74CBTLV3257BQ
74CBTLV3257BQ
    NEXPERIA(安世)
    DHVQFN16_3.5X2.5MM_EP
    74CBTLV3257BQ
74CBTLV3257BQ 数据手册
74CBTLV3257 Quad 1-of-2 multiplexer/demultiplexer Rev. 5 — 11 November 2016 Product data sheet 1. General description The 74CBTLV3257 provides a quad 1-of-2 high-speed multiplexer/demultiplexer with common select (S) and output enable (OE) inputs. The low ON resistance of the switch allows inputs to be connected to outputs without adding propagation delay or generating additional ground bounce noise. When pin OE = LOW, one of the two switches is selected (low-impedance ON-state) with pin S. When pin OE = HIGH, all switches are in the high-impedance OFF-state, independent of pin S. Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 2.3 V to 3.6 V. To ensure the high-impedance OFF-state during power-up or power-down, OE should be tied to the VCC through a pull-up resistor. The minimum value of the resistor is determined by the current-sinking capability of the driver. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Supply voltage range from 2.3 V to 3.6 V  High noise immunity  Complies with JEDEC standard:  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM AEC-Q100-011 revision B exceeds 1000 V  5  switch connection between two ports  Rail to rail switching on data I/O ports  CMOS low power consumption  Latch-up performance exceeds 250 mA per JESD78B Class I level A  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74CBTLV3257D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74CBTLV3257DS 40 C to +125 C SSOP16[1] plastic shrink small outline package; 16 leads; body width 3.9 mm; lead pitch 0.635 mm SOT519-1 74CBTLV3257PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74CBTLV3257BQ 40 C to +125 C DHVQFN16 plastic dual-in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm [1] SOT763-1 Also known as QSOP16. 4. Functional diagram $    $    $    $    6 2( Fig 1. % % % % % % % %   DDO Logic diagram 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 2 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 5. Pinning information 5.1 Pinning %   % $   % %   $ %   % $   % *1'   &%7/9 $ 6  2(   %   2( 6   9&& %   % %   2( $   % %   % %   $ $   % %  %   $ $  %   % $   % *1'   DDO $ *1'   %  %  % WHUPLQDO LQGH[DUHD   9&& $  *1' 6  9&& &%7/9 &%7/9 DDO 7UDQVSDUHQWWRSYLHZ DDO (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 2. Pin configuration SOT109-1 (SO16) and SOT519-1 (SSOP16) Fig 3. Pin configuration SOT403-1 (TSSOP16) Fig 4. Pin configuration SOT763-1 (DHVQFN16) 5.2 Pin description Table 2. Pin description Symbol Pin Description S 1 select input 1B1 to 4B1 2, 5, 11, 14 B1 input/output 1B2 to 4B2 3, 6, 10, 13 B2 input/output 1A to 4A 4, 7, 9, 12 A input/output GND 8 ground (0 V) OE 15 output enable input (active LOW) VCC 16 supply voltage 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 3 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 6. Functional description Table 3. Function table[1] Inputs Function switch OE S L L nA = nB1 L H nA = nB2 H X disconnect nA and nBn [1] H = HIGH voltage level; L = LOW voltage level. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +4.6 V 0.5 +4.6 V 0.5 VCC + 0.5 V VI input voltage control inputs [1] VSW switch voltage enable and disable mode [2] IIK input clamping current VI < 0.5 V 50 - mA ISK switch clamping current VI < 0.5 V 50 - mA VSW = 0 V to VCC ISW switch current - 128 mA ICC supply current - +100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [3] [1] The minimum input voltage rating may be exceeded if the input clamping current ratings are observed. [2] The switch voltage ratings may be exceeded if switch clamping current ratings are observed [3] For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN16 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW switch voltage Conditions enable and disable mode Tamb ambient temperature t/V input transition rise and fall rate [1] VCC = 2.3 V to 3.6 V [1] Min Max Unit 2.3 3.6 V 0 3.6 V 0 VCC V 40 +125 C 0 200 ns/V Applies to control signal levels. 