15SQ045
15SQ045
    LGE(鲁光)
    R-6
    肖特基二极管 电压:45V 电流:15A R-6
15SQ045 数据手册
15SQ030-15SQ100 15A Schottky Barrier Diode R-6 Features ! ! ! ! ! Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability Mechanical Data ! ! ! ! ! ! ! Case: P-600, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 2.1 grams (approx.) Mounting Position: Any Marking: Type Number Lead Free: For RoHS / Lead Free Version, Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or inductive load. For capacitive load, derate current by 20% CHARACTERISTICS SYMBOL 15SQ030 15SQ035 15SQ040 15SQ045 15SQ050 15SQ060 15SQ080 15SQ100 UNIT Maximum Recurrent Peak Reverse Voltage VRRM 30 35 40 45 50 60 80 100 V Maximum RMS Voltage VRMS 21 24.5 28 31.5 35 42 56 70 V Maximum DC Blocking Voltage VDC 30 35 40 45 50 60 80 100 V Maximum Average Forward Rectified Current@Tc=95 ℃ I(AV) 15 A Peak Forward Surage Current 8.3ms single half sine-wave super imposed on rated load(JEDEC Method) IFSM 275 A Peak Forward Voltage at 10A DC(Note1) Maximum DC Reverse Current @Tj=25℃ at Rated DC Bolcking Voltage @Tj=100℃ Tyical Junction Capacitance (Note2) Tyical Thermal Resistance (Note3) Operating Temperature Range Storage Temperature Range 0.55 VF 0.7 0.5 IR 50 0.8 V mA 450 PF 3.0 ℃/w TJ -55 to+200 ℃ TSTG -55 to+200 ℃ CJ R J NOTES:1.300us Pulse Width, 2%Dudy Cycle. 2.Measured at 1.0 MHZ and applied reverse voltage of 4.0VDC. 3.Thermal Resistance Junction to Case. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com 15SQ030-15SQ100 PEAK FORWARD SURGE CURRENT AMPERES 15A Schottky Barrier Diode AVERAGE FORWARD CURRENT AMPERES FIG.1-FORWARD CURRENT DERATING CURVE 18 15 12 9 6 3 0 20 50 75 100 125 150 175 FIG.2-MAXIMUM NON-REPETITVE SURGE 360 300 240 180 120 8.3Single Half-Sine-Wave (JEDEC METOD) 60 0 1 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz CASE TEMPERATURE ℃ FIG.4-TYPICAL FORWARD CHARACTERISTICS FIG.3-TYPICAL REVERSE CHARACTERISTICS 15SQ030 to 15SQ045 INSTANTANEOUS FORWARD CURRENT(A) INSTANTANEOUS REVERSE CURRENT(mA) 100 100 10 TJ=100℃ 1 TJ=50℃ 0.1 TJ=25℃ 0.01 10 15SQ050 to15SQ060 15SQ080 to15SQ100 1 TJ=25℃ PULSE WIDTH 300US 2%DUTY CYCLE 0.1 0 20 50 75 100 125 150 175 0.2 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE(%) 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.2 INSTANTANEOUS FORWARD VOLTAGE FIG.5-TYPICAL JUNCTION CAPACITANCE CAPACITANCE,(pF) 1000 100 TJ=25℃ ,f=1MHZ 10 0.1 1 4 10 100 REVERSE VOLTAGE VOLTS PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG R-6 500/AMMO 5000 44X28X31 12.00 10.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
15SQ045 价格&库存
很抱歉,暂时无法提供与“15SQ045”相匹配的价格&库存,您可以联系我们找货
15SQ045
  • 1+3.19680
  • 10+2.57040
  • 30+2.30040
  • 100+1.96560
  • 500+1.68480
  • 1000+1.58760
库存:2779
15SQ045
  • 1+4.96100
  • 50+3.96000
  • 500+3.67400
库存:1
