CM200-NIST
CM200-NIST
    TRIPLETT
    200A AC TRUE RMS OPEN JAW CLAMP
CM200-NIST 数据手册
CM200 200A AC True RMS Open Jaw Clamp Open jaw design fits into tight spaces where a standard clamp can’t close Features: • True RMS provides better accuracy when measuring non-sinusoidal or noisy waveforms • 0.6” (16mm) clamp jaw • Built-in Non-Contact Voltage Detector with LED • LoZ (impedance) mode for identifying ghost voltages • Data Hold freezes the display • Auto power off with disable • Built-in Flashlight • Includes Test Leads, 2 AA batteries • 1-year warranty Applications: • The open jaw clamp has a smaller profile and can fit into spaces that a standard clamp meter jaw can’t • Typically when using a multimeter to measure current, you would have to “break the circuit” and place the meter in series with it, so that voltage and current would pass through it. A clamp meter allows you to easily measure current without breaking the circuit by clamping around a single conductor. This saves time and the circuit will not be damaged. Specifications 6000 count Display counts 200A AC Current ACA Accuracy ±3% AC Voltage 1000V Resistance 60MΩ Capacitance 4mF Continuity
CM200-NIST 价格&库存
很抱歉,暂时无法提供与“CM200-NIST”相匹配的价格&库存,您可以联系我们找货