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 4 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 9. Static characteristics Table 6. Static characteristics At recommended operating conditions voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - V LOW-level input VCC = 2.3 V to 2.7 V voltage VCC = 3.0 V to 3.6 V - - 0.7 - 0.7 V - - 0.9 - 0.9 V II input leakage current - - 1 - 20 A IS(OFF) OFF-state VCC = 3.6 V; see Figure 5 leakage current - - 1 - 20 A IS(ON) ON-state VCC = 3.6 V; see Figure 6 leakage current - - 1 - 20 A IOFF power-off VI or VO = 0 V to 3.6 V; leakage current VCC = 0 V - - 10 - 50 A ICC supply current VI = GND or VCC; IO = 0 A; VSW = GND or VCC; VCC = 3.6 V - - 10 - 50 A ICC additional supply current pin OE, S; VI = VCC  0.6 V; VSW = GND or VCC; VCC = 3.6 V - - 300 - 2000 A CI input capacitance pin OE, S; VCC = 3.3 V; VI = 0 V to 3.3 V - 0.9 - - - pF CS(OFF) OFF-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 5.2 - - - pF CS(ON) ON-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 14.3 - - - pF HIGH-level input voltage VIH VIL pin OE, S; VI = GND to VCC; VCC = 3.6 V [1] All typical values are measured at Tamb = 25 C. [2] One input at 3 V, other inputs at VCC or GND. [2] 9.1 Test circuits 9&& 9&& Q2( 9,+ ,V $ 9O Q%Q Q$ Q2( 9,/ ,V ,V $ $ *1' 92 9O DDL Product data sheet *1' 92 VI = VCC or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current (one switch) 74CBTLV3257 Q%Q DDL VI = VCC or GND and VO = GND or VCC. Fig 5. Q$ Fig 6. Test circuit for measuring ON-state leakage current (one switch) All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 5 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 9.2 ON resistance Table 7. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter RON Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 64 mA; VI = 0 V - 4.2 8.0 - 15.0  ISW = 24 mA; VI = 0 V - 4.2 8.0 - 15.0  ISW = 15 mA; VI = 1.7 V - 8.4 40.0 - 60.0  ISW = 64 mA; VI = 0 V - 4.0 7.0 - 11.0  ISW = 24 mA; VI = 0 V - 4.0 7.0 - 11.0  ISW = 15 mA; VI = 2.4 V - 6.2 15.0 - 25.5  ON resistance VCC = 2.3 V to 2.7 V; see Figure 8 to Figure 10 [2] VCC = 3.0 V to 3.6 V; see Figure 11 to Figure 13 [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is determined by the lower of the voltages of the two (A or B) terminals. 9.3 ON resistance test circuit and graphs DDL  521 ȍ  96: 9  9&&  Q2( 9,/   Q$ 9O Q%Q *1'   ,6:        9, 9 DDL (1) Tamb = 125 C. RON = VSW / ISW. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 7. Test circuit for measuring ON resistance (one switch) 74CBTLV3257 Product data sheet Fig 8. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 15 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 6 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer DDL  521 ȍ DDL  521 ȍ                            9, 9 (1) Tamb = 125 C. (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 9. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 24 mA DDL   9, 9 521 ȍ Fig 10. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 64 mA DDL  521 ȍ                      9, 9 (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 11. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 15 mA Product data sheet   9, 9 (1) Tamb = 125 C. 74CBTLV3257  Fig 12. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 24 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 7 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer DDL  521 ȍ               9, 9 (1) Tamb = 125 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 13. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 64 mA 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 8 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 10. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; for test circuit see Figure 16 Symbol Parameter Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Conditions Min Typ[1] Max Min Max - - 0.15 - 0.25 ns - - 0.15 - 0.25 ns 1.0 3.8 6.1 1.0 6.7 ns 1.0 3.2 5.3 1.0 5.8 ns VCC = 2.3 V to 2.7 V 1.0 2.2 5.6 1.0 6.2 ns VCC = 3.0 V to 3.6 V 1.0 2.0 5.0 1.0 5.5 ns VCC = 2.3 V to 2.7 V 1.0 3.5 6.1 1.0 6.7 ns VCC = 3.0 V to 3.6 V 1.0 3.0 5.3 1.0 5.8 ns VCC = 2.3 V to 2.7 V 1.0 2.6 5.5 1.0 6.1 ns VCC = 3.0 V to 3.6 V 1.0 3.1 5.5 1.0 6.1 ns VCC = 2.3 V to 2.7 V 1.0 2.6 4.8 1.0 5.3 ns VCC = 3.0 V to 3.6 V 1.0 3.2 4.5 1.0 5.0 ns propagation delay nA to nBn or nBn to nA; see Figure 14 tpd [2][3] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V S to nA; see Figure 14 [3] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V enable time ten [4] OE to nA or nBn; see Figure 15 S to nBn; see Figure 15 disable time tdis [5] OE to nA or nBn; see Figure 15 S to nBn; see Figure 15 [1] All typical values are measured at Tamb = 25 C and at nominal VCC. [2] The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when driven by an ideal voltage source (zero output impedance). [3] tpd is the same as tPLH and tPHL. [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPHZ and tPLZ. 