EHEA 1PR
EHEA 1PR
    NEXANS
    NEXANS - EHEA 1PR - Multicore Cable, Per M, Screened, 1 Core, 24 AWG, 0.22 mm², 328 ft, 100 m
EHEA 1PR 数据手册
EHE & EHEA Applications These flexible cables are mainly designed for use in applications requiring high efficiency screening at low frequencies. The screen is made up of a continuous high conductive thermoplastic sheath and provides a shielding efficiency inversely proportional to the frequency. So a very high efficiency is obtained at industrial frequencies. For a reduced overall diameter, use EHEA range. Easy stripping, as well as grounding, because of the drain wire placed under the thermoplastic sheath. 250 Volts and 750 Volts according to the products Construction 1 1 - CONDUCTOR Stranded tinned copper wires 2 - INSULATION Polyethylene (Pe) 3- DRAIN WIRE 4- SCREEN High conductive sheath 5- OUTER JACKET Flexible polyvinyl chloride (PVC) 2 3 4 5 Standards NEXANS specification - 20°C to +80°C Flame retardant (NF C 32-070/C2) Flexible 35 Single core and multicore cables Screened and jacketed hook-up wires and multicore cables for low frequency Cross section mm² Construction n x Ø mm Nominal Ø core mm Mini. Maxi. Colour coding of cores Gauge AWG Conductor Operating voltage Overall Ø mm Base Core Average weight Kg / Km EHE & EHEA - Screened and jacketed hook-up wires and multicore cables EHEA 1 PR 24 0.22 7 x 0.20 1.1 2.4 2.8 8 250 V Natural EHEA 1 P 22 0.34 7 x 0.25 2.0 3.4 3.8 14 750 V Natural EHE 2 PR 24 0.22 7 x 0.20 1.2 3.8 4.2 12 250 V Natural, Blue EHEA 2 PR 24 0.22 7 x 0.20 1.1 3.5 3.9 14 250 V Natural, Blue EHE 2 P 22 0.38 12 x 0.20 2.0 5.5 6.1 22 750 V Natural, Blue EHEA 2 P 22 0.34 7 x 0.25 2.0 5.5 6.1 22 750 V Natural, Blue EHE 3 PR 24 0.22 7 x 0.20 1.2 4.0 4.4 14 250 V Natural, Blue, Red EHEA 3 PR 24 0.22 7 x 0.20 1.1 3.8 4.2 13 250 V Natural, Blue, Red EHE 3 P 22 0.38 12 x 0.20 2.0 6.4 7.0 31 750 V Natural, Blue, Red EHE 4 PR 24 0.22 7 x 0.20 1.2 4.6 5.0 16 250 V Natural, Blue, Red, Yellow EHEA 4 PR 24 0.22 7 x 0.20 1.1 4.2 4.6 14 250 V Natural, Blue, Red, Yellow 5 EHEA 5 PR 24 0.22 7 x 0.20 1.1 4.6 5.0 15 250 V Natural, Blue, Red, Yellow, Green 6 EHEA 6 PR 24 0.22 7x 0.20 1.1 4.9 5.3 16 250 V Nb. of cores. 1 2 3 Natural, Blue, Red, Yellow, Green, Black November 2007 - Copyright Nexans 4 Nexans Reference 36
EHEA 1PR
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特性,适用于高速光耦应用。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:EL817的主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于通信设备、工业控制系统、仪器仪表等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.9mm。
EHEA 1PR 价格&库存
很抱歉,暂时无法提供与“EHEA 1PR”相匹配的价格&库存,您可以联系我们找货
