201520
201520
    DESCO
    DESCO EUROPE (FORMERLY VERMASON) - 201520 - Antistatic Bag, Statshield Series, Shielding (Metal-In),...
201520 数据手册
Low Charging Clear Zipper STATSHIELD® METAL-IN SHIELDING SERIES Meets EN 61340-5-1 and Packaging standard IEC 61340-5-3 tested per IEC 61340-2-3 (ANSI/ESD STM11.11) and IEC 61340-4-8 (ANSI/ESD STM11.31) Specifications: Date & Lot Code Printed for QC Traceablility Side Weld Seals 9.5mm (± 2.5mm) Tolerance W: ± 6mm / Tolerance L: ± 6mm Low Charging Static Dissipative Proprietary Outer Polyester Layer Aluminium Shielding Layer Low Charging Static Dissipative Proprietary Inner Polyethylene Layer 7 Mixed Unsortable Plastic Scrap Mixed unsortable plastic scrap shall contain assorted plastics of multiple grades that are co-extruded, bonded or laminated together which are unsortable into individual grades Desco Europe bags are recyclable Electrical Properties Surface Resistance:   Outer Surface   Inner Surface Discharge Shielding Charge Generation Capacitance Probe (to dissipate 1 KV) Typical Values Test Procedures/Method 1 x 104 to < 1 x 1011 ohms 1 x 104 to < 1 x 1011 ohms 10 lbs/in 4600 PSI, 32 MPa >10 lbs Pass Silicone Not detected MIL-STD-3010, 1003 ASTM D-1003 375°F, 1/2 sec 60 psi ASTM 882 MIL-STD-3010, 2065 IPC-TM-650 2.4.1 ASTM E 168 Chemical Properties Corrosion Polycarbonate Capability, No effect on aluminium, copper, silver, Sn-Pb coated foil, stainless steel, low carbon steel Yes Item No. Size (WxL) 201500 201510 201515 201520 201525 201530 201535 201540 201545 201550 201551 201552 201555 201556 201560 75 x 125 mm 100 x 150 mm 125 x 200 mm 150 x 200 mm 150 x 255 mm 200 x 255 mm 200 x 305 mm 255 x 305 mm 255 x 355 mm 305 x 405 mm 305 x 455 mm 355 x 455 mm 455 x 455 mm 455 x 610 mm 505 x 505 mm Bag is free of amines, N-octanoic acid, silicones and heavy metals. Per Packaging Standard EN 61340-5-3 clause 5.3 Outside an EPA “Transportation of sensitive products outside of an EPA shall require packaging that provides both: a) dissipative or conductive materials for intimate contact b) a structure that provides electrostatic discharge shielding.” RoHS 2, REACH and Conflict Minerals Statement None of the RoHS 2 restricted materials, or REACH substances of very high concern as of 2015/12/17, or Conflict Minerals are intentionally added in manufacturing this product. Ref: European Directive 2011/65/EC Article 4.1. and Regulation (EC) No. 1907/2006/CE. See Desco Europe Limited Warranty at DescoEurope.com. Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc. Statshield® bags are packaged 100 per package in an oversized shielding bag. See TB-7057 - Requirements for Statshield ESD Bag Storage Made in the United States of America Specifications and procedures subject to change without notice. Statshield® Bag, Shielding, Metal-In Construction, Zipper DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com © 2018 DESCO INDUSTRIES INC. Employee Owned Drawing Number 201500 DATE: May 2018
201520 价格&库存
很抱歉,暂时无法提供与“201520”相匹配的价格&库存,您可以联系我们找货
