74AUP1Z04GW-Q100H
74AUP1Z04GW-Q100H
    NEXPERIA(安世)
    NEXPERIA - 74AUP1Z04GW-Q100H - Crystal Oscillator Driver, 0.8 V to 3.6 V, SC-88-6, -40 °C to 125 °C
74AUP1Z04GW-Q100H 数据手册
74AUP1Z04-Q100 Low-power X-tal driver with enable and internal resistor Rev. 1 — 18 August 2020 Product data sheet 1. General description The 74AUP1Z04-Q100 is a crystal driver with enable and internal resistor. When not in use the EN input can be driven HIGH, putting the device in a low power disable mode with X1 pulled HIGH via RPU, X2 set LOW and Y set HIGH. Schmitt trigger action on the EN input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range from 0.8 V to 3.6 V CMOS low power dissipation High noise immunity Overvoltage tolerant inputs to 3.6 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation at output Y Latch-up performance exceeds 100 mA per JESD78B Class II Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 5000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V 3. Ordering information Table 1. Ordering information Type number Package 74AUP1Z04GW-Q100 Temperature range Name Description Version -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 4. Marking Table 2. Marking Type number Marking code [1] 74AUP1Z04GW-Q100 a4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram VCC RPU X1 3 6 Rbias EN 4 Y X2 1 001aae488 RPU= pull-up resistance. Rbias= bias resistance. Fig. 1. Logic symbol 6. Pinning information 6.1. Pinning 74AUP1Z04 EN 1 6 Y GND 2 5 VCC X1 3 4 X2 001aad592 Fig. 2. Pin configuration SOT363 (SC-88) 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 2 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 6.2. Pin description Table 3. Pin description Symbol Pin Description EN 1 enable input (active LOW) GND 2 ground (0 V) X1 3 data input X2 4 data output VCC 5 supply voltage Y 6 data output 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output EN X1 X2 Y L L H L L H L H H L H L H H L H 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC IGND Conditions VI < 0 V [1] VO < 0 V [1] Max Unit -0.5 +4.6 V -50 - -0.5 +4.6 -50 - -0.5 mA V mA VCC + 0.5 V - ±20 mA supply current - 50 mA ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] VO = 0 V to VCC Min Tamb = -40 °C to +125 °C [2] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT363 (SC-88) package: Ptot derates linearly with 3.7 mW/K above 83 °C. 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 3 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCC V Tamb ambient temperature -40 +125 °C Δt/ΔV input transition rise and fall rate - 200 ns/V Unit VCC = 0.8 V to 3.6 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max 0.75VCC - - V VCC = 0.8 V 0.70VCC - - V VCC = 0.9 V to 1.95 V 0.65VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25VCC V VCC = 0.8 V - - 0.30VCC V VCC = 0.9 V to 1.95 V - - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 25 °C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 4 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter VOH Conditions Min Typ Max Unit IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.75VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.11 - - V IO = -1.9 mA; VCC = 1.65 V 1.32 - - V IO = -2.3 mA; VCC = 2.3 V 2.05 - - V IO = -3.1 mA; VCC = 2.3 V 1.9 - - V IO = -2.7 mA; VCC = 3.0 V 2.72 - - V IO = -4.0 mA; VCC = 3.0 V 2.6 - - V IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.75VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.11 - - V IO = -1.9 mA; VCC = 1.65 V 1.32 - - V IO = -2.3 mA; VCC = 2.3 V 2.05 - - V IO = -3.1 mA; VCC = 2.3 V 1.9 - - V IO = -2.7 mA; VCC = 3.0 V 2.72 - - V IO = -4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V HIGH-level output voltage Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC VOL LOW-level output voltage Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 5 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - ±0.1 μA - - ±0.1 μA - - 15 μA EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC VI = GND; VCC = 0.8 V to 3.6 V IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - ±0.2 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V [1] - - ±0.2 μA ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V - - 75 μA ΔICC additional supply current EN input - - 40 μA - 1.3 - pF - 0.8 - pF - 1.5 - pF - 1.7 - pF - - - mA/V VCC = 1.1 V to 1.3 V 0.2 - 9.9 mA/V VCC = 1.4 V to 1.6 V 3.9 - 17.7 mA/V VCC = 1.65 V to 1.95 V 7.9 - 24.3 mA/V VCC = 2.3 V to 2.7 V 18 - 30.7 mA/V VCC = 3.0 V to 3.6 V 20.5 - 32.4 mA/V 1.08 1.62 3.08 MΩ 0.75VCC - - V VCC = 0.8 V 0.70VCC - - V VCC = 0.9 V to 1.95 V 0.65VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V CI input capacitance X1 input VCC = 0 V to 3.6 V; VI = GND or VCC EN input VCC = 0 V to 3.6 V; VI = GND or VCC CO output capacitance X2 output VO = GND; VCC = 0 V Y output VO = GND; VCC = 0 V gfs forward transconductance see Fig. 8 and Fig. 9 VCC = 0.8 V Rbias bias resistance EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Fig. 3; for frequency behavior see Fig. 4 Tamb = -40 °C to +85 °C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 6 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions VIL X1 input LOW-level input voltage Min Typ - - 0.25VCC V VCC = 0.8 V - - 0.30VCC V VCC = 0.9 V to 1.95 V - - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.7VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.03 - - V IO = -1.9 mA; VCC = 1.65 V 1.30 - - V IO = -2.3 mA; VCC = 2.3 V 1.97 - - V IO = -3.1 mA; VCC = 2.3 V 1.85 - - V IO = -2.7 mA; VCC = 3.0 V 2.67 - - V IO = -4.0 mA; VCC = 3.0 V 2.55 - - V VCC = 0.8 V to 3.6 V Max Unit EN input VOH HIGH-level output voltage Y output; VI at X1 input = VIH or VIL IO = -20 μA; VCC = 0.8 V to 3.6 V VI at X1 input = VIH or VIL IO = -20 μA; VCC = 0.8 V to 3.6 V VOL LOW-level output voltage VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.7VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.03 - - V IO = -1.9 mA; VCC = 1.65 V 1.30 - - V IO = -2.3 mA; VCC = 2.3 V 1.97 - - V IO = -3.1 mA; VCC = 2.3 V 1.85 - - V IO = -2.7 mA; VCC = 3.0 V 2.67 - - V IO = -4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 7 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - ±0.5 μA - - ±0.5 μA - - 15 μA EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC VI = GND; VCC = 0.8 V to 3.6 V IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - ±0.5 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V [1] - - ±0.6 μA ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V - - 75 μA ΔICC additional supply current EN input - - 50 μA VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 7.5 - 29.9 mA/V VCC = 2.3 V to 2.7 V 15.0 - 38.0 mA/V VCC = 3.0 V to 3.6 V 17.8 - 39.2 mA/V 1.07 - 3.11 MΩ 0.75VCC - - V VCC = 0.8 V 0.75VCC - - V VCC = 0.9 V to 1.95 V 0.70VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25VCC V VCC = 0.8 V - - 0.25VCC V VCC = 0.9 V to 1.95 V - - 0.30VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V gfs Rbias forward transconductance see Fig. 8 and Fig. 9 bias resistance EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Fig. 3; for frequency behavior see Fig. 4 Tamb = -40 °C to +125 °C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 8 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter VOH Conditions Min Typ Max HIGH-level output voltage Y output; VI at X1 input = VIH or VIL IO = -20 μA; VCC = 0.8 V to 3.6 V V VCC - 0.11 - - V IO = -1.1 mA; VCC = 1.1 V 0.6VCC - - V IO = -1.7 mA; VCC = 1.4 V 0.93 - - V IO = -1.9 mA; VCC = 1.65 V 1.17 - - V IO = -2.3 mA; VCC = 2.3 V 1.77 - - V IO = -3.1 mA; VCC = 2.3 V 1.67 - - V IO = -2.7 mA; VCC = 3.0 V 2.40 - - V IO = -4.0 mA; VCC = 3.0 V 2.30 - - V X2 output; VI = GND or VCC IO = -20 μA; VCC = 0.8 V to 3.6 V VOL LOW-level output voltage Unit V VCC - 0.11 - - V IO = -1.1 mA; VCC = 1.1 V 0.6VCC - - V IO = -1.7 mA; VCC = 1.4 V 0.93 - - V IO = -1.9 mA; VCC = 1.65 V 1.17 - - V IO = -2.3 mA; VCC = 2.3 V 1.77 - - V IO = -3.1 mA; VCC = 2.3 V 1.67 - - V IO = -2.7 mA; VCC = 3.0 V 2.40 - - V IO = -4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V Y output; VI at