1N5333B-1N5388B
Zener Diode
POWER DISSIPATION: 5.0 W
DO-15
Features
Silicon planar power zener diodes
For use in stabilizing and clipping curcuits with high
power rating.
Standard zener voltage tolerance is ±10%. Add
suffix "B" for ±5% tolerance. other zener voltage
and tolerances are available upon request.
Mechanical Data
Case:DO-15
Polarity: cathode Band
Dimensions in inches and (millimeters)
Marking: type number
Approx. weight: 0.40grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25
ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
SYMBOL
VALUE
UNIT
DC pow er dissipation @ TL=75, measure at zero lead length (Fig.1)
derate above 75 (NOTE 1)
PD
5.0
40.0
W
mW
Peak forw ard surge current 8.3ms single half sine-w ave superimposed on rated
load (JEDEC Method)(NOTE 1,2)
IFSM
see fig.5
A
Junction temperature
TJ
-55---+150
Storage temperature range
Ts
-55---+150
Zener current (see Table "Characteristics")
NOTES: (1) Mounted on 8.0mm2 copper pads to each terminal.
(2) 8.3ms single half sine-wav e, or equiv alent square wav e, duty cy cle=4 pulses per minute maximum.
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
1N5333B-1N5388B
Zener Diode
Type
(Note 1)
(T A=25℃)
Maximum Zener
Impedance
(Note 2)
Zener voltage
(Note 2)
Max Reverse Leakage
Current
IR
VR
IZM
IR
VZ
(Note 3) (Note 4) (Note 5)
A
V
mA
VZ@IZT
V
IZT
mA
ZZT@IZT
Ω
ZZT@IZK =1µA
Ω
µA
V
1N5333B
3.3
380
3.0
400
300
1.0
1440
1N5334B
3.6
350
2.5
500
150
1.0
18.7
0.80
1320
1N5335B
3.9
320
2.0
500
50
1.0
17.6
0.54
1220
1N5336B
4.3
290
2.0
500
10
1.0
16.4
0.49
1100
1N5337B
4.7
260
2.0
450
5.0
1.0
15.3
0.44
1010
1N5338B
5.1
240
1.5
400
1.0
1.0
14.4
0.39
930
1N5339B
5.6
220
1.0
400
1.0
2.0
13.4
0.25
865
1N5340B
6.0
200
1.0
300
1.0
3.0
12.7
0.19
790
1N5341B
6.2
200
1.0
200
1.0
3.0
12.4
0.10
765
1N5342B
6.8
175
1.0
200
10
5.2
11.5
0.15
700
1N5343B
7.5
175
1.5
200
10
5.7
10.7
0.15
630
1N5344B
8.2
150
1.5
200
10
6.2
10.0
0.20
580
1N5345B
8.7
150
2.0
200
10
6.6
9.5
0.20
545
1N5346B
9.1
150
2.0
150
7.5
6.9
9.2
0.22
520
1N5347B
10
125
2.0
125
5.0
7.6
8.6
0.22
475
1N5348B
11
125
2.5
125
5.0
8.4
8.0
0.25
430
1N5349B
12
100
2.5
125
2.0
9.1
7.5
0.25
395
1N5350B
13
100
2.5
100
1.0
9.9
7.0
0.25
365
1N5351B
14
100
2.5
75
1.0
10.6
6.7
0.25
340
1N5352B
15
75
2.5
75
1.0
11.5
6.3
0.25
315
1N5353B
16
75
2.5
75
1.0
12.2
6.0
0.30
295
1N5354B
17
70
2.5
75
0.5
12.9
5.8
0.35
280
1N5355B
18
65
2.5
75
0.5
13.7
5.5
0.40
264
1N5356B
19
65
3.0
75
0.5
14.4
5.3
0.40
250
1N5357B
3.0
75
0.5
15.2
5.1
0.40
237
1N5358B
22
50
3.5
75
0.5
16.7
4.7
0.45
