HPZR-C23X
HPZR-C23X
    NEXPERIA(安世)
    Diode Zener Single 23.35V 5% 4100mW 2-Pin SOD-123W
HPZR-C23X 数据手册
HPZR series High power voltage regulator diodes Rev. 2 — 12 September 2022 Product data sheet 1. General description Low-current voltage regulator diodes in a CFP3 (SOD123W) small and flat lead low-profile SurfaceMounted Device (SMD) plastic package. 2. Features and benefits • • • • Total power dissipation: ≤ 962 mW Tolerance series: Approximately ±5 % Working voltage range: nominal 5.6 V to 75 V ESD maximum rating 30 kV according IEC 61000-4-2 (contact discharge) 3. Applications • Low-currect general regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 100 mA PZSM non-repetitive peak power dissipation square wave; tp ≤ 100 µs Ptot total power dissipation Tamb ≤ 25 °C [1] [2] Min Typ Max Unit [1] - - 1 V - - 800 W [2] - - 962 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 cathode 1 cm HPZR series Nexperia High power voltage regulator diodes 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline [1] 1 Graphic symbol 2 A K 006aaa152 [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number HPZR series Package Name Description Version CFP3 plastic, surface mounted package; 2 terminals; 2.6 mm x 1.7 mm x 1 mm body SOD123W 7. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code HPZR-C5V6 LM HPZR-C15 M3 HPZR-C39 MF HPZR-C6V7 LN HPZR-C17 M4 HPZR-C42 MG HPZR-C7V0 LP HPZR-C18 M5 HPZR-C47 MH HPZR-C7V6 LR HPZR-C19 M6 HPZR-C50 MJ HPZR-C8V2 LS HPZR-C20 M7 HPZR-C53 MK HPZR-C8V8 LT HPZR-C21 M8 HPZR-C56 ML HPZR-C9V4 LU HPZR-C23 M9 HPZR-C60 MM HPZR-C10 LV HPZR-C26 MA HPZR-C63 MN HPZR-C11 LW HPZR-C28 MB HPZR-C68 MP HPZR-C12 LX HPZR-C30 MC HPZR-C70 MR HPZR-C13 LY HPZR-C33 MD HPZR-C75 MS HPZR-C14 M2 HPZR-C35 ME - - HPZR_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 2 / 12 HPZR series Nexperia High power voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current PZSM non-repetitive peak power dissipation IFSM Ptot Conditions Min Max Unit - 400 mA square wave; tp ≤ 100 µs - 800 W non-repetitive peak forward current single half-sine wave; tp = 8.3 ms - 50 A total power dissipation Tamb ≤ 25 °C [1] - 568 mW [2] - 962 mW [3] - 1786 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 +150 °C Tstg storage temperature -65 +150 °C Max Unit 30 kV [1] [2] [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Device mounted on ceramic PCB, Al2O3, standard footprint. Table 6. ESD maximum ratings Symbol Parameter Conditions Min Per diode VESD [1] [2] electrostatic discharge voltage IEC 61000-4-2 (contact discharge) [1] [2] Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses. Soldering point of cathode tab. Table 7. ESD standard compliance Test and measurement Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 8 kV HPZR_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 HPZR series Nexperia High power voltage regulator diodes 9. Thermal characteristics Table 8. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air Rth(j-sp) [1] [2] [3] [4] thermal resistance from junction to ambient thermal resistance from junction to solder point Min Typ Max Unit [1] - - 220 K/W [2] - - 130 K/W [3] - - 70 K/W [4] - - 18 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Device mounted on ceramic PCB, Al2O3, standard footprint. Soldering point of cathode tab. 10. Characteristics Table 9. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 100 mA [1] Min [1] - Typ Max Unit - 1 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Table 10. Characteristics per type; HPZR-C5V6 to HPZR-C8V2 Tj = 25 °C unless otherwise specified. HPZR -Cxxx Working voltage VZ (V) IZ = 10 mA Differential resistance RZ (Ω) IZ = 20 mA Reverse current IR (μA) Min Max Max VR (V) Max 5V6 5.20 6.00 600 3.3 63.60 6V7 6.40 7.00 400 5.0 42.40 7V0 6.67 7.37 400 6.0 4.77 7V6 7.22 7.98 250 6.5 11.60 8V2 7.78 8.60 100 7.0 13.25 HPZR_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 4 / 12 HPZR series Nexperia High power voltage regulator diodes Table 11. Characteristics per type; HPZR-C8V8 to HPZR-C75 Tj = 25 °C unless otherwise specified. HPZR -Cxxx Working voltage VZ (V) IZ = 1 mA Differential resistance RZ (Ω) IZ = 20 mA Reverse current IR (μA) Min Max Max VR (V) Max 8V8 8.33 9.21 50 7.5 14.84 9V4 8.89 9.83 