HER201-HER208
2.0 AMP. Glass Passivated High Efficient Rectifiers
DO-15
Features
Glass passivated chip junction.
High efficiency, Low VF
High current capability
High reliability
High surge current capability
For use in low voltage, high frequency inventor, free
wheeling, and polarity protection application.
Mechanical Data
Case: Molded plastic DO-15
Epoxy: UL 94V0 rate flame retardant
Polarity: Color band denotes cathode
High temperature soldering guaranteed:
o
260 C/10 seconds/.375”,(9.5mm) lead
lengths at 5 lbs., (2.3kg) tension
Mounting position: Any
Weight: 0.40 gram
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol HER HER HER HER HER HER HER HER Units
Type Number
201
V RRM
V RMS
V DC
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current .375 (9.5mm) Lead Length
@T A = 55 oC
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 2.0A
Maximum DC Reverse Current
o
@T A=25 C at Rated DC Blocking Voltage
o
@ T A=125 C
( Note 2 )
Typical Thermal Resistance
Operating Temperature Range
203
204
205
206
207
100
70
100
200
140
200
300
210
300
400
280
400
600
420
600
800 1000
560 700
800 1000
A
IFSM
60
A
1.0
1.3
Trr
Cj
R θJA
1.7
5.0
150
IR
TJ
ht t p : //
V
V
V
2.0
50
35
75
-65 to +150
-65 to +150
T STG
Storage Temperature Range
Notes:
1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1 MHz and Applied Reverse Voltage of 4.0 V D.C.
3. Mount on Cu-Pad Size 10mm x 10mm on P.C.B.
Revision:20170701-P1
208
202
I(AV)
VF
Maximum Reverse Recovery Time ( Note 1 )
Typical Junction Capacitance
50
35
50
www.lgesemi .c o m
V
uA
uA
nS
pF
o
C/W
o
C
o
C
mail:lge@lgesemi.com
HER201-HER208
RATINGS AND CHARACTERISTIC CURVES (HER201 THRU HER208)
1000
Single Phase
Half Wave 60Hz
Resistive or
Inductive Load
0.375" (9.5mm)
Lead Length
2.0
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
3.0
1.0
25
75
100
125
150
175
O
AMBIENT TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT
100
Tj=125 0C
Tj=75 0C
10
1
Tj=25 0C
0.1
60
50
60
80
100
120
140
40
30
FIG.5- TYPICAL FORWARD CHARACTERISTICS
10
2
5
10
100
NUMBER OF CYCLES AT 60Hz
175
JUNCTION CAPACITANCE.(pF)
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
8.3ms Single Half Sine Wave
JEDEC Method
INSTANTANEOUS FORWARD CURRENT. (A)
PEAK FORWARD SURGE CURRENT. (A)
70
FIG.4- TYPICAL JUNCTION CAPACITANCE
150
Tj=25 0C
125
100
HE
R2
75
HE
50
R2
01
06G
G~
~H
HE
ER
R2
05
208
G
Tj=25 0C
10
1
HER205G
HER201G-HER204G
0.1
HER206G-HER208G
G
25
0.5
1
2
5
10
0.01
500 800
100 200
0.4
REVERSE VOLTAGE. (V)
0.6
0.8
1.0
1.2
1.4
FORWARD VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50
NONINDUCTIVE
10
NONINDUCTIVE
trr
+0.5A
50Vdc
(approx)
DUT
PULSE
GENERATOR
(NOTE 2)
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
-1.0A
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
1cm
SET TIME BASE FOR
5/ 10ns/ cm
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-15
3000/AMMO
30000
42X28X31
12.00
10.00
ht t p : //
-0.25A
www.lgesemi .c o m
很抱歉,暂时无法提供与“HER208”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20218
- 200+0.15704
- 600+0.13198
- 3000+0.10941
- 9000+0.09645
- 21000+0.08943
