74AVC1T8832GS
74AVC1T8832GS
    NEXPERIA(安世)
    NEXPERIA - 74AVC1T8832GS - Logic IC, OR Gate, Single, 2 Inputs, 8 Pins, XSON, 74AVC1T8832
74AVC1T8832GS 数据手册
74AVC1T8832 Single dual-supply translating 2-input OR with strobe Rev. 1 — 10 October 2018 Product data sheet 1. General description The 74AVC1T8832 is a single dual-supply translating 2-input OR with strobe inputs. It features two data input pins (A, B), two strobe input pins (STRA, STRB), one data output pin (Y) and dual-supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 0.8 V and 3.6 V making the device suitable for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins A, B, STRA and STRB are referenced to VCC(A) and pin Y is referenced to VCC(B). The logic equation provided at the Y output is: Y = STRA•A + STRB•B The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In Suspend mode when either VCC(A) or VCC(B) are at GND level, the Y output is in the high-impedance OFF-state. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range: • VCC(A): 0.8 V to 3.6 V • VCC(B): 0.8 V to 3.6 V High noise immunity Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • HBM: ANSI/ESDA/JEDEC JS-001 exceeds 8000 V • CDM: ANSI/ESDA/JEDEC JS-002 exceeds 1000 V Maximum data rates: • 500 Mbit/s (1.8 V to 3.3 V translation) • 320 Mbit/s (
74AVC1T8832GS 价格&库存
很抱歉,暂时无法提供与“74AVC1T8832GS”相匹配的价格&库存,您可以联系我们找货
