GBU10A-GBU10M
Silicon Bridge Rectifiers
GBU
FEATURES
Dim
A
Min
22.00
Max
22.40
18.80
B
18.40
C
3.40
3.95
2.50
0.40
3.00
0.60
Ideal for printed circuit board
C1
E
F
Reliable low cost construction utilizing molded plastic technique
F1
1.70
2.30
I1
2.30
2.60
Plastic materrial has U/L flammability classification 94V-O
I2
0.95
1.25
K
4.70
Mounting position: Any
P
Glass passivated chip junctions
17.00min
5.30
R1.9ypical
All Dimensions in mm
Maximum Ratings (@TA = 25°C unless otherwise specified)
Characteristic
Symbol
GBU10A
GBU10B
GBU10D
GBU10G
GBU10J
GBU10K
GBU10M
UNITS
Maximum recurrent peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forward Output current
IF(AV)
10.0
A
IFSM
220
A
I²t
9200
A²S
@TC=100℃
Peak forward surge current
8.3ms single half-sine-wave
superimposed on rated load
I²t Rating for fusing @Tj=25℃
Thermal Characteristics
Characteristic
Symbol
Typical junction capacitance per leg (note 3)
GBU10A
CJ
GBU10B
GBU10D
GBU10G
GBU10J
211
GBU10K
GBU10M
94
UNITS
pF
Typical thermal resistance per leg (note 2)
RθJA
22
(note 1)
RθJC
2.0
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
Operating junction temperature range
Storage temperature range
℃/W
Electrical Characteristics (@TA = 25°C unless otherwise specified)
Characteristic
Symbol
GBU10A
GBU10B
GBU10D
GBU10G
GBU10J
GBU10K
GBU10M
UNITS
Maximum instantaneous forward voltage
VF
@5.0A
1.0
@10A
1.1
Maximum
reverse
current
@TA=25 ℃
V
5.0
μA
IR
500
at rated DC blocking voltage @TA=125℃
NOTE: 1. Unit case mounted on 3.2x3.2x0.12" thick (6.2x8.2x0.3cm) AI. Plate
2. Units mounted in free air, no heat sink on P.C.B., 0.5x0.5"(12x12mm) copper pads, 0.375"(9.5mm) lead length.
3. Measured at 1.0 MHz and applied reverse voltage of 4.0 volts.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
GBU10A-GBU10M
CHARACTERISTICS CURVES
(TA = 25°C unless otherwise noted)
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
GBU10A - GBU10G
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
15
10
5
100
GBU10J - GBU10M
RESISTER OR
INDUCTIVE LOAD
WITH HEATSINK
f=1.0MHz
Vsig=50mVp-p
60
90
120
CASE TEMPERATURE
10
150
0.1
10
TJ=25°C
0.1
60
80
100
120
140
10
100
UF1DLW
1
TJ=125°C
10
0.1
0.01
1
Pulse width
0.001
0.3
0.4
0.5
ht t p : //
0.6
0.7
0.8
0.9
1
1.1
1
1.1
1.2
0.1
0.6
0.7
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
TJ=25°C
(A)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
TJ=125°C
Fig.4 Typical Forward Characteristics
1000
1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
1
(°C)
www.lgesem i .c o m
0.8
0.9
1.2
1.3
FORWARD VOLTAGE (V)
GBU10A-GBU10M
PEAK FORWARD SURGE CURRENT (A)
Fig.5 Maximum Non-repetitive Forward Surge Current
225
200
8.3ms Single Half Sine Wave
175
150
125
100
75
50
25
100
10
NUMBER OF CYCLES AT 60 Hz
Device
Package
Shipping
GBU10A-GBU10M
GBU
500 Units/Box
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“GBU10M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.19177
- 50+1.75048
- 150+1.56133
- 500+1.18740
- 2500+1.08233
- 5000+1.01924
