2W10M
2W10M
    LGE(鲁光)
    DIP-4
    耐压:1000V 电流:2A
2W10M 数据手册
2W005M-2W10M WOM FEATURES B  Rating to 1000V PRVP I  Surge overload rating to 40 Amperes peak A B RB15 .150(3.8) .130(3.3) .360(9.1) .340(8.6) WO .305(7.75) .265(6.73) .395(10.0) .355(9.0) .220(6.73) .340(8.6) .180(4.6) .300(7.6) WOM A  Glass passivated chip junctions MIN 1.27(32.3)  Reliable low cost construction utilizing molded plastic technique results in inexpensive product MIN 1.20(30.5) POS. LEAD .032(.81) .028(.71) DIA .220 .180  Lead solderable per MIL-STD-202 method 208  Lead: silver plated copper, solderde plated  Plastic material has UL flammability classification94V-O .220 .180 (5.6) (4.6) (5.6) (4.6) inch(mm) Maximum Ratings (@TA = 25°C unless otherwise specified) Symbol W0050 Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Characteristic Maximum average forward Output current @TA=40℃ Peak forward surge current :0:0:0 :0 :0:0 UNITS IF(AV) 2.0 IFSM 60 A 15 As A 8.3ms single half-sine-wave superimposed on rated load Current squared time t < 8.3ms , Ta = 25℃ 2 It 2 Thermal Characteristics Characteristic Symbol 2W005M 2W01M 2W02M 2W04M 2W06M 2W08M 2W10M UNITS Typical thermal resistance junction to lead R θ JA 40 On aluminum substrate R ΘJL 15 Operating junction temperature range TJ -55 -150 ℃ TSTG -55 -150 ℃ Storage temperature range ℃/W Electrical Characteristics (@TA = 25°C unless otherwise specified) Characteristic Maximum instantaneous forward voltage at 2.0A Maximum reverse current @TA=25℃ at rated DC blocking voltage @TA=100℃ Revision:20170701-P1 Symbol 2W005M VF IR ht t p : // 2W01M 2W02M 2W04M 2W06M 2W08M 2W10M UNITS 1.1 V 10 μA 1.0 mA www.lgesemi .c o m mail:lge@lgesemi.com 2W005M-2W10M Fig. 1 - Forward Current Derating Curve Fig. 2 - Maximum Non-Repetitive Surge Current 2.4 Peak Forward Surge Current (A) Average Forward Current (A) 70 2 1.6 1.2 0.8 0.4 0 0 30 60 90 120 8.3mS Single Half-Sine-Wave (JEDEC METOD) 60 50 40 30 20 10 0 150 10 1 Ambient Temperature (℃) Fig. 4 - Typical Forward Characteristics Fig. 3 - Typical Reverse Characteristics 5 1000 Pulse Width 300uS 2%Duty Cycle TJ=125°C TJ=100°C 1 TJ=75°C 10 TJ=25°C 1 0.1 20 40 60 80 100 TJ=100°C 瞬时正向电流 (A) 100 Instantaneous Forward Current (A) Instantaneous Reverse Current (uA) 100 Number of Cycles at 60Hz TJ=25°C TJ=125°C TJ=75°C 0.1 0.4 0.6 Percent of Rated Peak Reverse Voltage (%) 0.8 1 1.2 1.4 Instantaneous Forward Voltage (V) Fig. 5 - Typical Junction Capacitance Capacitance (pF) 100 10 TJ=25°C,f=1MHz 1 0.1 1 10 100 Reverse Voltage (V) Revision:20170701-P1 Device Shipping 2W005M-2W10M 50unit/pipe ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com
