BZX84B33
BZX84B33
    LGE(鲁光)
    SOT-23
BZX84B33 数据手册
BZX84B2V4-BZX84B51 Surface Mount Zener Diodes B:2% tolerance SOT-23 Features — Planar Die Construction. — 350mw Power Dissipation. — Zener Voltages From 2.4V -51V — Ideally Suited For Automated Assembly Prcesses. Applications — Dimensions in inches and (millimeters) 350Mw Surface mount zener diode Ordering Information Type No. BZX84B2V4-BZX84B51 Marking Package Code See Table on page2 SOT-23 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Characteristic Symbol Value Unit Power Dissipation Pd 350 mW Thermal Resistance, Junction to Ambient Air RθjA 357 ℃/W Operating and Storage Temperature Range Tj,Tstg -65 to+150 ℃ ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com BZX84B2V4-BZX84B51 Surface Mount Zener Diodes ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Maximum Zener Zerner Voltage Range Reverse Impedance Marking Maximum Current Type Number Code VZ@IZT IZT ZZT@IZT ZZK@IZK IR VR Nom(V) Min(V) Max(V) (mA) (Ω) (Ω) (mA) (μA) (V) BZX84B2V4 Z50 2.4 2.35 2.45 5 100 275 1 50 1 BZX84B2V7 Z51 2.7 2.65 2.75 5 100 600 1 20 1 BZX84B3V0 Z52 3.0 2.94 3.06 5 95 600 1 10 1 BZX84B3V3 Z53 3.3 3.23 3.37 5 95 600 1 5 1 BZX84B3V6 Z54 3.6 3.53 3.67 5 90 600 1 5 1 BZX84B3V9 Z55 3.9 3.82 3.98 5 90 600 1 3 1 BZX84B4V3 Z56 4.3 4.21 4.39 5 90 600 1 3 1 BZX84B4V7 Z57 4.7 4.61 4.79 5 80 500 1 3 2 BZX84B5V1 Z58 5.1 5 5.2 5 60 480 1 2 2 BZX84B5V6 Z59 5.6 5.49 5.71 5 40 400 1 1 2 BZX84B6V2 Z60 6.2 6.08 6.32 5 10 150 1 3 4 BZX84B6V8 Z61 6.8 6.66 6.94 5 15 80 1 2 4 BZX84B7V5 Z62 7.5 7.35 7.65 5 15 80 1 1 5 BZX84B8V2 Z63 8.2 8.04 8.36 5 15 80 1 0.7 5 BZX84B9V1 Z64 9.1 8.92 9.28 5 15 100 1 0.5 6 BZX84B10 Z65 10 9.8 10.2 5 20 150 1 0.2 7 BZX84B11 Z66 11 10.8 11.2 5 20 150 1 0.1 8 BZX84B12 Z67 12 11.8 12.2 5 25 150 1 0.1 8 BZX84B13 Z68 13 12.7 13.3 5 30 170 1 0.1 8 BZX84B15 Z69 15 14.7 15.3 5 30 200 1 0.05 10.5 BZX84B16 Z70 16 15.7 16.3 5 40 200 1 0.05 11.2 BZX84B18 Z71 18 17.6 18.4 5 45 225 1 0.05 12.6 BZX84B20 Z72 20 19.6 20.4 5 55 225 1 0.05 14 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com BZX84B2V4-BZX84B51 Surface Mount Zener Diodes Maximum Zener Zerner Voltage Range Reverse Impedance Marking Maximum Current Type Number Code VZ@IZT IZT ZZT@IZT ZZK@IZK IR VR Nom(V) Min(V) Max(V) (mA) (Ω) (Ω) (mA) (μA) (V) BZX84B22 Z73 22 21.6 22.4 5 55 250 1 0.05 15.4 BZX84B24 Z74 24 23.5 24.5 5 70 250 1 0.05 16.8 BZX84B27 Z75 27 26.5 27.5 2 80 300 0.5 0.05 18.9 BZX84B30 Z76 30 29.4 30.6 2 80 300 0.5 0.05 21 BZX84B33 Z77 33 32.3 33.7 2 80 325 0.5 0.05 23.1 BZX84B36 Z78 36 35.3 36.7 2 90 350 0.5 0.05 25.2 BZX84B39 Z79 39 38.2 39.8 2 130 350 0.5 0.05 27.3 BZX84B43 Z80 43 42.1 43.9 2 150 375 0.5 0.05 30.1 BZX84B47 Z81 47 46.1 47.9 2 170 375 0.5 0.05 32.9 BZX84B51 Z82 51 50 52 2 180 400 0.5 0.05 35.7 TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com BZX84B2V4-BZX84B51 Surface Mount Zener Diodes PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOT- 23 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
BZX84B33 价格&库存
很抱歉,暂时无法提供与“BZX84B33”相匹配的价格&库存,您可以联系我们找货
BZX84B33
库存:2754
