ES5DBF
ES5DBF
    MDD(辰达半导体)
ES5DBF 数据手册
ES5ABF THRU ES5JBF Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER Features SMBF  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Low reverse leakage  Built-in strain relief,ideal for automated  placement High forward surge current capability  High temperature soldering guaranteed: 0.146(3.70) 0.138(3.50) 0.086 (2.20) 0.075 (1.90) 0.173(4.40) 0.165(4.20)  250°C/10 seconds at terminals Glass passivated chip junction 0.051(1.30) 0.043(1.10) 0.010(0.26) 0.007(0.18) 0.048(1.20) 0.031(0.80) Mechanical Data 0.216(5.50) 0.200(5.10) Case : JEDEC SMBF Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.002 ounce, 0.075 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRMM VRMS VDC ES5ABF ES5BBF ES5DBF ES5GBF ES5JBF MDD E5AB MDD E5BB MDD E5DB MDD E5GB MDD E5JB 50 35 50 100 70 100 200 140 200 400 280 400 UNITS V V V 600 420 600 Maximum average forward rectified current at TL=55℃ I(AV) 5.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 150 A Maximum instantaneous forward voltage at 5.0A VF Maximum DC reverse current at rated DCblocking voltage Maximum reverse recovery time TA=25℃ TA=125℃ (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) IR 1 1.25 10.0 100.0 1.70 V μA trr 35 ns CJ 95.0 pF RJA 45.0 ℃/W -55 to +150 ℃ Operating junction and storage temperature range TJ,TSTG Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.5x0.5”(12.7x12.7mm) copper pad areas DN:T23301A2 http://www.microdiode.com Rev:2023A2 Page :1 ES5ABF THRU ES5JBF Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere Ratings And Characteristic Curves t rr 10 ohm Noninductive 50 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 300 6 5 I R - Reverse Current (μA) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 4 3 2 1 Single phase half-wave 60 Hz resistive or inductive load 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0 25 50 75 100 125 150 175 20 0 40 Case Temperature (°C) Junction Capacitance (pF) Instaneous Forward Current (A) T J =25°C 1.0 ES5ABF~ES5DBF ES5EBF/ES5GBF 0.1 80 100 Fig.5 Typical Junction Capacitance Fig.4 Typical Forward Characteristics 10 60 % of PIV.VOLTS ES5JBF 0.01 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.001 0 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surge Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surge Current 175 150 125 100 75 50 25 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2023A2 Page :2 ES5ABF THRU ES5JBF Reverse Voltage - 50 to 600 Volts Forward Current - 5.0 Ampere Packing information P0 unit:mm P1 d E F B A W P D2 T D1 C W1 D Item Symbol Tolerance SMBF Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 3.81 5.61 1.60 1 50 . 330.00 50.00 13.00 1.75 5.50 4.00 4.00 2.00 0.30 12.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) BOX (pcs) INNER BOX (mm) REEL DIA, (mm) SMBF 13" 5,000 4.0 10,000 190*190*41 330 CARTON SIZE (mm) 365*365*360 CARTON (pcs) 80,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 2.54 0.100 B 1.8 0.071 C 4.8 0.189 D 3.0 0.118 E 6.6 0.260 Unit (inch) Rev:2023A2 Page :3
ES5DBF 价格&库存
很抱歉,暂时无法提供与“ES5DBF”相匹配的价格&库存,您可以联系我们找货