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 9 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 11. Waveforms 9, LQSXW 90 90 9 W3+/ W3/+ 92+ 90 RXWSXW 90 92/ DDL Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 14. The data input (nA or nBn) to output (nBn or nA) propagation delays Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM VX VY 2.3 V to 2.7 V 0.5VCC VCC  2.0 ns 0.5VCC VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5VCC VCC  2.0 ns 0.5VCC VOL + 0.3 V VOH  0.3 V 9, 90 2(6LQSXW 90 *1' W3=/ W3/= 9&& RXWSXW /2:WR2)) 2))WR/2: 90 9; 92/ W3=+ W3+= 92+ RXWSXW +,*+WR2)) 2))WR+,*+ 9< 90 *1' VZLWFK HQDEOHG VZLWFK GLVDEOHG VZLWFK HQDEOHG DDO Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 15. Enable and disable times 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 10 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer W: 9,  QHJDWLYH SXOVH 90 90  9 WI WU WU WI 9,  SRVLWLYH SXOVH 90 90  9 W: 9(;7 9&& * 9, 5/ 92 '87 57 5/ &/ DDH Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 16. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 2.3 V to 2.7 V 30 pF 500  open GND 2VCC 3.0 V to 3.6 V 50 pF 500  open GND 2VCC 74CBTLV3257 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 11 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 11.1 Additional dynamic characteristics Table 11. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise specified); tr = tf 2.5 ns. Symbol Parameter f(3dB) [1] Tamb = 25 C Conditions 3 dB frequency response VCC = 3.3 V; RL = 50 ; see Figure 17 [1] Unit Min Typ Max - 398 - MHz fi is biased at 0.5VCC. 11.2 Test circuits 9&& 9&& 6 9,/RU9,+ 5/ Q%Q 2( Q$ *1' 9,/ G% IL DDD OE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB. Fig 17. Test circuit for measuring the frequency response when channel is in ON-state 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 12 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 18. Package outline SOT109-1 (SO16) 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 13 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPPOHDGSLWFKPP ' ( 627 $ ; F \ +( Y 0 $ =   $ $ $   $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S Y Z \ =   ș PP                           R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(    Fig 19. Package outline SOT519-1 (SSOP16) 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 14 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ 02 (8523($1 352-(&7,21 ,668('$7(   Fig 20. Package outline SOT403-1 (TSSOP16) 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 15 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H / Y Z \ \        H  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 21. Package outline SOT763-1 (DHVQFN16) 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 16 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 13. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CBTLV3257 v.5 20161111 Product data sheet - 74CBTLV3257 v.4 - 74CBTLV3257 v.3 Modifications: 74CBTLV3257 v.4 Modifications: • Section 11.1 and Section 11.2 added. 20111216 • Product data sheet Legal pages updated. 74CBTLV3257 v.3 20110106 Product data sheet - 74CBTLV3257 v.2 74CBTLV3257 v.2 20101126 Product data sheet - 74CBTLV3257 v.1 74CBTLV3257 v.1 20100112 Product data sheet - - 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 17 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74CBTLV3257 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 18 of 20 74CBTLV3257 NXP Semiconductors Quad 1-of-2 multiplexer/demultiplexer Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74CBTLV3257 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © NXP Semiconductors N.V. 2016. All rights reserved. 19 of 20 NXP Semiconductors 74CBTLV3257 Quad 1-of-2 multiplexer/demultiplexer 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 9.2 9.3 10 11 11.1 11.2 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 ON resistance . . . . . . . . . . . . . . . . . . . . . . . . . . 6 ON resistance test circuit and graphs. . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Additional dynamic characteristics . . . . . . . . . 12 Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP Semiconductors N.V. 2016. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 November 2016 Document identifier: 74CBTLV3257
74CBTLV3257BQ 价格&库存
很抱歉,暂时无法提供与“74CBTLV3257BQ”相匹配的价格&库存,您可以联系我们找货
