242278
242278
    DESCO
242278 数据手册
Used in applications masking PCB gold features for wave soldering Tape is wound on a paper core. The user must determine the suitability of the product for its intended use. Wescorp Tape Storage and Limited Warranty: The user must determine the suitability for use of an antistatic tape for his particular application. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Desco Europe recommends those tracking useful life of product to use shipping/invoice date as Desco Europe expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of defects in material (parts) and workmanship (labour). See details of Limited Warranty online at DescoEurope.com RoHS 2, REACH, and Conflict Minerals Statement See the Desco Europe RoHS 2, REACH, and Conflict Minerals Statement: DescoEurope.com/ROHS.aspx • • • • • • • • • • • • • • • • Waterproof Does tribocharge, but has minimal charge retention Total thickness: 7 mil (0.007” or 0.18mm) Adhesive surface resistance: 1.2 x 1011 ohms Film resistance: < 1 x 1011 ohms tested per ANSI/ESD S11.11 at 50% RH Maximum temperature: 135°C (275°F) 45 minutes max Non-toxic pH neutral Non-corrosive Tensile strength: 12mm Adhesion to steel: 155.04 g/cm2 Elongation: 8% Temperature range: -36°C to 135°C (-32°F to +275°F) Adhesive mass: natural rubber Adhesive: non-staining Excellent conformability Note: Waterproof release coating does generate static charges during unrolling. We recommend slow unwinding, utilising an ioniser to neutralise the charge. 2mm 18mm 24mm 48mm Core 242278 242279 242280 242281 7.62cm *Wescorp is a Desco Industries brand. Note: Tape rolls may vary slightly in colour Employee Owned 1/2" 3/4" 1" 2" is 12mm is 18mm is 24mm is 48mm nominal nominal nominal nominal or or or or 0.472" 0.709" 0.945" 1.890" Unless otherwise noted, tolerance ±10%. Specifications and procedures subject to change without notice. Wescorp ESD High Temp Masking Tape, Paper Core DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com © 2018 DESCO INDUSTRIES INC. Tape widths are nominal metric ±0.8mm (±1/32"). 54.8m Width tolerance ±0.8mm See the Desco Europe Limited Warranty: DescoEurope.com/Limited-Warranty.aspx See the Desco Europe Disclaimer: DescoEurope.com/Disclaimer.aspx Length Drawing Number 242278 DATE: January 2018
242278 价格&库存
很抱歉,暂时无法提供与“242278”相匹配的价格&库存,您可以联系我们找货
