157284
157284
    NEXANS
157284 数据手册
Communication Data Cables Filotexâ PRODUCT REFERENCES Passing on or copying of the document, use or communicate of its content is not permitted without prior written authorization. FILOTEX ref. : ET 087 059 CONSTITUTION  Conductor : 1 x 0.17 mm solid silver plated copper covered steel ‚ Insulation : Extruded PTFE Æ = 0.52 ± 0.05 mm ƒ Shield : 0.05 mm silver plated copper braid „ Jacket : FEP Æ = 1.17 ± 0.05 mm 140 - 146 rue E. Delacroix B.P. 1 91211 DRAVEIL CEDEX - FRANCE Tél : +33(0)169 83 78 00 - Fax :+33(0)169 42 05 70 50 VMTX Miniature PTFE coaxial cable Main applications ■ High frequency interconnections or PCB in telecommunication equiments Electrical characteristics ■ Voltage rating:250 Volts (RMS) ■ Operating temperature: - 90°C to + 200°C ■ Operating frequency: up to 3 GHz ■ Impedance: 50 ± 5 W ■ Capacitance: 85 pF/m ■ Relative propagation velocity: 69.5 % ■ Attenuation at 0.5 GHz 1.5 dB/m 1.0 GHz 2.3 dB/m 1.5 GHZ 2.9 dB/m 2.0 GHz 3.4 dB/m 3.0 GHZ 4.3 dB/m Physical characteristics ■ Very good resistance to solvents ■ Very good resistance to soldering operations ■ Nominal weight : 3 g/m Issue 2 - February 1999 -1-
157284 价格&库存
很抱歉,暂时无法提供与“157284”相匹配的价格&库存,您可以联系我们找货