X1 input = VIH or VIL 0.33VCC V X2 output; VI = GND or VCC 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © 0.33VCC V Nexperia B.V. 2020. All rights reserved 9 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - ±0.75 μA - - ±0.75 μA - - 15 μA EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC VI = GND; VCC = 0.8 V to 3.6 V IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - ±0.75 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V [1] - - ±0.75 μA ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V - - 75 μA ΔICC additional supply current EN input - - 75 μA VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 6.9 - 29.9 mA/V VCC = 2.3 V to 2.7 V 13.4 - 38.0 mA/V VCC = 3.0 V to 3.6 V 15.8 - 39.2 mA/V 1.07 - 3.11 MΩ VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V forward transconductance see Fig. 8 and Fig. 9 gfs Rbias [1] bias resistance EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Fig. 3; for frequency behavior see Fig. 4 Only for output Y and input EN. Rbias VCC II X1 X2 VI VO 001aai359 Fig. 3. Test circuit for measuring bias resistance 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 10 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 001aai159 20 Rbias (MΩ) 16 (1) 12 8 (2) 4 (3) 0 1.0 1.5 2.0 2.5 3.0 3.5 VCC (V) (1) fi = 30 kHz. (2) fi = 1 MHz. (3) fi = 10 MHz. Fig. 4. Typical bias resistance versus supply voltage 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Max Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Max Min Max Unit CL = 5 pF tpd propagation X1 to X2; see Fig. 5 delay VCC = 0.8 V - 12.8 - - - - - ns VCC = 1.1 V to 1.3 V 1.2 3.0 3.9 1.2 3.9 1.2 3.9 ns VCC = 1.4 V to 1.6 V 1.0 2.2 2.6 1.0 2.7 1.0 2.7 ns VCC = 1.65 V to 1.95 V 0.8 1.9 2.3 0.8 2.4 0.8 2.5 ns VCC = 2.3 V to 2.7 V 0.7 1.6 1.9 0.7 2.0 0.7 2.0 ns VCC = 3.0 V to 3.6 V 0.7 1.4 1.6 0.7 1.7 0.7 1.7 ns - 39.2 - - - - - ns VCC = 1.1 V to 1.3 V 2.5 8.0 10.7 2.3 10.8 2.3 10.9 ns VCC = 1.4 V to 1.6 V 2.2 5.5 6.6 2.0 7.0 2.0 7.0 ns VCC = 1.65 V to 1.95 V 1.8 4.4 5.5 1.7 5.9 1.7 6.0 ns VCC = 2.3 V to 2.7 V 1.5 3.5 4.1 1.4 4.4 1.4 4.5 ns VCC = 3.0 V to 3.6 V 1.5 3.1 3.5 1.4 3.8 1.4 3.8 ns X1 to Y; see Fig. 6 VCC = 0.8 V 74AUP1Z04_Q100 Product data sheet [2] [2] All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 11 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Max Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Max Min Max Unit CL = 10 pF tpd propagation X1 to X2; see Fig. 5 delay VCC = 0.8 V [2] - 20.9 - - - - - ns VCC = 1.1 V to 1.3 V 1.4 4.1 5.4 1.3 5.6 1.3 5.6 ns VCC = 1.4 V to 1.6 V 1.3 2.9 3.6 1.2 3.8 1.2 3.8 ns VCC = 1.65 V to 1.95 V 1.2 2.5 3.0 1.1 3.2 1.1 3.2 ns VCC = 2.3 V to 2.7 V 0.9 2.0 2.4 0.8 2.5 0.8 2.5 ns VCC = 3.0 V to 3.6 V 0.9 1.8 2.1 0.8 2.3 0.8 2.3 ns - 46.6 - - - - - ns VCC = 1.1 V to 1.3 V 2.7 9.2 12.4 2.5 12.7 2.5 12.7 ns VCC = 1.4 V to 1.6 V 2.5 6.3 7.8 2.2 8.2 2.2 8.2 ns VCC = 1.65 V to 1.95 V 2.3 5.0 6.2 2.2 6.7 2.2 6.7 ns VCC = 2.3 V to 2.7 V 1.8 4.0 4.7 1.7 5.0 1.7 5.1 ns VCC = 3.0 V to 3.6 V 1.9 3.6 4.2 1.8 4.5 1.8 4.5 ns - 28.9 - - - - - ns VCC = 1.1 V to 1.3 V 1.7 5.2 7.1 1.6 7.2 1.6 7.3 ns VCC = 1.4 V to 1.6 V 1.6 3.6 4.4 1.6 4.7 1.6 4.8 ns VCC = 1.65 V to 1.95 V 1.3 3.0 3.7 1.3 3.9 1.3 4.0 ns VCC = 2.3 V to 2.7 V 1.0 2.4 2.9 1.0 3.1 1.0 3.1 ns VCC = 3.0 V to 3.6 V 1.1 2.2 2.5 1.0 2.7 1.0 2.7 ns - 53.9 - - - - - ns VCC = 1.1 V to 1.3 V 3.1 10.4 14.2 2.8 14.6 2.8 14.7 ns VCC = 1.4 V to 1.6 V 2.9 7.0 8.5 2.7 9.2 2.7 9.3 ns VCC = 1.65 V to 1.95 V 2.5 5.6 6.9 2.3 7.4 2.3 7.5 ns VCC = 2.3 V to 2.7 V 2.1 4.5 5.4 2.0 5.7 2.0 5.7 ns VCC = 3.0 V to 3.6 V 2.3 4.1 4.7 2.1 5.1 2.1 5.1 ns X1 to Y; see Fig. 6 [2] VCC = 0.8 V CL = 15 pF tpd propagation X1 to X2; see Fig. 5 delay VCC = 0.8 V X1 to Y; see Fig. 6 VCC = 0.8 V 74AUP1Z04_Q100 Product data sheet [2] [2] All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 12 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Max Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Max Min Max Unit CL = 30 pF tpd propagation X1 to X2; see Fig. 5 delay VCC = 