ESD03D6BU
Ultra Low Capacitance ESD Protection Diode
DFN0603 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
ESD03D6BU is a low-capacitance Transient Voltage Suppressor (TVS) designed to provide
electrostatic discharge (ESD) protection for high-speed data interfaces. With typical capacitance of
0.25pF, GESD03D6BU is designed to protect parasitic-sensitive systems against over-voltage and
over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact
discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device
model (CDM) ESD and cable discharge event (CDE), etc.
ESD03D6BU uses ultra-small DFN0603 package. Each ESD03D6BU device can protect one highspeed data line. It offers system designers flexibility to protect single data line where space is a
premium concern. The combined features of low capacitance, ultra-small size and high ESD
robustness make ESD03D6BU ideal for high-speed data port and high-frequency line applications,
such as cellular phones and HD visual devices.
Features
Peak Power Dissipation :96 W (8/20μs)
Transient protection for high-speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Package optimized for high-speed lines
Protects one data, control line
Low Capacitance: 0.25pF (Typical)
Low leakage current
Low clamping voltage
Applications
Pin Configuration
Serial ATA
Desktops, Servers and Notebooks
Cellular Phones
MDDI Ports
USB Data Line Protection
Display Ports
Digital Visual Interfaces (DVI)
Circuit Diagram
Mechanical Characteristics
Package: DFN0603
Flammability Rating: UL 94V-0
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Packaging: Tape and Reel
Marking: 3BU
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 20
± 20
KV
Peak Pulse Power(8/20us )
PPP
96
W
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature
TSTG
−55 to +150
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
The above data are for reference only.
DN:T20402A0
http://www.microdiode.com
Rev:2020A0
Page :1
ESD03D6BU
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
bol
Param
Test Condition
Min
Typ
Max
Units
3.3
V
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IT = 1mA
IR
Reverse Leakage Current
VRWM = 3.3V
100
nA
IPP = 1A, tp = 8/20μs
12
V
IPP = 4A, tp = 8/20μs
24
V
VC
Clamping Voltage
CJ
Junction Capacitance
VR = 0V, f = 1MHz
4.2
V
0.25
pF
Rev:2020A0
Page :2
ESD03D6BU
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2020A0
Page :3
ESD03D6BU
Outlitne Drawing
DFN0603 Package Outline Dimensions
Symbol
A
D
E
b
c
e
L1
L2
Dimensions In Millimeters
Min.
Max.
0.275
5
340
0.570
0.270
0.225
5
295
0.050 REF.
0.365
5
435
0.125
5
195
0.030 REF.
Dimensions In Inches
Min.
Max.
0.011
0.013
0.022
0.026
0.011
0.015
0.009
0.012
0.002 REF.
0.014
0.017
0.005
0.008
0.001 REF.
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
DFN0603
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
10,000
210×210×205
100,000
445×445×230
400,000
7'
Rev:2020A0
Page :4
很抱歉,暂时无法提供与“ESD03D6BU”相匹配的价格&库存,您可以联系我们找货
