231636
231636
    DESCO
    DESCO EUROPE / VERMASON - 231636 - ESD Field Service Kit, Wrist Strap, EBP Ground Cord, Crocodile Cl...
231636 数据手册
Purpose of Field Service Kit To create a temporary ESD Protected Area (EPA). An EPA is a working space where electrostatic discharge sensitive devices (ESDS) may be unpacked, handled and packed with the minimum risk of being damaged by static electricity. Instructions for use • Remove kit from pouch • Open mat and place on a flat stable surface with the stud facing upwards. • Connect straight ground cord using snap fastener to the stud on the mat. • Connect 4mm plug of the straight ground cord to Earth or to an earthed terminal of the equipment. If necessary use the crocodile clip to do so. • Put on wristband. Ensure wristband fits snugly. Separate instructions for use are supplied with band. • Connect coiled cord (has a 1 megohm resistor) by snap fastener to wristband. • Plug the other end of coiled cord into straight cord. Alternatively, the coiled cord can be connected to Earth or the equipment Earth terminal, possibly using the crocodile clip. • The EPA is now ready for use. 231635 Item Description 231615 Field Service Kit - Heavy Duty, Blue 231635 Field Service Kit - Heavy Duty, Red "Field service activities often necessitate a completely portable work surface that may fit in a tool kit or pocket of a field service engineer. This work surface shall be designed so that it can withstand continual handling and frequent connection and disconnection from ground. The work surface might also need to last for years in the service engineer's tool kit." [CLC/TR 61340-5-2 User guide Work surfaces Clause 4.7.1.2.2 Permanency of the work area] "Portable work surfaces in a variety of forms (multi-layered or homogeneous) are available to meet established requirments and the same ESD control needs as those used in non-remote areas. Typically, field service work surfaces are designed to fold up and fit in a tool kit or a pocket of a field service engineer." [CLC/TR 61340-5-2 User guide Work surfaces Clause 4.7.1.3.5 Field service/portable work surfaces] Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. EUROPE © 2018 DESCO INDUSTRIES INC. Employee Owned General Instructions • Always replace kit in pouch after use. • Do not clean mat with solvents. Use Reztore® ESD Surface & Mat Cleaner or mild detergent and warm water. • Pockets sewn into mat are suitable for holding components, PCBs and ESD compatible tools. • If possible test the overall resistance to Earth of the personnel regularly. This can be achieved by preparing the kit for use and measuring the resistance from the operator’s finger tips to Earth. The resistance should be approximately 3 megohms, but certainly be at least 0.75 but less than 35 megohms. Properties • RS: < 1 x 108 ohms, RG: 1 x 106 to 1 x 108 ohms • Size when open 590mm x 545mm • Total weight of kit: 0.4kg • Kit 231615 includes 1 x blue field service mat, 1 x blue pouch, 1 x 229765, 1 x 230205, 1 x 231255 and 1 x crocodile clip • Kit 231635 includes 1 x red field service mat, 1 x red pouch, 1 x 229755, 1 x 230175, 1 x 231255 and 1 x crocodile clip Made in the United Kingdom Portable Field Service Kit - Heavy Duty DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 231615 DATE: February 2018
231636 价格&库存
很抱歉,暂时无法提供与“231636”相匹配的价格&库存,您可以联系我们找货