0.8 V [2] - 52.8 - - - - - ns VCC = 1.1 V to 1.3 V 2.4 8.5 11.8 2.3 12.2 2.3 12.4 ns VCC = 1.4 V to 1.6 V 2.2 5.6 6.8 2.0 7.5 2.0 7.6 ns VCC = 1.65 V to 1.95 V 2.0 4.5 5.6 1.9 6.2 1.9 6.2 ns VCC = 2.3 V to 2.7 V 1.5 3.7 4.2 1.4 4.6 1.4 4.6 ns VCC = 3.0 V to 3.6 V 1.7 3.3 3.7 1.6 4.0 1.6 4.2 ns - 77.6 - - - - - ns VCC = 1.1 V to 1.3 V 3.7 13.8 19.2 3.3 19.8 3.3 20.1 ns VCC = 1.4 V to 1.6 V 3.4 9.2 11.2 3.1 12.2 3.1 12.3 ns VCC = 1.65 V to 1.95 V 3.4 7.4 8.8 3.1 9.7 3.1 9.7 ns VCC = 2.3 V to 2.7 V 2.6 5.9 6.7 2.4 7.4 2.4 7.4 ns VCC = 3.0 V to 3.6 V 3.2 5.4 6.2 2.9 6.7 2.9 6.9 ns - 6.8 - - - - - pF VCC = 1.1 V to 1.3 V - 12.0 - - - - - pF VCC = 1.4 V to 1.6 V - 18.2 - - - - - pF VCC = 1.65 V to 1.95 V - 19.2 - - - - - pF VCC = 2.3 V to 2.7 V - 21.9 - - - - - pF VCC = 3.0 V to 3.6 V - 24.9 - - - - - pF X1 to Y; see Fig. 6 [2] VCC = 0.8 V CL = 5 pF, 10 pF, 15 pF and 30 pF CPD [1] [2] [3] [4] [5] fi = 1 MHz; EN = GND; power dissipation VI = GND to VCC capacitance VCC = 0.8 V [3] [4] [5] All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL. All specified values are the average typical values over all stated loads. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. Feedback current is included in the CPD. 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 13 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 11.1. Waveforms and test circuit VI VM X1 input GND tPLH tPHL VOH VM X2 output VOL mnb099 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig. 5. The input (X1) to output (X2) propagation delays VI VM X1 input GND tPHL tPLH VOH VM Y output VOL mnb100 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig. 6. The input (X1) to output (Y) propagation delays Table 9. Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5 × VCC 0.5 × VCC VCC ≤ 3.0 ns 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 14 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor VCC VI G VEXT 5 kΩ VO DUT RT CL RL 001aac521 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zoof the pulse generator. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ [1] VEXT RL [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2 × VCC For measuring enable and disable times RL = 5 kΩ. For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ. 001aad074 30 gfs (mA/V) Rbias 20 VCC 0.47 µF X 1 X2 100 µF Vi 10 Io 001aai360 0 fi = 1 kHz. VO is constant. Fig. 8. Product data sheet 1 2 3 VCC (V) 4 Tamb= 25°C. Test set-up for measuring forward transconductance 74AUP1Z04_Q100 0 Fig. 9. Typical forward transconductance as a function of supply voltage All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 15 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 12. Application information Crystal controlled oscillator circuits are widely used in clock pulse generators because of their excellent frequency stability and wide operating frequency range. The use of the 74AUP1Z04-Q100 provides the additional advantages of low power dissipation, stable operation over a wide range of frequency and temperature and a very small footprint. This application information describes crystal characteristics, design and testing of crystal oscillator circuits based on the 74AUP1Z04-Q100. 12.1. Crystal characteristics Fig. 10 is the equivalent circuit of a quartz crystal. The reactive and resistive component of the impedance of the crystal alone and the crystal with a series and a parallel capacitance is shown in Fig. 11. CX1 = CX0 LX1 RX1 001aai361 Fig. 10. Equivalent circuit of a crystal + CX1 CX0 (1) LX1 resistance R1 0 fr fa f reactance RX1 + CX0 (2) LX1 resistance RL CX1 0 fL fa f reactance RX1 CL + Rp resistance CX1 (3) CL CX0 LX1 0 fr fL fa RX1 f reactance 001aai362 (1) resonance (2) anti-resonance (3) load resonance Fig. 11. Reactance and resistance characteristics of a crystal 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 16 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 12.1.1. Design Fig. 12 shows the recommended way to connect a crystal to the 74AUP1Z04-Q100. This circuit is basically a