25 8.0 16.43 10 9.44 10.40 10 8.5 18.02 11 10.00 11.10 5 9.0 19.61 12 11.10 12.30 2.5 10.0 21.20 13 12.20 13.50 2.5 11.0 22.79 14 13.30 14.70 2.5 12 24.38 15 14.40 15.90 0.1 13 25.97 17 15.60 17.20 0.1 14 27.56 18 16.70 18.50 0.1 15 29.15 19 17.80 19.70 0.1 16 30.74 20 18.90 20.90 0.1 17 32.33 21 20.00 22.10 0.1 18 33.92 23 22.20 24.50 0.1 20 35.51 26 24.40 26.90 0.1 22 36.57 28 26.70 29.50 0.1 24 37.10 30 28.90 31.90 0.1 26 40.28 33 31.10 34.40 0.1 28 43.46 35 33.30 36.80 0.1 30 46.64 39 36.70 40.60 0.1 33 49.82 42 40.00 44.20 0.1 36 53.00 47 44.40 49.10 0.1 40 56.18 50 47.80 52.80 0.1 43 59.36 53 50.00 55.30 0.1 45 62.54 56 53.30 58.90 0.1 48 65.72 60 56.70 62.70 0.1 51 68.90 63 60.00 66.30 0.1 54 72.08 68 64.40 71.20 0.1 58 75.26 70 66.70 73.70 0.1 60 76.32 75 71.10 78.60 0.1 64 77.38 HPZR_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 HPZR series Nexperia High power voltage regulator diodes aaa-035292 103 aaa-035293 1 IF (A) PZSM (W) 10-1 102 10-2 10-3 10 10-4 1 10-1 1 tp (ms) 10 10-5 0.4 (1) Tj = 25 °C (before surge) Fig. 1. Fig. 2. aaa-035294 IF (A) VF (V) 1 Forward current as a function of forward voltage; typical values (HPZR-C5V6) aaa-035295 1 IF (A) 10-1 10-1 10-2 10-2 10-3 10-3 10-4 10-4 10-5 0.4 0.6 0.8 VF (V) 1 10-5 0.4 Tj = 25 °C Fig. 3. 0.8 Tj = 25 °C Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values 1 0.6 Product data sheet 0.8 VF (V) 1 Tj = 25 °C Forward current as a function of forward voltage; typical values (HPZR-C7V0) HPZR_SER 0.6 Fig. 4. Forward current as a function of forward voltage; typical values (HPZR-C8V2) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 HPZR series Nexperia High power voltage regulator diodes aaa-035296 1 IF (A) 10-1 10-2 10-3 10-4 10-5 0.4 0.6 0.8 VF (V) 1 Tj = 25 °C Fig. 5. Forward current as a function of forward voltage; typical values (HPZR-C68) 11. Package outline 1.9 1.5 1.1 0.9 1 0.6 0.3 3.7 3.3 2.8 2.4 2 1.05 0.75 Dimensions in mm Fig. 6. HPZR_SER Product data sheet 0.22 0.10 08-11-06 Package outline CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 HPZR series Nexperia High power voltage regulator diodes 12. Soldering Footprint information for reflow soldering of CFP3 package SOD123W 4.4 2.9 2.8 2.1 1.6 1.1 1.2 1.4 1.1 1.2 1.4 recommended stencil thickness: 0.1 mm occupied area solder resist solder land solder paste Dimensions in mm Issue date Fig. 7. HPZR_SER Product data sheet 17-06-09 20-02-28 sod123w_fr Reflow soldering footprint for CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 HPZR series Nexperia High power voltage regulator diodes Wave soldering footprint information SOD123W 8.3 4.8 1.8 3.5 2.4 (2×) 2.55 (2×) 3.0 (2×) occupied area solder resist solder lands dummy track (solder resist and Cu free) 3.15 (2×) Dimensions in mm Issue date Fig. 8. HPZR_SER Product data sheet 17-06-06 17-06-07 sod123w_fw Wave soldering footprint for CFP3 (SOD123W) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 HPZR series Nexperia High power voltage regulator diodes 13. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HPZR_SER v.1 20220912 Product data sheet - HPZR_SER v.1 Modifications: • HPZR_SER v.1 20220520 - - HPZR_SER Product data sheet Product status changed Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 HPZR series Nexperia High power voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HPZR_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 HPZR series Nexperia High power voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 4 11. Package outline.......................................................... 7 12. Soldering..................................................................... 8 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 September 2022 HPZR_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 September 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
HPZR-C23X 价格&库存
很抱歉,暂时无法提供与“HPZR-C23X”相匹配的价格&库存,您可以联系我们找货
HPZR-C23X
  • 1+5.026521+0.64847
  • 10+3.0714110+0.39624
  • 100+1.95394100+0.25208
  • 500+1.46871500+0.18948
  • 1000+1.311981000+0.16926
库存:2550
HPZR-C23X
  • 3000+1.112463000+0.14352
  • 6000+1.011886000+0.13054
  • 9000+0.960619000+0.12393
  • 15000+0.9029815000+0.11650
  • 21000+0.8688521000+0.11209
  • 30000+0.8356930000+0.10781
库存:2550
