203065
203065
    DESCO
    DESCO EUROPE / VERMASON - 203065 - Antistatic Bag, Pink, Resealable, 254mm W x 355.6mm L
203065 数据手册
A. These products are made of an antistatic polyethylene film that under normal working conditions doesn’t generate triboelectric charges. B. The bags are tough, amine free, do not affect polycarbonate housings and do not cause corrosion. C. The product is transparent and tinted pink. Typical film thickness is 75 micron. D. Bags are hot foil printed in yellow with a descriptive text and ESD protective symbol per EN 61340-5-1. E. The zip in the bags uses a double tooth locked closure system for strength - this is impulsive sealed into the bags. It is made from Polyethylene. F. Dissipative bags can be used as packaging for ESDS and non-ESD sensitive items in ESD protected areas e.g. passive components, screws. The antistatic properties are long lasting provided the film is stored in a cool dry place. Do not store outside and do not expose the film to heat or store in an overheated warehouse. PHYSICAL PROPERTIES: Density 920kg/m3 (ASTM D792) Thickness 75 micron Tensile Strength MD >10-12mpa (BS 2782) CD >10-12mpa (BS 2782) Elongation MD >250-300% (BS 2782) CD >400-500% (BS 2782) Item Size (WxL) 203000 75 x 125mm (3” x 5”) with write-on panels, with zipper ELECTRICAL PROPERTIES: 203005 100 x 150mm (4” x 6”), with write-on panels, with zipper Inner Surface Resistance (50% RH) 1 x 105 to < 1 x 1011 ohms (IEC 61340-2-3) 203010 125 x 200mm (5” x 8”), with write-on panels, with zipper Outer Surface Resistance (50% RH) 1 x 105 to < 1 x 1011 ohms (IEC 61340-2-3) 203015 150 x 200mm (6” x 8”), with write-on panels, with zipper Shelf Life 2 years 203025 200 x 250mm (8” x 10”), with write-on panels, with zipper 203030 250 x 350mm (10” x 14”), with write-on panels, with zipper 203040 100 x 150mm (4” x 6”), with zipper RoHS 2 and REACH Compliant 203065 250 x 350mm (10” x 14”), with zipper MD = Machine direction, CD = Cross direction Tear Resistance >50N/mm Thickness (BS 2782) CHEMICAL PROPERTIES: Antistatic Additive Amine Free - Non-Corrosive and Polycarbonate Compliant Sold 100 per package Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. “Packaging used within an EPA shall consist of dissipative or conductive materials for intimate contact.” [EN 61340-5-3 Clause 5.2 Inside an EPA] EUROPE © 2017 DESCO INDUSTRIES INC. Employee Owned Made in the United Kingdom Antistatic Pink Bags with Zipper DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 203000 DATE: December 2017
203065 价格&库存
很抱歉,暂时无法提供与“203065”相匹配的价格&库存,您可以联系我们找货
