CM1050-NIST
CM1050-NIST
    TRIPLETT
    1000A AC/DC TRUE RMS CLAMP METER
CM1050-NIST 数据手册
CM1000 & CM1050 1000A AC & AC/DC True RMS Clamp Meters True RMS Clamp Meter with Inrush current, Low Pass Filter and LoZ Features: • Captures the instantaneous surge (inrush) current when power equipment is turned on • 1.4” (35mm) clamp jaw • Low Pass Filter (LPF) for filtering frequency and harmonic interference when measuring variable frequency drives • LoZ mode for identifying ghost voltages • Peak voltage measurement with Min/Max • Built-in Non-Contact Voltage Detector with LED • Data Hold freezes the display • Relative Mode for making comparisons to a stored reference value • Auto power off with disable • Built-in flashlight • Includes test leads, Type K thermocouple bead probe, 3 AAA batteries, and carrying case • 1-year warranty Model CM1000: • Measures 1000A True RMS AC Current Model CM1050: • Measures 1000A True RMS AC and DC Current • DC Zero function True RMS Display counts Typically when using a multimeter to measure current, you would have to “break the circuit” and place the meter in series with it, so that voltage and current would pass through it. A clamp meter allows you to easily measure current without breaking the circuit by clamping around a single conductor. This saves time and the circuit will not be damaged. 6000 count 1000A 1000A ACA Accuracy ±2.8% ±2.8% — 1000A AC/DC Voltage 1000V 1000V Resistance 60MΩ 60MΩ Temperature -4 to 1832°F (-20 to 1000°C) -4 to 1832°F (-20 to 1000°C) Capacitance 100mF 100mF Frequency 100kHz 100kHz Duty Cycle 10.0 to 90.0% 10.0 to 90.0% Continuity 90V Inrush Current 100ms 100ms Safety Category CAT IV-600V CAT IV-600V Dimensions Weight 1000A AC True RMS Clamp Meter CM1000 with Certificate of Traceability to NIST 1000A AC/DC True RMS Clamp Meter CM1050 with Certificate of Traceability to NIST 9.9 x 3.2 x 1.7” (249 x 81.5 x 42.2mm) 9.9 x 3.2 x 1.7” (249 x 81.5 x 42.2mm) 11.3oz (320g) 11.5oz (327g) CAT IV 600V 850 Perimeter Road • Manchester, NH • (603) 669-6400 • info@triplett.com
CM1050-NIST 价格&库存
很抱歉,暂时无法提供与“CM1050-NIST”相匹配的价格&库存,您可以联系我们找货
