1SMB5929B
1SMB5929B
    MDD(辰达半导体)
    SMB(DO-214AA)
    表面贴装齐纳二极管,适用于表面贴装设计的小型塑料封装,符合ROHS标准
1SMB5929B 数据手册
1SMB5913B THRU 1SMB5956B Zener Voltage - 3.3 to 200 Volts Peak Pulse Power - 3.0 W SURFACE MOUNT ZENER DIODE Features DO-214AA/SMB  Small plastic package suitable for surface mounted design. 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.071 (1.80) Mechanical Data 0.185(4.70) 0.160(4.06) Case : JEDEC SMB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.002ounce, 0.055grams 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. Standard packing : 12mm tape(E1A-481) 0.220(5.59) 0.200(5.08) Dimensions in inches and (millimeters) Ordering Information Parameter Symbol DC power dissipation at TL=75°C, measure at zero lead length (Note 1) derate above 75°C PD Maximum Steady State Power Dissipation @ TA=25°C Derate above 25°C PD Value Unit 3.0 W 40 。 mW/ C 550 mW 4.4 。 mW/ C Junction to ambient thermal resistance R thJA 226 °C/W Junction to lead thermal resistance R thJL 25 °C/W Junction Temperature Range TJ - 55 to + 150 °C Storage Temperature Range T STG - 55 to + 150 °C Note: 1. Mounted on Cu-Pad size 5mm x 5mm on PCB. PD mAXIMUM POWER DISSPATION (W) ELECTRICAL CHARACTERISTICS (T L = 30°C unless otherwise noted, V F = 1.5 V Max. @ I F = 200 mA(DC) for all types) 5.0 4.0 3.0 2.0 1.0 0.0 Single phase half-wave 60 Hz resistive or inductive load 25 50 75 100 125 Case Temperature (°C) 150 175 I Parameter Symbol Fig.1 Forward Current Derating Curve Vz Reverse Zener Voltage @ I ZT I ZT Reverse Current Z ZT Maximum Zener Impedance @ I ZT I ZK Reverse Current Z ZK Maximum Zener Impedance @ I ZK IR Reverse Leakage Current @ V R VR Reverse Voltage IF Forward Current VF Forward Voltage @ I F I ZM Maximum DC Zener Current IF VR VZ V IR VF I ZT Zener Voltage Regulator Notes On Page 2: 1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5% 2. Zener voltage (Vz) measurement Nominal Zener v oltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C 3. Zener impedance (Zz) derivation : Z ZT and Z ZK are measured by dividing the AC voltage drop across the device by the AC current applied. The specified limits are for Iz(AC) = 0.1 Iz(DC) with the AC frequency = 60 Hz DN:T20828A0 http://www.microdiode.com Rev:2020A1 Page :1 1SMB5913B THRU 1SMB5956B Zener Voltage - 3.3 to 200 Volts Peak Pulse Power - 3.0 W Ratings And Characteristic Curves Characteristics at Ta = 25°C (Devices listed in bold, italic are ON Semiconductor Preferred devices.) (TL = 30°C unless otherwise noted, VF = 1.5 V Max. @ IF = 200 mA(DC) for all types) Nominal Zener Voltage Type Marking Zener (4) Impedance (3) Vz Min(V) Nom(V) (2) Max(V) I ZT Z ZT@ I ZT (mA) (Ω) Leakage Current IR @ VR Z ZK@ I ZK (Ω) (mA) (μA) (V) Maximum DC Zener Current I ZM (mA)(DC) 1SMB5913B 913B 3.13 3.3 3.47 113.6 10 500 1 100 1 454 1SMB5914B 914B 3.42 3.6 3.78 104.2 9 500 1 75 1 416 1SMB5915B 915B 3.70 3.9 4.10 96.1 7.5 500 1 25 1 384 1SMB5916B 916B 4.08 4.3 4.52 87.2 6 500 1 5 1 348 1SMB5917B 917B 4.46 4.7 4.94 79.8 5 500 1 5 1.5 319 1SMB5918B 918B 4.84 5.1 5.36 73.5 4 350 