DSR0.3M
DSR0.3M
    MDD(辰达半导体)
    SMF(SOD-123FL)
    VR=1000V IF=300mA 4pF
DSR0.3M 数据手册
DSR0.3A THRU DSR0.3M Reverse Voltage - 50 to 1000 Volts Forward Current - 0.3 Ampere SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER Features SOD-123FL  Glass passivated device  Ideal for surface mouted applications  Low reverse leakage  Metallurgically bonded construction 0.075(1.90) 0.067(1.70) 0.031 (0.80) 0.043 (1.10) 0.114(2.90) 0.102(2.60)  High temperature soldering guaranteed:  250°C/10 seconds,0.375”(9.5mm) lead length, 5 0.051(1.30) 0.039(1.00) lbs. (2.3kg) tension 0.010(0.25) 0.004(0.10) 0.035(0.90) 0.028(0.70) 0.154(3.90) 0.141(3.60) Mechanical Data Case: JEDEC 6OD-123FL molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. DSR0.3A DSR0.3B DSR0.3D DSR0.3G DSR0.3J DSR0.3K DSR0.3M Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRRM VRMS VDC S03A S03B S03D S03G S03J S03K 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 S03M 1000 700 1000 UNITS V V V Maximum average forward rectified current at TL(see fig.1) I(AV) 0.3 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 15.0 A Maximum instantaneous forward voltage at 2.0A VF V Maximum DC reverse current at rated DCblocking voltage IR 1.1 5.0 50 uA TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range CJ RJA 4 pF 220 ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Note: 1.Averaged over any 20ms period. 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A1 Page :1 DSR0.3A THRU DSR0.3M Reverse Voltage - 50 to 1000 Volts Forward Current - 0.3 Ampere Typical Characterisitics Characteristic Curves (TA=25 ℃ unless otherwise noted) The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2 DSR0.3A THRU DSR0.3M Reverse Voltage - 50 to 1000 Volts Forward Current - 0.3 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 1.2 0.047 B 1.2 3.2 0.126 D 2 0.079 E 4.4 0.173 C http://www.microdiode.com 0.047 Rev:2024A1 Page :3
DSR0.3M 价格&库存
很抱歉,暂时无法提供与“DSR0.3M”相匹配的价格&库存,您可以联系我们找货
DSR0.3M
  • 20+0.13290
  • 100+0.08250
  • 800+0.05440
  • 3000+0.03890
  • 6000+0.03690
  • 30000+0.03420
库存:5851