216
1N5359B
24
50
3.5
100
0.5
18.2
4.4
0.55
198
1N5360B
25
50
4.0
110
0.5
19.0
4.3
0.55
190
1N5361B
27
50
5.0
120
0.5
20.6
4.1
0.60
176
1N5362B
28
50
6.0
130
0.5
21.2
3.9
0.60
170
1N5363B
30
40
8.0
140
0.5
22.8
3.7
0.60
158
1N5364B
33
40
10
150
0.5
25.1
3.5
0.60
144
1N5365B
36
30
11
160
0.5
27.4
3.5
0.65
132
1N5366B
39
30
14
170
0.5
29.7
3.1
0.65
122
1N5367B
43
30
0.5
32.7
2.8
0.70
110
1N5368B
47
25
25
210
0.5
35.8
2.7
0.80
100
1N5369B
51
25
27
230
0.5
38.8
2.5
0.90
93
1N5370B
56
280
0.5
42.6
2.3
1.00
86
1N5371B
60
350
0.5
45.5
2.2
1.20
79
1N5372B
62
400
0.5
47.1
2.1
1.35
76
ht t p : //
www.lgesem i .c o m
1N5333B-1N5388B
Zener Diode
Type
(Note 1)
Zener voltage
(Note 2)
VZ@IZT
V
IZT
mA
(T A=25℃)
Maximum Zener
Impedance
(Note 2)
Max Reverse Leakage
Current
ZZT@IZT
Ω
ZZT@IZK =1µA
Ω
IR
VR
µA
V
IZM
IR
VZ
A
V
mA
1N5373B
68
500
0.5
51.7
2.0
1.5
70
1N5374B
75
620
0.5
56.0
1.9
1.6
63
1N5375B
82
15
65
720
0.5
62.2
1.8
1.8
58
1N5376B
87
15
75
760
0.5
66.0
1.7
2.0
54.5
1N5377B
91
15
75
760
0.5
69.2
1.6
2.2
52.5
1N5378B
100
12
90
800
0.5
76.0
1.5
2.5
47.5
1N5379B
110
12
125
1000
0.5
83.6
1.4
2.5
43.0
1N5380B
120
10
170
1150
0.5
91.2
1.3
2.5
39.5
1N5381B
130
10
190
1250
0.5
98.8
1.2
2.5
36.6
1N5382B
140
8.0
230
1500
0.5
106
1.2
2.5
34.0
1N5383B
150
8.0
330
1500
0.5
114
1.1
3.0
31.6
1N5384B
160
8.0
350
1650
0.5
122
1.1
3.0
29.4
1N5385B
170
8.0
380
1750
0.5
129
1.0
3.0
28.0
1N5386B
180
5.0
430
1750
0.5
137
1.0
4.0
26.4
1N5387B
190
5.0
450
1850
0.5
144
0.9
5.0
25.0
1N5388B
200
5.0
480
1850
0.5
152
0.9
5.0
23.6
NOTE:
1.TOLERANCE AND VOLTAGE DESIGNATION-The JEDEC type numbers shown indicate a tolerance of ±10% with guaranteed limits on only Vz, I R, Ir, and
VF as shown in the electrical characteristics table. Units with guaranteed limits on all seven parameters are indicated by suffix "B" for ±5% tolerance.
2.ZENER VOLTAGE (Vz) AND IMPEDANCE (ZZT & ZZK) - Test conditions for zener voltage and impedance are as follows;Iz is applied 40±10ms prior to
reading. Mounting contacts are located from the inside edge of mounting clips to the body of the diode.
3.SURGE CURRENT (Ir) - Surge current is specified as the maximum allowable peak, non-recurrent square-wave current with a pulse width, PW, of 8.3ms.
The data given in Fig 5. May be used to find the maximum surge current for a quare wave of any pulse width between 1 ms by plotting the applicable
points on logarithmic paper. Examples of this, using the 6.8v and 200v zeners, are shown in Fig 6. Mounting contact located as specified in NOTE 3.