Pierce oscillator circuit in which the crystal is operating at its fundamental frequency and is tuned by the parallel load capacitance of C1 and C2. C1 and C2 are in series with the crystal. They should be approximately equal. R1 is the drive-limiting resistor and is set to approximately the same value as the reactance of C1 at the crystal frequency (R1 = XC1). This will result in an input to the crystal of 50 % of the rail-to-rail output of X2. This keeps the drive level into the crystal within drive specifications (the designer should verify this). Overdriving the crystal can cause damage. The internal bias resistor provides negative feedback and sets a bias point of the inverter near midsupply, operating the 74AUP1GU04-Q100 portion in the high gain linear region. To calculate the values of C1 and C2, the designer can use the formula: CL is the load capacitance as specified by the crystal manufacturer, Cs is the stray capacitance of the circuit (for the 74AUP1Z04-Q100 this is equal to an input capacitance of 1.5 pF). 74AUP1GU04 portion 74AUP1G04 portion Rbias X1 Y X2 Xtal C2 system load R1 Csys Rsys C1 001aai363 Fig. 12. Crystal oscillator configuration for the 74AUP1Z04-Q100 12.1.2. Testing After the calculations are performed for a particular crystal, the oscillator circuit should be tested. The following simple checks will verify the prototype design of a crystal controlled oscillator circuit. Perform them after laying out the board: • • • • Test the oscillator over worst-case conditions (lowest supply voltage, worst-case crystal and highest operating temperature). Adding series and parallel resistors can simulate a worst-case crystal. Insure that the circuit does not oscillate without the crystal. Check the frequency stability over a supply range greater than that which is likely to occur during normal operation. Check that the start-up time is within system requirements. As the 74AUP1Z04-Q100 isolates the system loading, once the design is optimized, the single layout may work in multiple applications for any given crystal. 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 17 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 13. Package outline SOT363 (SC-88) 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 18 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor 14. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1Z04_Q100 v.1 20200818 Product data sheet - 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 - © Nexperia B.V. 2020. All rights reserved 19 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 16. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 20 / 21 74AUP1Z04-Q100 Nexperia Low-power X-tal driver with enable and internal resistor Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics...........................................11 11.1. Waveforms and test circuit.......................................14 12. Application information........................................... 16 12.1. Crystal characteristics..............................................16 12.1.1. Design...................................................................17 12.1.2. Testing.................................................................. 17 13. Package outline........................................................ 18 14. Abbreviations............................................................ 19 15. Revision history........................................................19 16. Legal information......................................................20 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 August 2020 74AUP1Z04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 August 2020 © Nexperia B.V. 2020. All rights reserved 21 / 21
74AUP1Z04GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74AUP1Z04GW-Q100H”相匹配的价格&库存,您可以联系我们找货
74AUP1Z04GW-Q100H
  • 1+4.854611+0.63087
  • 10+3.4323710+0.44605
  • 25+3.0702525+0.39899
  • 100+2.67345100+0.34743
  • 250+2.48390250+0.32279
  • 500+2.36954500+0.30793
  • 1000+2.275581000+0.29572
库存:2918
