FS2M
FS2M
    MDD(辰达半导体)
    SMA(DO-214AC)
    反向恢复时间(trr):500ns;平均整流电流(Io):2A;直流反向耐压(Vr):1kV;正向压降(Vf):1.7V @ 2A;二极管配置:-;
FS2M 数据手册
FS2A THRU FS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere SURFACE MOUNT FAET RECOVERY RECTIFIER Features DO-214AC/SMA  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 0.110(2.80) 0.094(2.40) 0.067 (1.70) 0.051 (1.30)  Idea for printed circuit board  Glass passivated Junction chip  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed 0.177(4.50) 0.157(3.99) 0.012(0.305) 0.006(0.152) 250 °C/10 seconds at terminals 0.096(2.42) 0.078(1.98) 0.060(1.52) 0.030(0.76) Mechanical Data 0.008(0.203)MAX. 0.208(5.30) 0.188(4.80) Case : JEDEC DO-214AC/SMA Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.002 ounce, 0.07 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=110℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A VRRM VRMS VDC MDD FS2A MDD FS2B MDD FS2D MDD FS2G MDD FS2J MDD FS2K MDD FS2M UNITS 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V I(AV) 2.0 A IFSM 50.0 A IR 1.30 5 50 uA Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) CJ RJA 50.0 15.0 ℃/W Maximmum reverse recovery time(NOTE 3) Trr Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=100℃ VF Operating junction and storage temperature range TJ,TSTG 150 V pF 250 -65 to +150 500 ns ℃ Note: 1.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A DN:T20515A0 http://www.microdiode.com Rev:2020A0 Page :1 FS2A THRU FS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere Ratings And Characteristic Curves Figure 1 Typical Forward Characteristics 20 Figure 2 Forward Derating Curve 10 3.0 6 4 2.5 2 25°C Amps 2.0 1 .6 1.5 Amps .4 1.0 .2 .5 .1 Single Phase, Half Wave 60Hz Resistive or Inductive Load .06 0 .04 75 100 125 150 175 °C .02 .01 50 0 .4 .6 .8 1.0 1.2 Average Forward Rectified Current - Amperesversus Ambient Temperature -°C 1.4 Volts Instantaneous Forward Current - Amperesversus Instantaneous Forward Voltage - Volts Figure 3 Junction Capacitance 100 60 40 20 TJ=25°C 10 6 4 2 1 .1 .2 .4 1 Volts 2 4 10 20 40 100 200 400 1000 Junction Capacitance - pFversus Reverse Voltage - Volts The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2 FS2A THRU FS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere Ratings And Characteristic Curves Figure 4 Maximum Non-Repetitive Forward Surge Current 90 75 60 45 Amps 30 15 0 1 4 2 6 8 10 20 40 60 80 100 Cycles Peak Forward Surge Current - Amperesversus Number Of Cycles At 60Hz - Cycles Figure 5 Reverse Recovery Time Characteristic And Test Circuit Diagram 50Ω 10Ω trr +0.5A 0 Pulse Generator Note 2 25Vdc 1Ω Oscilloscope Note 1 Notes: 1. Rise Time = 7ns max. Input impedance = 1 megohm, 22pF 2. Rise Time = 10ns max. Source impedance = 50 ohms 3. Resistors are non-inductive -0.25 -1.0 1cm Set Time Base for 20/100ns/cm The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :3 FS2A THRU FS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SMA A B C d D D1 D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.80 5.33 2.36 1.50 330.00 50.00 178.00 62.00 13.00 1.75 5.50 4.00 4.00 2.00 0.28 12.00 18.00 E Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width F B A W P D2 D1 T C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMA REEL SIZE 7" APPROX. GROSS WEIGHT (kg) REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) 2,000 4.0 4,000 183*155*183 178 382*356*392 80,000 16.0 10,000 290*290*38 330 310*310*360 80,000 11.0 15,000 335*335*38 330 350*330*360 120,000 14.5 SMA 11" 5,000 4.0 SMA 13" 7,500 4.0 CARTON SIZE (m/m) CARTON (pcs) Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 1.68 0.066 B 1.52 0.060 C 3.90 0.154 D 2.41 0.095 E 5.45 0.215 Unit (inch) Rev:2020A0 Page :4
很抱歉,暂时无法提供与“FS2M”相匹配的价格&库存,您可以联系我们找货
