Meets the resistance required range for packaging of EN 61340-5-1
and Packaging standard IEC 61340-5-3 per IEC 61340-2-3.
A. Desco Europe PCB racks are moulded in black conductive polypropylene.
B. These racks are a good investment to protect CMOS loaded boards, the design enables the storing
of boards approximately 25% longer than their base depth.
C. It is recommended that they are used in conjunction with complete static protected work stations.
D. Electrical resistance RV: 1 x 103 to < 1 x 105 ohms (test method per IEC 61340-2-3).
E. Recommended maximum operating temperature is 75°C
Item
Description
237195
PCB Rack, 208mm x 272mm x 93mm, slots: 25 x 2mm
237200
PCB Rack, 355mm x 266mm x 128mm, slots: 25 x 3mm
“The fundamental ESD control principles that form the basis of IEC 61340-5-1 are as follows:
a) Avoid a discharge from any charged, conductive object (personnel, equipment) into the device:
This can be accomplished by bonding or electrically connecting all conductors in the environment, including personnel, to a known
ground or contrived ground (as on shipboard or on aircraft). This attachment creates an equipotential balance between all items and
personnel. Electrostatic protection can be maintained at a pontial different from "zero" voltage ground potential, as long as all items in
the system are at the same potential. ..."
[EN 61340-5-2 Introduction]
Made in the
United Kingdom
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
EUROPE
© 2017 DESCO INDUSTRIES INC.
Employee Owned
L-Shaped PCB Racks
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
Drawing Number
237195
DATE:
December
2017
很抱歉,暂时无法提供与“237200”相匹配的价格&库存,您可以联系我们找货
