74HCT4052BQ
74HCT4052BQ
    NEXPERIA(安世)
    NEXPERIA - 74HCT4052BQ - IC, MUX/DEMUX DUAL 4-CH, DHVQFN16
74HCT4052BQ 数据手册
74HC4052; 74HCT4052 Dual 4-channel analog multiplexer/demultiplexer Rev. 11 — 10 February 2016 Product data sheet 1. General description The 74HC4052; 74HCT4052 is a dual single-pole quad-throw analog switch (2x SP4T) suitable for use in analog or digital 4:1 multiplexer/demultiplexer applications. Each switch features four independent inputs/outputs (nY0, nY1, nY2 and nY3) and a common input/output (nZ). A digital enable input (E) and two digital select inputs (S0 and S1) are common to both switches. When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Wide analog input voltage range from 5 V to +5 V  Low ON resistance:  80  (typical) at VCC  VEE = 4.5 V  70  (typical) at VCC  VEE = 6.0 V  60  (typical) at VCC  VEE = 9.0 V  Logic level translation: to enable 5 V logic to communicate with 5 V analog signals  Typical ‘break before make’ built-in  Complies with JEDEC standard no. 7A  Input levels:  For 74HC4052: CMOS level  For 74HCT4052: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Specified from 40 C to +85 C and 40 C to +125 C 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 74HC4052; 74HCT4052 NXP Semiconductors Dual 4-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information Type number 74HC4052D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual-in line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 74HCT4052D 74HC4052DB 74HCT4052DB 74HC4052PW 74HCT4052PW 74HC4052BQ 74HCT4052BQ 5. Functional diagram  =
74HCT4052BQ 价格&库存
很抱歉,暂时无法提供与“74HCT4052BQ”相匹配的价格&库存,您可以联系我们找货
