75 VMTX
75 VMTX
    NEXANS
    NEXANS - 75 VMTX - Coaxial Cable, 75 ohm, 328 ft, 100 m
75 VMTX 数据手册
Contact Nexans - Electronic cables Phone: + 33 1 69 83 78 60 electronic.products@nexans.com Miniature coaxial cables 75 VMTX 75 VMTX Nexans ref.: 10035806 EAN 13: 3427570022381 75 VMTX - Câble coaxial miniature 75 ohms Description Very good resistance to solvents Very good resistance to soldering operations Attenuation at • 10 MHz: 36 dB/100m • 100 MHz: 70 dB/100m • 400MHz: 135 dB/100m • 1000 MHz: 220 dB/100m • 2000 MHz: 320 dB/100m Standards • 3000 MHz: 390 dB/100m International Nexans specification Operating temp. range -90 .. 200 °C Generated 5/3/13 - http://www.nexans.fr Page 1 / 2 All drawings, designs, specifications, plans and particulars of weights, size and dimensions contained in the technical or commercial documentation of Nexans is indicative only and shall not be binding on Nexans or be treated as constituting a representation on the part of Nexans. Contact Nexans - Electronic cables Phone: + 33 1 69 83 78 60 electronic.products@nexans.com Miniature coaxial cables 75 VMTX Nexans ref.: 10035806 Characteristics Construction characteristics Conductor material Silvered copper-clad steel Type of conductor Circular, solid Insulation PTFE Screen Silver plated copper braid Outer sheath FEP Dimensional characteristics Number of cores 1 Conductor diameter 0.1 mm Diameter over insulation 0.57 mm Number of screen braids 1 Nominal outer diameter 1.22 mm Wire diameter 0.1 mm Number of wires per strand 1 Approximate weight 3 kg/km Electrical characteristics Impedance at 200 MHz 75 Ohm Operating voltage 250 V Nominal capacitance core to core 60.0 pF/m Relative propagation velocity 69.5 % Usage characteristics Operating temperature, range -90 .. 200 °C Length 250 m Packaging Reel Selling information In addition to the standard products you will find within these pages, our development and studies engineers are at your disposal to provide their experience in tailoring any of our products to meet your precise requirements. Operating temp. range -90 .. 200 °C Generated 5/3/13 - http://www.nexans.fr Page 2 / 2 All drawings, designs, specifications, plans and particulars of weights, size and dimensions contained in the technical or commercial documentation of Nexans is indicative only and shall not be binding on Nexans or be treated as constituting a representation on the part of Nexans.
75 VMTX 价格&库存
很抱歉,暂时无法提供与“75 VMTX”相匹配的价格&库存,您可以联系我们找货
