231280
231280
    DESCO
    DESCO EUROPE / VERMASON - 231280 - ESD Grounding Cord, Bench Mat, Black, 4.5m, 1Mohm
231280 数据手册
Description • 2.4 mm PVC insulation • Conductor is high strength 7-strand tinsel wire for strength and durability • Low-profile conical head helps prevent cord from being knocked off • Built-in 10 mm socket fits stud on mat • 1 megohm resistor built into each 10 mm socket (unless otherwise specified) 231280 231266 Item Description 231265 1.7 m Straight Cord with Conical Head, 10 mm Socket / M5 Ring Terminal, No Resistor 231266 1.7 m Straight Cord with Conical Head, 10 mm Socket / 10 mm Socket, No Resistor 231267 4.5 m Straight Cord with Conical Head, 10 mm Socket / 10 mm Socket ”The protection of ESDS is accomplished by providing a ground path to bring ESD protective materials and personnel to the same electrical potential. All conductor and dissipative items in the environment, including personnel, shall be bonded or electrically connected to a known ground or common connection point. This connection results in a sharing of charge which equalizes the voltage across all items and personnel and eliminates the changes of an ESD event to ESD sensitive devices.” [CLC/TR 61340-5-2 User guide Grounding/bonding systems Clause 4.4.1 Introduction] “Where an equipotential bonding system is used, it is important to verify that the common connection point is sufficiently conductive. The resistance of the common connection point between any two ESD control items should be less than 1 Ω when measured using a DC ohmmeter capable of measuring resistance from 0,1 1 Ω through 1x106 1 Ω with a minimum open circuit voltage of 1,5 V.” [CLC/TR 61340-5-2 User guide Grounding/bonding systems Clause 4.4.4.3 Equipotential bonding] EUROPE © 2019 DESCO INDUSTRIES INC Employee Owned 231280 4.5 m Straight Cord with Conical Head, 10 mm Socket / M5 Ring Terminal Unless otherwise noted, tolerance ±10 % Specifications and procedures subject to change without notice. Made in Taiwan Straight Cords with Conical Head DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 231265 DATE: March 2019
231280 价格&库存
很抱歉,暂时无法提供与“231280”相匹配的价格&库存,您可以联系我们找货
