DSK12-DSK120
Surface Mount Schottky Rectifier
SOD-123FL
Features
Low profile package
Ideal for automated placement
Ultrafast reverse recovery time
Low power losses, high efficiency
Low forward voltage drop
High surge capability
High temperature soldering:
0.043(1.09)
0.035(0.89)
0.075(1.90)
0.067(1.70)
0.114(2.9)
0.098(2.5)
0.008(0.20)
0.004(0.10)
0.047(1.19)
0.043(1.09)
260℃/10 seconds at terminals
Component in accordance to
0.030(0.76)
0.018(0.45)
RoHS 2002/95/1 and WEEE 2002/96/EC
Mechanical Date
Case: JEDEC SOD-123FL molded plastic
0.154(3.9)
0.138(3.5)
body over passivated chip
Dimensions in inches and(millimeters)
Terminals: Solder plated, solderable per
J-STD-002B and JESD22-B102D
Polarity: Laser band denotes cathode end
Maximum Ratings & Thermal Characteristics & Electrical Characteristics
(TA = 25 °C unless otherwise noted)
SYMBOLS DSK12 DSK13 DSK14
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
DSK15 DSK16
DSK17 DSK18 DSK19 DSK110 DSK115 DSK120
40
50
60
70
80
90
100
150
200
14
21
28
35
42
49
56
63
70
105
140
40
50
60
70
80
90
100
150
I(AV)
1.0
IFSM
25.0
VF
0.55
CJ
0.85
0.70
5.0
10.0
80
110
TJ
TSTG
VOLTS
VOLTS
200 VOLTS
Amp
Amps
0.5
IR
-65 to +125
-65 to +150
-65 to +150
UNITS
Volts
0.2
2.0
mA
pF
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
DSK12-DSK120
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Characteristic Curves (TA=25 ℃ unless otherwise noted)
FIG. 1- FORWARD CURRENT DERATING CURVE
1
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
DSK12-DSK16
DSK17-DSK120
0.2
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
2
AMBIENT TEMPERATURE, C
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DSK12-DSK14
DSK15-DSK16
DSK17-DSK115
DSK120
0.1
0.01
0.2
0.4
0.6
0.8
1.0
100
10
NUMBER OF CYCLES AT 60 Hz
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
DSK12-DSK14
DSK15-DSK120
100
TJ=25 C
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123FL
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“DSK115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25224
- 200+0.20558
- 600+0.18225
- 3000+0.14746
- 9000+0.13346
- 21000+0.12636
