CM650-NIST
CM650-NIST
    TRIPLETT
    600A AC/DC TRUE RMS CLAMP METER
CM650-NIST 数据手册
CM600 & CM650 600A AC and AC/DC True RMS Clamp Meters True RMS Clamp Meter with Inrush current and Low Pass Filter Features: • Captures the instantaneous surge (inrush) current when power equipment is turned on • 1.3” (33mm) clamp jaw • Low Pass Filter (LPF) for filtering frequency and harmonic interference when measuring variable frequency drives • Peak voltage measurement with Min/Max • Built-in Non-Contact Voltage Detector with LED • Data Hold freezes the display • Relative Mode for making comparisons to a stored reference value • Auto power off with disable • Built-in flashlight • Includes test leads, Type K thermocouple bead probe, 3 AAA batteries, and carrying case • 1-year warranty Model CM600: • Measures 600A True RMS AC Current Model CM650: • Measures 600A True RMS AC and DC Current • DC Zero function CM600 CM650 √ √ 6000 count 6000 count 600A 600A ±2.5% ±2.5% — 600A AC/DC Voltage 1000V 1000V Resistance 60MΩ 60MΩ Temperature -4 to 1832°F (-20 to 1000°C) -4 to 1832°F (-20 to 1000°C) Capacitance 100mF 100mF True RMS Display counts Applications: AC Current Typically when using a multimeter to measure current, you would have to “break the circuit” and place the meter in series with it, so that voltage and current would pass through it. A clamp meter allows you to easily measure current without breaking the circuit by clamping around a single conductor. This saves time and the circuit will not be damaged. ACA Accuracy DC Current Frequency 100kHz 100kHz Duty Cycle 20.0 to 80.0% 20.0 to 80.0% Continuity 90V Inrush Current 100ms 100ms Safety Category Ordering Information: CM600 CM600-NIST CM650 CM650-NIST Dimensions Weight 600A AC True RMS Clamp Meter CM600 with Certificate of Traceability to NIST 600A AC/DC True RMS Clamp Meter CM650 with Certificate of Traceability to NIST CAT III-600V CAT III-600V 9.4 x 3 x 1.5” (239 x 76.5 x 38mm) 9.4 x 3 x 1.5” (239 x 76.5 x 38mm) 10oz (282.8g) 10.3oz (290.6g) CAT III 600V 850 Perimeter Road • Manchester, NH • (603) 669-6400 • info@triplett.com
CM650-NIST 价格&库存
很抱歉,暂时无法提供与“CM650-NIST”相匹配的价格&库存,您可以联系我们找货