4.VOLTAGE REGULATION (Vz) - Test conditions for voltage regulation are as follows: Vz measurements are the made at 10% and then at 50% of the Iz max
value listed in the electrical characteristics table. The test currents are the same for the 5% and 10% tolerance devices. The test current time druation for
each Vz measurement is 40±10ms.Mounting contact located as specified in NOTE 2.
5.MAXIMUM REGULATOR CURRENT (IZM) - The maximum current shown is based on the maximum voltage of a 5% type unit. Therefore, it applies only to
the B-suffix device. The actual IZM for any device may not exceed the value of 5 watts divided by the actual Vzof the device. TL=75℃ at 3/8" maximum from
the device body.
ht t p : //
www.lgesem i .c o m
1N5333B-1N5388B
Zener Diode
Ratings And Characteristic Curves
θVz TEMPERATURE COEFFICIENT
(mv)CJ @IZT
FIG.2 -- TEMPERATURE COEFFICIENT RANGE
8
L-LEAD LENGTH
TO HEAT SINK
6
AMPERES
AVERAGE FORWARD CURRENT
FIG.1 --FORWARD DERATING CURVE
4
2
60
80
100 120
140
160 180
200
300
200
RANGE
100
50
5
.6
100
120
140 160 180
200 220
240
.8
1
40
AMPERES
PEAK FORWARD SURGE CURRENT
/W)
30
.2
80
FIG.4 -- MAXIMUM NON-REPETITIVE SURGE CURRENT
40
Vz,ZENER VOLTACE @IZT(VOLTS)
FIG.3 -- TYPICAL THERMAL RESISTANCE
RESISTANCE
ΘJL.JUNCTION-TO-LEAD THERMAL RESISTA
AMBIENT TEMPERATURE,
40
10
4
2
1
.4
.2
.1
2
L/LEAD LENGTH TO HEAT SINK(INCH)
4
5
8
10
40
60
80
100
200
NUMBER OF CYCLES AT 60 Hz
/W
JUNCTION-TO-LEAD
ΘJl(1.D)TRANSIENT THERMAL RESISTANCE
FIG.5 -- TYPICAL THERMAL RESPONSE
D=0.5
5 D=0.2
D=0.1
2 D=0.05
1 D=0.01
.5
D=0
.2
.001
.005
.01
ht t p : //
.05
.1
.5
TIME SECONDS
1
5
www.lgesem i .c o m
10
1N5333B-1N5388B
Zener Diode
FIG.7 -- ZENER VOLTAGE VERSUS ZENER CURRENT
Vz=6.8 THRU 10 VOLTS
FIG.6 -- PEAK SURGE CURRENT VERSUS PULSE WIDTH
I r.PEAK SURGE CURRENT(AMPS)
30
Iz,ZENER CURRENT(mA)
VZ=6.8V
10
5
2
1
.5
.2
.1
VZ=200V
1
10
100
T=25℃
1000
Tc=25℃
100
10
1
.1
1
2
T=25℃
10
1
40
50
60
7
8
9
70
100
10
1
.1
80
100
120
140
160
180
200
220
80
Vz,ZENER VOLTAGE(VOLTS)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-15
3000/AMMO
30000
42X28X31
12.00
10.00
ht t p : //
10
1000
6
FIG.9 -- ZENER VOLTAGE VERSUS ZENER CURRENT
Vz=82 THRU 200 VOLTS
1000
10
5
FIG.8 -- ZENER VOLTAGE VERSUS ZENER CURRENT
Vz=11 THRU 75 VOLTS
.1
4
1000
PW,PULSE WIDTH(ms)
100
3
www.lgesem i .c o m
很抱歉,暂时无法提供与“1N5338B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.42409
- 50+1.13552
- 150+1.01196
- 1250+0.80039
- 2500+0.73170
- 5000+0.69045
