) 300 200 positive-going edge 100 negative-going edge 0 0 2 4 VCC (V) 6 Figure 12. Average additional supply current as a function of VCC for 74HC132-Q100; linear change of VI between 0.1VCC to 0.9VCC. aaa-003899 500 average ICC (µA) 400 positive-going edge 300 200 negative-going edge 100 0 0 2 4 VCC (V) 6 Figure 13. Average additional supply current as a function of VCC for 74HCT132-Q100; linear change of VI between 0.1VCC to 0.9VCC. 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger VCC R VCC A Y B C 001aac440 For 74HC132-Q100 and 74HCT132-Q100: Typical K-factor for relaxation oscillator, see Figure 15 and Figure 16 Figure 14. Relaxation oscillator aaa-004609 2.0 K aaa-004610 1.2 K 1.0 1.5 0.8 1.0 0.6 0.4 0.5 0.2 0 2 3 4 5 Figure 15. K-factor for 74HC132-Q100 74HC_HCT132_Q100 Product data sheet VCC (V) 6 0 4.5 5.0 VCC (V) 5.5 Figure 16. K-factor for 74HCT132-Q100 All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 14 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 17. Package outline SOT108-1 (SO14) 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 18. Package outline SOT402-1 (TSSOP14) 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 Eh e 14 8 k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Figure 19. Package outline SOT762-1 (DHVQFN14) 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 15 Abbreviations Table 11. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 16 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT132_Q100 v.4 20180612 Product data sheet - 74HC_HCT132_Q100 v.3 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Added type number 74HC132BQ (SOT762-1) 74HC_HCT132_Q100 v.3 20151201 Modifications: • General description changed. 74HC_HCT132_Q100 v.2 20120813 Modifications: • Figure 15 and Figure 16 added (typical K-factor for relaxation oscillator). 74HC_HCT132_Q100 v.1 20120712 74HC_HCT132_Q100 Product data sheet Product data sheet Product data sheet Product data sheet - 74HC_HCT132_Q100 v.2 - 74HC_HCT132_Q100 v.1 - All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 - © Nexperia B.V. 2018. All rights reserved. 16 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger 17 Legal information 17.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation 74HC_HCT132_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 19 74HC132-Q100; 74HCT132-Q100 Nexperia Quad 2-input NAND Schmitt trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 74HC_HCT132_Q100 Product data sheet 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 12 June 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 19 Nexperia 74HC132-Q100; 74HCT132-Q100 Quad 2-input NAND Schmitt trigger Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 12.1 13 14 15 16 17 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 4 Static characteristics .......................................... 4 Dynamic characteristics .....................................5 Waveforms and test circuit ................................ 6 Transfer characteristics ......................................8 Transfer characteristics waveforms ................... 8 Application information .................................... 10 Package outline .................................................13 Abbreviations .................................................... 16 Revision history ................................................ 16 Legal information .............................................. 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 June 2018 Document identifier: 74HC_HCT132_Q100
74HC132BQ-Q100 价格&库存
很抱歉,暂时无法提供与“74HC132BQ-Q100”相匹配的价格&库存,您可以联系我们找货
74HC132BQ-Q100
  • 5+3.54764
  • 10+2.14757
  • 100+1.70856
  • 500+1.62551
  • 1000+1.54245
  • 5000+1.44753
  • 10000+1.34075
库存:3890
74HC132BQ-Q100
  • 5+3.54764
  • 10+2.14757
  • 100+1.70856
  • 500+1.62551
  • 1000+1.54245
  • 5000+1.44753
  • 10000+1.34075
库存:3890