1 5 2 294 1SMB5919B 919B 5.32 5.6 5.88 66.9 2 250 1 5 3 267 1SMB5920B 920B 5.89 6.2 6.51 60.5 2 200 1 5 4 241 1SMB5921B 921B 6.46 6.8 7.14 55.1 2.5 200 1 5 5.2 220 1SMB5922B 922B 7.12 7.5 7.88 50 3 400 0.5 5 6 200 1SMB5923B 923B 7.79 8.2 8.61 45.7 3.5 400 0.5 5 6.5 182 1SMB5924B 924B 8.64 9.1 9.56 41.2 4 500 0.5 5 7 164 1SMB5925B 925B 9.5 10 10.5 37.5 4.5 500 0.25 5 8 150 1SMB5926B 926B 10.45 11 11.55 34.1 5.5 550 0.25 1 8.4 136 1SMB5927B 927B 11.4 12 12.6 31.2 6.5 550 0.25 1 9.1 125 1SMB5928B 928B 12.35 13 13.65 28.8 7 550 0.25 1 9.9 115 1SMB5929B 929B 14.25 15 15.75 25 9 600 0.25 1 11.4 100 1SMB5930B 930B 15.2 16 16.8 23.4 10 600 0.25 1 12.2 93 1SMB5931B 931B 17.1 18 18.9 20.8 12 650 0.25 1 13.7 83 1SMB5932B 932B 19 20 21 18.7 14 650 0.25 1 15.2 75 1SMB5933B 933B 20.9 22 23.1 17 17.5 650 0.25 1 16.7 68 1SMB5934B 934B 22.8 24 25.2 15.6 19 700 0.25 1 18.2 62 1SMB5935B 935B 25.65 27 28.35 13.9 23 700 0.25 1 20.6 55 1SMB5936B 936B 28.5 30 31.5 12.5 28 750 0.25 1 22.8 50 1SMB5937B 937B 31.35 33 34.65 11.4 33 800 0.25 1 25.1 45 1SMB5938B 938B 34.2 36 37.8 10.4 38 850 0.25 1 27.4 41 1SMB5939B 939B 37.05 39 40.95 9.6 45 900 0.25 1 29.7 38 1SMB5940B 940B 40.85 43 45.15 8.7 53 950 0.25 1 32.7 34 1SMB5941B 941B 44.65 47 49.35 8 67 1000 0.25 1 35.8 31 1SMB5942B 942B 48.45 51 53.55 7.3 70 1100 0.25 1 38.8 29 1SMB5943B 943B 53.2 56 58.8 6.7 86 1300 0.25 1 42.6 26 1SMB5944B 944B 58.9 62 65.1 6 100 1500 0.25 1 47.1 24 1SMB5945B 945B 64.6 68 71.4 5.5 120 1700 0.25 1 51.7 22 1SMB5946B 946B 71.25 75 78.75 5 140 2000 0.25 1 56 20 1SMB5947B 947B 77.9 82 86.1 4.6 160 2500 0.25 1 62.2 18 1SMB5948B 948B 86.45 91 95.55 4.1 200 3000 0.25 1 69.2 16 1SMB5949B 949B 95 100 105 3.7 250 3100 0.25 1 76 15 1SMB5950B 950B 104.5 110 115.5 3.4 300 4000 0.25 1 83.6 13 1SMB5951B 951B 114 120 126 3.1 380 4500 0.25 1 91.2 12 1SMB5952B 952B 123.5 130 136.5 2.9 450 5000 0.25 1 98.8 11 1SMB5953B 953B 142.5 150 157.5 2.5 600 6000 0.25 1 114 10 1SMB5954B 954B 152 160 168 2.3 700 6500 0.25 1 121.6 9 1SMB5955B 955B 171 180 189 2.1 900 7000 0.25 1 136.8 8 1SMB5956B 956B 190 200 210 1.9 1200 8000 0.25 1 152 7 Note :( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates ± 5.0% tolerance. http://www.microdiode.com Rev:2020A1 Page :2 1SMB5913B THRU 1SMB5956B Zener Voltage - 3.3 to 200 Volts Peak Pulse Power - 3.0 W Packing information P0 P1 d unit:mm E F B A Item W D2 D1 C W1 D Tolerance SMB A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 3.81 5.41 2.42 1 5.0 330.00 50.00 13.00 1.75 5.55 8.00 4.00 2.00 0.30 12.00 12.30 Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width P T Symbol Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMB REEL SIZE REEL (pcs) COMPONENT SPACING (mm) 13" 3,000 4.0 BOX (pcs) 6,000 INNER BOX (mm) REEL DIA, (mm) CARTON SIZE (mm) CARTON (pcs) 190*190*41 330 365*365*360 48,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout Symbol A B C D E http://www.microdiode.com Unit (mm) 2.8 2.4 Unit (inch) 0.110 4.6 0.094 0.181 2.2 7.0 0.086 0.276 Rev:2020A1 Page :5
1SMB5929B 价格&库存
很抱歉,暂时无法提供与“1SMB5929B”相匹配的价格&库存,您可以联系我们找货
