1.302550
1.302550
    SKROSS
    SKROSS - 1.302550 - Mains Adapter, PRO Light, Australia/China, Europe (Schuko), UK, USA
1.302550 数据手册
World Adapter PRO Light USB – World more compact: the smallest 3–pole world travel adapter with an integrated usb charger The PRO Light USB – World ensures a simple and safe connection of 2- and 3-pole devices from and to more than 200 countries (thanks to the included World to Europe top). The available power of up to 1575 W makes it unique in its application even with powerful devices like laptops or hairdryers. Wherever the traveller comes from, the World Adapter PRO Light USB – World provides the safest solution of plugging in devices around the world. Furthermore the dual USB port provides sufficient energy to charge two USB devices easily, even if another device is connected via the adapter at the same time. Compatibility Input Specifications Designed in Switzerland Suitable for equipment with 2- & 3-pole plugs ■ Adapter input for: Switzerland, Italy, Brazil, USA/Japan, UK, Australia/China, Europe (Schuko & 2-pole Euro) ■ Retractable plugs (3-pole): USA, UK, Australia/China, Europe (Schuko) ■ Input voltage: 100 V – 250 V ■ Max. load: 6.3 A ■ Power rating: e.g. 100 V – 630 W / 250 V – 1575 W ■ Integrated fuse: T6.3 A ■ USB output: 5 V / 2400 mA shared ■ Does not convert voltage ■ ■ Switzerland Italy Brazil USA, Japan UK Australia, China Euro Output USA UK Australia, China Europe (Schuko) Europe (Schuko) Weight Adapter incl. top: 167 g Retail packaging: 231 g Max. 6.3 A - 1575 W - 250 V AC Dimensions Adapter incl. top: L 70 mm W 58 mm H 67 mm Retail packaging: L 150 mm W 150 mm H 75 mm Packaging Unit Master retail: 20 Dimensions master retail: L 345 mm W 410 mm H 385 mm Pallet retail: 1000 pcs Standard colour: white Description Article-No. EAN-Code PRO Light USB – World, retail, white 1.302550 7640166320784 Made in Thailand WorldConnect AG · Werkstrasse 12a, 9444 Diepoldsau, Switzerland T +41 (0)71 7379760 · F +41 (0)71 7379770 · info@skross.com · www.skross.com
1.302550 价格&库存
很抱歉,暂时无法提供与“1.302550”相匹配的价格&库存,您可以联系我们找货
