203530
203530
    DESCO
    DESCO EUROPE / VERMASON - 203530 - Antistatic Bag, Conductive, Heat Seal, 101.6mm W x 101.6mm L
203530 数据手册
Product Information Page 1 of 1 Bin 22 No: PIS 048 Issue No 5 Date 13 Aug 2003 Approved by CONDUCTIVE FILM AND BAGS Code BP3.. Vermason black conductive film is made of linear low density polyethylene to achieve high toughness and strength. The film is carbon loaded for consistent, non-humidity dependent conductivity. With a surface resistance of less than 105 ohms per square, this material shields against electrical fields. It has a shelf life measured in years and is resistant to common solvents. Typical film thickness is 72 micron (300 gauge). The material is printed in yellow and meets the requirements of EN 61340-5-1: 2001 and includes the ESD warning triangle . It is sold as layflat tubing on rolls or as bags. Typical physical properties MD = Machine direction CD = Cross direction Tensile strength MD CD Elongation at break Elmendorf tear strength 28 25 kPa kPa ASTM D882-A MD 900 CD 1000 % % ASTM D882-A MD CD 6 9 N N ASTM D882-A Dart drop impact strength 250 gr ASTM D1709-A Water vapour transmission rate >0.8 gr/m2 24 hr at 50% rH & 20oC Weight 0,07 kg/m2 Roll and bag width tolerance (inside) +15 -2 mm mm Bag length tolerance (inside) +30 -2 mm mm Typical electrical properties Surface resistivity
203530 价格&库存
很抱歉,暂时无法提供与“203530”相匹配的价格&库存,您可以联系我们找货
